Pealkiri: Audi A8 D2 4.2 Q - 1997 - Karly (Vastuseid: 42 | Vaatamisi: 8397)
karly
Registreerunud 26.11.08
postitati 17.07.13 10:14 Tsiteeri
Tervist !
Teen siis ka uue liikuri kohta teema ära.
Autoks siis A8 4.2Q ja automaat.
Mis autol küljes on:
Solar luuk
Xenon tuled
Püsikas
Kliima
4*el aknad
Pool el. sisu(riidest)
Mehhaaniliselt liigatav rool
Bose
Pakett klaasid
Valgustus pakett
Täpsem lisade list:
PRCode: 0G7 = Tiptronic
PRCode: 0JZ = Without determination of weight categoryfor front axle
PRCode: 0YZ = Without determination of weight categoryfor rear axle
PRCode: 1AH = Electronic differential lock (EDL)
PRCode: 1BM = Standard suspension/shock absorption
PRCode: 1G3 = Alloy spare wheel with original equipment tires
PRCode: 1KE = Disc brakes rear
PRCode: 1LC = Disc brakes front
PRCode: 1MR = Leather steering wheel
PRCode: 1N3 = Speed-related variable steering assist (Servotronic)
PRCode: 3FR = Electric sliding/pop-up solar sunroof with automatic pre-selection
PRCode: 4UE = Air bag for driver and front seat passenger
PRCode: 5RQ = Right exterior mirror: convex
PRCode: 5SL = Left exterior mirror: aspherical
PRCode: 8AE = Radio RCD310 MP3
PRCode: 8FA = Without second battery
PRCode: 8GL = Alternator 120 A
PRCode: 8RY = Speakers with BOSE sound
PRCode: B0A = Component parts set without country-specific design requirement
PRCode: C0S = Alloy wheels 8J x 17
PRCode: G0Q = 5-speed automatic transmission for four-wheel drive vehicle
PRCode: H0S = Tires 215/60 R16 95H
PRCode: J1G = Battery 450 A (92 Ah)
PRCode: M72 = 8-cyl. gasoline engine 4.2 L/220 kW V8 Motronic closed-loop catalyt. converterbase engine is T7W
PRCode: Q1A = Standard front seats
PRCode: T7W = 8-cylinder gasoline engine 4.2 L Unit 077.5 (aluminum)
PRCode: X0A = National sales program Germany
Autol tehtud:
Saksat tulles 2008a tehti käigugasti remont pärnus.
2009 jäi auto seisma ja vahepeal veel tehtud:
Uued kettad ja koltsid nii ees kui ka taga.
Uued piduri voolikud ees.
Uued küünlad.
Uus mootori õli.
Uus kommutaator.
Vaja on veel uut aju ja rihmavahetus kindluse mõttes.
Saksast tooduna oli läbisõit 226 000 ja seisma jäi läbisõiduga 256 000.
Masin ise seisnud ca 3a sama aju veaga.
Mõni pilt ka masinast endast:
http://static2.fotoalbum.ee/fotoalbum/414/214/0103607481f4531.jpg
http://static2.fotoalbum.ee/fotoalbum/414/214/0103607485c7637.jpg
püstolett
Registreerunud 29.07.06
postitati 17.07.13 10:46 Tsiteeri
Täitsa ponks ju.
karly
postitati 17.07.13 10:51 Tsiteeri
Algselt postitas: püstolett
Täitsa ponks ju.
On :P Eks vahepeal tuleb veel huvitavat infot mis tehtud on siis lisan juurde :D
MatuAudi
Registreerunud 07.08.04
postitati 17.07.13 11:27 Tsiteeri
Ohoh, sellise aparaadi võtsid hoopis. Siis pole sind vist tallinna oodata seda näitama nii pea? :D
A8 ja tumedat värvi on ikka väga maasikas.
