Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi 2.5TDI Q 99a Tiptronic käigud kadusid ära
Pealkiri: Audi 2.5TDI Q 99a Tiptronic käigud kadusid ära (Vastuseid: 1 | Vaatamisi: 1766)
BestCarAUDI80
Registreerunud 07.01.06
Auto: Audi80 (B2)
postitati 20.10.13 22:52 Tsiteeri
Nimelt siis paar päeva tagasi hakkasid käiguvahetused natuke robustsemaks muutuma. Täna siis juhtus nii et sõites hakkasid käigud ära hääbuma. Vaikselt ilma erilisi pöördeid andmata liikusin nii tuttava majani.
Jäin siis tee äärde seisma ja proovisin tagurdada, sai siis vajalik manööver tehtud.
Pärast aga absoluutselt edasi ega tagasi ei liikunud ja kogu käigukasti õli oli ka asfaldil. Kui kellelgi on kogemusi võiks siin sõna võtta, igasugune info on teretulnud. Kõik see siis toimus Pärnus, ehk on keegi sealt kandist ja võibolla saaks midagi kokku leppida.
Ette tänades!
postitati 21.10.13 13:07 Tsiteeri
Seda ikka tead, et aut. kast ei toimi ilma õlita? Seega esimene asi, uuri, kuskohast õli tänavale tuli. Vastavalt sellele siis edasi.
[PHP: 8.3% - SQL: 91.7%]
