Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi A4 B7 (103kW) 2005 VÄRIN
Pealkiri: Audi A4 B7 (103kW) 2005 VÄRIN (Vastuseid: 19 | Vaatamisi: 3735)
Rauno639
Registreerunud 13.07.13
postitati 30.08.13 17:06 Tsiteeri
Nimelt autoks Audi A4 B7 (103kW) 2005, BNA mootori tüübiga. Nimelt on hakanud värisema kahtlaselt. Vabadel pööretel vaikselt nagu väriseks, samas kui anda 1100-ni, on vibratsiooni kõvasti paremini tunda--1200 ja vibratsioon kaob. Hommikuti tahab vahel pikemat käivitust, nagu ei saaks kütet korraga peale. Sooja mootoriga tahab pikemat käivitust. Salongi sisse kuulda vaikset undamist, kapoti alla vaadates tuleks nagu juhi poole pealt see heli.
Rihmad, rullid hiljuti vahetatud, diagnostis käidud-veakoode pole, pihustid head.
Kas viga võib olla HOORATTAS?
real-illusion
Registreerunud 27.09.11
Auto: A6 3.0 TDI 165 kw Q
postitati 30.08.13 18:01 Tsiteeri
Algselt postitas: Rauno639
Hea nali- diagnostis käidud (veakoode pole) Mingi küla vasja juures käisid? (Ei ole rassist) Mis käigukast sul on? Ise usun, et äkki käigukastis originaal õli ja see põhjustab. Minul tiptronic c6-l oli alguses ka madalalt värin lõpus kuni 2400 ja viimastel päevadel suht 3.5 tuhandeni välja. Sai käidud r129 külas ja õli vahetus, uued adaptsioonid, ning korras. Siiani pole ca 7k km juures midagi muutund... Loomulikult võib põhjuseid olnud rohkem, aga peab käima korralikus kohas diagnostis...
Life is tough.
postitati 31.08.13 06:09 Tsiteeri
Lase esimene mootori tugipadi paika seada.
Ma tahaks ka nüüd teada, mis mõiste on "korralik diagnost"? Veamälu vaatamine on sellest üks ja oluline osa. Aga edasi ? Kus lõpeb halb ja algab korralik? Kas MB erinevate väärtuste uurimine on hea? Või hoopis halb? Kas erinevate adaptsioonide tegemine on "hea"? Kodeeringute muutmine vist enam nii hea ei ole? Aju softi ümberkirjutamine vist pole ka enam diagnost, või siiski on? Ja kui diagnost midagi ei tuvasta, siis polegi ju nagu diagnost, või siiski on?
Vahest on ju nii, eriti vanemate masinate meh. vigade korral.
Kes defineeriks hea diagnosti?
Rauno639
postitati 31.08.13 08:01 Tsiteeri
Kui esimene mootori tugipadi on taoline vahu laadne käkerdis, asub radika lähedal siis see sai alles hiljuti vahetatud, kuna originaal oli nii pudetaks muutunud. Kuidas selle paika seadmine veel ette peaks nägema?
Autol manuaal kast. Kõik vajalikud õlid ja filtrid ka vahetatud. Nendega on ligikaudu 3000 km juba sõidetud, auto kaks kuud vana alles (minu käes).
Ei taha eriti uskuda et mootori tugipadjast selline vibratsioon võib tulla. Eile panin veel ka seda tähele, et kui kolmandaga kiirendada, nii 3000 pöördeni ja siis üritada sidurit lahutada, siis tekib ka siduri pedaali selline kõrin/värin. Rahulikult sõites, kui pöörded pole väga kõrged käigu vahetuse momendi, siis tunneb harva sellist kõrinat/värinat läbi siduri pedaali. Nimelt see esimene dislakas mul ning ei tea kas peabki nii toimima või mitte, sidur võtab ka kahtlaselt ülevalt.
Esimeses postis ei maininud ka seda, et sujuval kiirendamisel, hakkab vahel nii enne 2000 pööret jõnksutama, nagu ei saaks kütet peale vms, kuid kui jõnksutamise ajal lapp põhja vajutada, kaob jõnksutamine. Pihustid on TIPTOP.
jokerAudi
Registreerunud 09.02.08
Auto: Superb 2018
postitati 31.08.13 08:06 Tsiteeri
Kohapeal külma mootoriga mingeid veidraid hääli pole? Mingi kolin näiteks? Mina pakuks selle värina põhjuseks hooratast just nimelt. Millest järeldad, et pihustid on tiptop? Ise leiutasid või ütles see "diagnostik"?
Rauno639
postitati 31.08.13 08:33 Tsiteeri
Algselt postitas: jokerAudi
Kolinat ei ole kuulda olnud. Diagnostis olid kõik pihustite näidud nullilähedased.
