Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi 80 B3
Pealkiri: Audi 80 B3 (Vastuseid: 10 | Vaatamisi: 1265)
Janek_P
Registreerunud 22.09.13
Auto: Audi 100 C3
postitati 22.09.13 04:45 Tsiteeri
Audi 80 B3
Tere, Olen siis uus audi omanik ja mul oleks üks väike mure.
Probleem siis selline et mu audi käib korralikult ainult tühipööretel
Ja siis kui vajutan gaasi põhja. Jama hakkas peale seda kui tankisin Viljandis
Favora tanklas.
Kas viga võib olla küttes või millegis muus?
Autoks siis Audi 80 B3 1989 a.
Ette tänades,
Janek
Janek_P
Auto: Audi 100 C3
postitati 22.09.13 07:17 Tsiteeri
Alates täna hommikust ei taha tühipööretel ka käija :-(
andres91
postitusõiguseta huviline
Registreerunud 07.04.09
Auto: b4
postitati 22.09.13 08:36 Tsiteeri
mis mootoriga?
tl470487
aeg maha
Registreerunud 06.07.11
postitati 22.09.13 11:51 Tsiteeri
Ostsid auto ja pärast esimest tankimist algas see? Või juba enne?
Mida tankisid, 95?
Kui vahetult pärast tankimist ja 95 siis võid proovida 98 peal tööle panna. Selleks ei pea paaki tühjendama vaid alternatiivsele suvalisele anumale voolikud tõsta.
Võid ka proovida oktaanarvu korrektorit lisada aga see test kindlasti kulukam ja pealegi ei pruugi sama tulemust anda, kuna on keeruline saadud oktaanarvu kontrollida.
Kui 98-ga hakkab tööle siis saab edasi mõelda.
Algselt postitas: Janek_P
Favora tanklas.
Ette tänades,
Janek
Janek_P
Auto: Audi 100 C3
postitati 22.09.13 19:16 Tsiteeri
Kapote vahel on 2.0 engine :-P
Olen eelnevalt ka tankinud ikka aga sealt tanklast esimest korda...
Tankisin ikka 95-te,
jokerAudi
Registreerunud 09.02.08
Auto: Superb 2018
postitati 22.09.13 19:27 Tsiteeri
Mina alustaks kütusefiltrist. Kõige odavam ja lihtsam koht, kust alustada. Vaheta kütusefilter ära, vaata, mis siis saab.
Janek_P
Auto: Audi 100 C3
postitati 25.09.13 05:27 Tsiteeri
Praegult siis töötab niimoodi kui pöörete piiraja nupp on alla vajutatud. Aga tänu sellele ei saa ühtlase gaasiga sõita, mootor arvab et pöörded põhjas ja hakkab pööretega mängima. .. :-(
Janek_P
Auto: Audi 100 C3
postitati 26.09.13 05:54 Tsiteeri
Nonii sõbrad, Viljandi lähedusest keegi kiiresti mulle 80 2.0 1989 käigukasti pakub odava raha eest? :-)
56774173 palun helistada.
Janek_P
Auto: Audi 100 C3
postitati 29.09.13 10:28 Tsiteeri
Kas r5 käigukast sobiks? Andmed muidu samad lihtsalt r5
postitati 29.09.13 10:42 Tsiteeri
Mul oleks pakkuda CGT koodiga käigukast. Oli see 94a 2.0 66kw ABT mootori otsas. Asub Tartumaal. Huvi korral võta ühendust.
Janek_P
Auto: Audi 100 C3
postitati 29.09.13 10:49 Tsiteeri
Kahtlen et ei istu?
[PHP: 33.9% - SQL: 66.1%]
