Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 2.8 V6 142kw tihendite vahetus, mida peaks varuma?
Pealkiri: 2.8 V6 142kw tihendite vahetus, mida peaks varuma? (Vastuseid: 2 | Vaatamisi: 1680)
Darkdog
Registreerunud 20.03.06
Auto: Audi A6
postitati 23.09.13 06:11 Tsiteeri
Kuna mootor õline, plaan teha suurem remont ja vahetada välja enamik tihendid.
Audi A6 C4 2.8 V6 142kw. Mida peaksin poest varuma?
- Rihmade, rullide komplekt
- Rihma pinguti
- Veepump
- Termostaat
- Geneka rihm
- Klapikambrikaane tihendid
- Nuka simmekad
- Klapisääre tihendid
- Plokikaane tihendid
- Plokikaane poldid
- Õli + filter + jahutusvedelik
- Karteritihend
Mis mul vahele jäi, või mida veel vahetada?
Auto: 6x4x4
postitati 23.09.13 07:32 Tsiteeri
Kui laiali Sa seda masinat kakkuda tahad ja kas väntvõlli otsasimmerid peavad? Kas kavatsed mootori maha võtta?
Soovituslikult veel:
+ Hüdrotõukurid, kui juba lahti siis pole mõtet vanu sisse jätta (varem või hiljem hakkavad õlirõhku läbi lobistama)
+ Sisselaskekolde tihendid (irduvad ribadena)
+ Õli vahejahuti alune rõngastihend (muutub vanast peast rabedaks ja võib talvel külmalt paksu õliga mahlad välja visata)
+ Kui väljalaskekoldeid maha ei kaku, siis pole vaja - kui kakud siis ka kaane ja kolde vahelised tihendid.
+ Jahutusvedeliku torustiku ja kaane vahelised tihendid (surnud vanusesse ja riskantne samadega tagasi panna)
+ Käbi (kindluse mõttes, aga vastavalt kuidas vana lahti tuleb)
+ Klapikambri tihendite puhul ikka mõlemad, ka küünlakodade vahelised (neid unustatakse pakkuda).
Lisaks:
+ Vaata üle roolilati kattekummid ja survevoolik. Kui kaaned maas on sinna palju lihtsam ligi pääseda
- plokikaane poldid osta ainult originaalid või keera vanad tagasi (B osa on andke andeks P*SK, sõltumata kes on tootnud)! Aga eks igaühele jääb tema enda arvamuse õigus.
+ Kui kavatsed alumise õliämbliku lahti kakkuda, siis ka selle tihend lisaks karteritihendile (paljud varuosade müüjad ei tea sellest tihendist mitte midagi ja ka kataloogid ei näita). Lisaks on vanni tihend aastatekäikudel erinev.
+ Siduri survelaager kui mootor on maas (oletame, et tegemist on manuaaliga).
+ Ürita jahutussärgi kork anduri kõrval liikuma saada, hiljem on sellele kehvem ligi saada, et liikuma saaks. Vajadusel vaheta ära kui kantidest lahti saad. Anduri vahelt saab küll õhku kätte, aga korgi kaudu on lihtsam ja parem pika kuuskandiga.
+ Nukakettide olukord.
+ Vaata kuumaga kokku puutuvate andurite pistikud üle, kui plast on rabe siis vaheta need samuti välja. Plasti rabedus annab ennast suhteliselt lihtsalt märku :).
+ Pisiasju, mida hetkel pähe enam ei tule on kindlasti veel.
Kaaned soovitaks loomulikult mõnel tegijal üle käia, et ka "tihe" saaks.
Väldi soetades sõna TOPRAN - soovitan soojalt!
rix30
Registreerunud 19.04.09
Auto: Audi S3 1,8T 8L
postitati 23.09.13 08:26 Tsiteeri
Vända esimene ja tagumine simmer tihend (ei näinud kuskil kirjas olevat).
Kaante taga jahutus vedeliku ringlus toru flantside tihendid 2tk.
Adolf Hitler!
[PHP: 21.2% - SQL: 78.8%]
