Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi A4 1,9TDI ,sarniiri kägin...
Pealkiri: Audi A4 1,9TDI ,sarniiri kägin... (Vastuseid: 7 | Vaatamisi: 1235)
EriLugu
Registreerunud 06.06.13
Auto: A6 (C5) 1,9tdi 81kw
postitati 18.08.13 18:00 Tsiteeri
Eest sarniirid kägisevad, remonditöökojast öeldi, et muidu tunduvad korras olema. Soovitati süstida prooviks WD 40-t ,aga kägin kaob vaid ajutiselt. Aitab niisiis ainult sarniiride vahetus?
mtaudi
Registreerunud 26.02.07
postitati 18.08.13 18:03 Tsiteeri
Kui kägisevad, siis on juba kohe kohe nii läbi, et on juba tunda. Ja ei ole olemas sellist varianti, et tundub olema korras - kas on korras või ei ole korras. Šarniire vahetada ei saa, kuna on õõtsa sees - pead uue(d) õõtsa(d) ostma.
J.Aru
Registreerunud 28.07.12
postitati 18.08.13 19:32 Tsiteeri
Kui tõesti korras on siis võiks prooviks laagrimääret sisse panna. Ning jah, osadel komplektidel on tõesti nii näpuotsaga määret pandud, et pole ime kui väheks jääb.
EriLugu
postitati 24.08.13 12:10 Tsiteeri
Õnnestus tiba "tummisem" õli sisse ajada ja kohe saabus õnnis vaikus.
postitati 24.08.13 15:04 Tsiteeri
Isiklik kogemus ütleb, et varsti on oodata öötsa(de) vahetust. Kägin on samuti märk sellest, et asi pole enam öige, öli lisamine on ajutine lahendus.
Häält tegid ülemised vöi alumised öötsad?
sileem11
Registreerunud 17.09.03
Auto: G30LCI, B6,C3
postitati 24.08.13 15:27 Tsiteeri
Vaheta ära, lihtne töö. Tegin just ise kuu aega tagasi.
EriLugu
postitati 24.08.13 17:55 Tsiteeri
Eks ennem talve vahetab ära ,aga kägin oli praegu ainus probleem,ei lokse ega kolkse. Kuits, ausalt öeldes ei suutnudki tuvastada ...:(
RedRockets
Registreerunud 29.11.11
Auto: Audi, BMW
postitati 25.08.13 12:22 Tsiteeri
Minul kägises näiteks hoopis amordi ülemine see puks vms, amordi mutter oli väheke lahti kerinud, keerasin kinni tagasi ja kägin kadus!:P
Vähemalt saab kiiremini kui jala!
[PHP: 21.9% - SQL: 78.1%]