Täna siis sõitsin enamus päevast ilma muusikata ja kuulasin heli. Arvastasin et käigu vahetuse momendil, nii kui pöörded umbes 2000, teeb sellist huvitavat häält nagu midagi viliseks. Umbes sarnane hääl kui panna suuremalt käigult madalamale, kui mina panin just vastupidi. Heli tekib just hetkel kui siduri põhja vajutan. Heli kestvus max 1-2 sekundit ja siis kaob.
Ehk midagi siis sealt käigukasti poole pealt mäda???
Rauno639
postitati 05.09.13 17:44 Tsiteeri
Ei oska keegi midagi siis öelda? :(
yanekk
postitati 05.09.13 18:16 Tsiteeri
Rohkem kui üks kord juba öeldud, võta kast maha ja siis näha, kuigi lõhnab hooratta järgi see.
Best ET 12.08 :)
Rauno639
postitati 17.06.14 17:56 Tsiteeri
Mootori poolsed probleemid { Audi A4 B7 2004 100kW (BNA)
Natukene unarusse jäänud teema, kuid jätkaksin. Nimelt autol tekkinud suuremat sorti värin, kui süüde välja keerata. Diagnostis käidud (pihustid, pumbad jne korras). Kuu tagasi vahetatud kahemassiline hooratas, LUK-i oma (vana oli läbi), sidur-korv- laager (Sachs), kõik 3 mootoripatja (Audi Originaalid).
Mureks veel ka pikemat sorti käivitumine ning aeg-ajalt sujuvalt kiirendades 2000 pöörde juures jõnksutamine. Jõnksutamise hetkel väänet juurde andes viga kaob.
Ehk oskab keegi aidata. Endal pea enam ei võta :(
niffu
Registreerunud 04.11.04
Auto: C6, A6 & A6 Allroad ;Coupe Quattro Typ85 x 2
postitati 19.06.14 09:32 Tsiteeri
Parandage mind kui ma eksin, kuid kas nendel algusaasta b7-l mitte õlipumba varda viga suht tihti esinev probleem ei olnud.
Rauno639
postitati 28.06.14 18:11 Tsiteeri
Ei oska keegi aidata?
postitati 28.06.14 19:43 Tsiteeri
Pädev töökoda oskab küll, aga sinna sa minna ei taha.
Veakoodide lugemine on diagnost või?
Rauno639
postitati 29.06.14 17:36 Tsiteeri
Algselt postitas: mkb
Kuna esindusse minemiseks pole kunagi aega (pidevalt viibin Soomes), siis tahtsin teada et ega keegi selliste asjadega varem kokku pole puutunud. Pole vaja kohe kurjustama hakata, seega endiselt ootan vihjeid.
Siim89
Registreerunud 07.06.10
Auto: C5 1.8T; C4 2.2TQ;
postitati 29.06.14 18:03 Tsiteeri
Soomes pole Audidel ühtegi esindust?
S4 OMC 238 km/h, ET 13,04
vedru
Registreerunud 07.01.07
Auto: Auditu
postitati 29.06.14 18:09 Tsiteeri
Algselt postitas: Siim89
Seal naljalt 3 kohalise numbriga ei pääse;)
postitati 29.06.14 18:30 Tsiteeri
Algselt postitas: vedru
Kas sissetuleku ja esinduse arve suhe on väiksem kui Eestis?
vedru
Auto: Auditu
postitati 29.06.14 18:52 Tsiteeri
Algselt postitas: audi_a4_v6
Aastal 2009 käidi Soomes Audis sees, puruks löödi tagumine külje klaas. Esindus SAI teha hinna 1300.- koos tööga, vähe googeldades sain originaal klaasi, koos vahetusega 130.-, siin nagu ei ole palkadest mõtet üldse rääkida. Andke andeks, kui ma ka teeniks Soomes 5000.-, on sealsed hinnad ulmelised. See, kui sul ka raha on, otsib ikkagi inimene võimaluse, kust saab soodsamalt.
Siim89
postitati 29.06.14 20:57 Tsiteeri
Vaevalt nüüd terve diagnostika 1000€ tuleks. Viga pole teada ja kui teada, siis saab juba konkreetsemalt midagi odavamat Eestis otsida ju. Aeg leppida ja töö lihtsalt ära teha.
real-illusion
postitati 30.06.14 04:37 Tsiteeri
Autofoorumi diagnostika ca 80-100 eurot. :)
Life is tough.
Rauno639
postitati 30.06.14 18:05 Tsiteeri
On aga tööpäevad kõik nädala sees ju. Asi poleks rahas vaid ajas, mida mitte kuskilt pigistada ei saa.
[PHP: 34.1% - SQL: 65.9%]
