Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890 Eesti Audi Klubi foorum - A4 1.6 1997 suri välja ja enam ei käivitu
Pealkiri: A4 1.6 1997 suri välja ja enam ei käivitu
(Vastuseid: 2 | Vaatamisi: 679)
Magoo
Registreerunud 16.07.13
postitati 22.08.13 19:19
Tere,
Mure järgmine. Sõitsin umbes 10 minutit, käisin poes, auto läks ilusati käima ja paar hetke hiljem suri välja ja enam käima ei läinud. Vedasin koju
ära ning teadjad ütlesid, et kütusepumba häda. Vahetasin nüüd pumba, aga käima ei lähe. Kas aitab veel mingi lihtne võlunipp või pean hakkama juhet
otsima, et koode lugeda?
Maaryo
Registreerunud 15.11.09
postitati 22.08.13 19:28
Aga millest teadjad mehed järeldasid,et kütusepumba viga
Mina alustaks kõigepealt kaabli taha pistmisega, ilmselt kõige lihtsam variant.
Kui kaablit kohe käepärast pole,siis kontrolliks esialgu kaks asja: kas säde on ja kütus jõuab samuti kapoti alla.
yanekk
postitati 22.08.13 20:14
Algselt postitas: Magoo
Vedasin koju ära ning teadjad ütlesid, et kütusepumba häda.
Kus kandis ka sellised "teadjad mehed" elavad, saaks ka ehk teinekord abi, kuidas porgandi lõikurist kapsa hakkur teha.
[PHP: 27.6% - SQL: 72.4%]
