Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Võib Lukku panna
Pealkiri: Võib Lukku panna (Vastuseid: 13 | Vaatamisi: 1310)
-jeq
Registreerunud 29.11.11
Auto: Audi A4 1999 2.5tdi Quattro ja Audi A4 1995 1.6 74kw
postitati 17.08.13 07:12 Tsiteeri
Võib Lukku panna
Tere käisin eile ülevaatusel ja peale sealt lahkumist läks tosool keema, jäin siis seisma ja valasin tosooli uuesti juurde kuid see ei aita enam läheb ikka kogu aeg keema. kas peab kuidagi seda süsteemi õhutama või ajab ise õhu välja.
Umpser
Registreerunud 01.02.07
postitati 17.08.13 07:15 Tsiteeri
Kas sul salongi ja mootori vahelise seina peal õhutusniplit pole? Sealt saaksid õhu välja. Termostaat on korralik?
Terv,
Urmas
Maaryo
Registreerunud 15.11.09
postitati 17.08.13 07:59 Tsiteeri
Peetis termostaat tekitab samuti keema minemist,kuna lihtsalt termostaat ei avane.
Seda saad kontrollida,kas alumine lõdvik läheb soojaks või mitte!
-jeq
postitati 17.08.13 08:21 Tsiteeri
alumine voolik ei läinud soojaks ja õhutusniplit pole.kunagi sai vw õhutada nii et sai tehtud vasak poolne soojendus radika toru lahti ja kui tosooli hakkas tulema sai kokku lükatud aga praegu proovisin sama moodi audi peal ja ei lükanud sealt ültse tosooli välja.
tarmo77
Registreerunud 04.08.13
postitati 17.08.13 13:10 Tsiteeri
Arvan et probleem on termostaadis,minu audil oli sama probleem.Vahetasin termostaadi ära ja probleem lahenes;)
-jeq
postitati 17.08.13 13:16 Tsiteeri
vahetasin termostaadi ära ja avastasin et mootori taga olev flants on katki ja lekkib sealt. esmaspäeval poodi uue järgi. nii et võib teema lukku panna.
-jeq
postitati 20.08.13 11:27 Tsiteeri
sai siis termostaadi vahetadud ja flantsi ka nüüd mure selles et ei saa õhku välja proovisin soojendusradika toru lahti võtta jne aga ei midagi vendist puhub ikka külma.
ragnara
Registreerunud 23.03.12
Auto: A4 b9 2.0TDI Quattro
postitati 20.08.13 11:29 Tsiteeri
Audil õhutab ennast ise süsteem, paisupaagi korgi abil, nii olen ma aru saanud. Lase töödata, ja jälgi tempi, kui tõuseb üle lubatud sureta välja, kui võimalus katseta töötava auto paisupaagi korki.
postitati 20.08.13 11:30 Tsiteeri
B5-l pidavat saama nina üles ajades mingi kallaku peale ja siis lased mootoril soojana käia vms. Uuri selle kohta täpsemalt.
Maaryo
postitati 20.08.13 12:58 Tsiteeri
Tundub päris kahtlane juba,üldiselt peaks see masin ennast ise õhutama.
Mis ta siis täpselt teeb,läheb samamoodi temperatuur kõrgeks.
Veepump ikka korras?
Samas kui tõsta mootori pöördeid kohapeal mingi hetkeni,peaks hakkama siiski salongiradika voolikust mingil määral jahutusvedelikku tulema!
ehanurm
Registreerunud 22.10.10
Auto: Volvo
postitati 20.08.13 13:14 Tsiteeri
Kui endal ka samamoodi hakkas ülekuumenema ( peale lõdviku purunemist ja kokku panemist) õhutasin süsteemi nii, et ajasin auto kuumaks (temp näidiku järgi kuskil 100-110 kraadi ) ja ajasin auto esiotsa üles,mingi kallaku peale ja paisupaagil kork maha ja hakkasin lõdvikuid käega pigistama ja peale 5-10 minti langes juba auto temp näidik 90 peale ja enam pole probleemi olnud. Autoks küll B4 1,9TDI aga süsteem peaks suhteliselt sama olema
-jeq
postitati 20.08.13 16:48 Tsiteeri
kui pöördeid tõsta siis hakkab ja mingil määral sealt tosooli tulema aga õhku ikka kätte ei saa proovisin veel korra kuumaks ajada ja kallaku peale ajada ja paisu paagi korgi lahti teha aga kasu midagi ainult tosool läks kaduma jälle. kui järsk see kallak olema peab? kuidas auto töökodades seda muidu tehakse seal pole juu kallakuid?
Maaryo
postitati 20.08.13 17:31 Tsiteeri
Endal vana mootoriga käis õhutamine nõnda,et läksin lihtsalt autoga sõitma.
Enamasti läks temperatuur alati kuskil 110-115 kraadini välja. Mina sellepärast ei muretsenud veel kui temp. üle 90 kraadi juba liikus ja polegi mõtet.
Mingi hetk lihtsalt lisasin jahutusvedelikku juurde,kui temp tagasi 90 kraadini langes. Alati selline teguviis töötas,ma ei oska nüüd öelda kui õieti ma tegelikult käitusin:D
Lihtsalt vedeliku lisamisega tuleb ettevaatlik olla.
Eks ise tead kas hakkad sellist teguviisi praktiseerima.
Reaalselt peaks see masin ennast ise täiesti kohapeal käies juba ära õhutama.
Kuidas survega jahutussüsteemis lood on,kas mingil hetkel paisupaagis vedelikku ei hakka välja ajama?
-jeq
postitati 20.08.13 17:41 Tsiteeri
minu arust ei hakka välja ajama.kui keema läheb siis kõik lõdvikud kivi kõvad.
[PHP: 30.5% - SQL: 69.5%]