Defu - Matu
karly
postitati 17.07.13 11:35 Tsiteeri
Algselt postitas: MatuAudi
Kaua oodatud kaunike :D:D
Eks ma mingi aeg pean ikka linna ka tulema :P Siis saad kaeda :D Eelmist A6-tegi sa vist ei näinud :D
Oleks toon taga siis oleks veel maasikam :P
-Sander-
Registreerunud 16.03.13
Auto: vw
postitati 28.07.13 14:30 Tsiteeri
Tere,kas mäletad mis tootja kettad ja klotsid alla sul läksid.
karly
postitati 28.07.13 18:20 Tsiteeri
Küljes peaksid olema DELPHI tootja osad.
saidless
Registreerunud 21.12.11
Auto: Audi a4 2,5tdi V6 110kw 1999a. Audi a4 1,9 74kw 2004a
postitati 29.07.13 15:28 Tsiteeri
Kas sa oled autole aju ka leidnud või ei?
Viga on jagajas, jagajast on saanud segaja.
karly
postitati 29.07.13 15:57 Tsiteeri
Reedel tallinnast tuleb järgmine. Loodetavasti peaks sobima 1:1-le.
Loodame parimat ! :cool:
karly
postitati 06.08.13 08:30 Tsiteeri
Küles on nagu 4-jane kast..... Kas viiesel pole mitte kangi valikus 1,2,3 käigud ? Sellel on 2,3,4.
püstolett
postitati 06.08.13 12:06 Tsiteeri
Kui kuidagi muudmoodi kindlaks ei tee mis kast on siis vaata põhjaalla. Neljasel kastil on väline esidiffri kardaan, viiesel enam ei ole. Mis aasta auto sul on. 96 lõpp peaks ka juba viiese kastiga olema.
postitati 06.08.13 12:14 Tsiteeri
1-2-3 on neljasel kastil just, 5k kastil on 2-3-4.
karly
postitati 06.08.13 12:33 Tsiteeri
Masin ise on 97a ja põhjaalla pole veel vaadanud.
Kuuldavasti need 5-sed tiptronic kastid nõrgad.....
püstolett
postitati 07.08.13 14:18 Tsiteeri
Hooldamatus on selle nimi, miks nad halvad on.
karly
postitati 07.08.13 14:44 Tsiteeri
Seda ma olen ka kuulnud ja.
60k tagant kastis õli vahetada regulaarselt siis ei ole vast hullu kedagi. Eile just rääkisin ühe inimesega kes ütles et tal on A8 4.2q autom. samane 5 tip. ja selle 6a. jooksul mis ta seda autot omanud on ei ole kastiga midagi juhtunud ja üles et pole tagasi ka hoidnud.
Eks näis kaua see kestab :cool:
karly
postitati 18.08.13 09:35 Tsiteeri
Nii hetkel masin taas liikluses ja eile sai veel vahetatud esimene vasak välime pooltelje porikumm ja taga reduktori mõlemad pooltelje simmerid ja sai ka uus õli sisse 80W90 GL-5.
Hetkel teeb kõige rohkem muret see et 3-ndalt 4-ndale vahetates teeb õrna vibra ja jõnksu. Gaasi andes ja maha lastes teeks ka nagu jõnsku just neljanda käiguga.
Teised käigud vahetuvad ilusti sujuvalt. Ehk tahab lihtsalt õli vahetust või siis basic setting-ut saada.
karly
postitati 18.08.13 10:26 Tsiteeri
Air Contr.Valve (N212) Electrical Malfunction
Nüüd annab sellist viga ka. See võibolla tuleneb sellest et on veidike teine mootori aju peal kuna mootori töös häireid küll ei esine.
karly
postitati 18.08.13 10:35 Tsiteeri
Võtsin korra katted maha ja vaatasin et polegi sellel mootoril seda klappi mille viga näitab.....
KristjanE
Registreerunud 17.10.10
Auto: Audi 80 B3Q
postitati 19.08.13 17:30 Tsiteeri
Algselt postitas: karly
Pole klappi, pole probleemi :D Tore et sõitma said, kunagi aega leian, siis sooviks ka sõita :D
karly
postitati 22.08.13 08:34 Tsiteeri
Algselt postitas: KristjanE
Just :D:D
Aega läks aga asja sai :D
Mõni nv läbi hüppad siis vast saad ikka :D
karly
postitati 07.09.13 09:48 Tsiteeri
Üks sõbrapilt.
http://static2.fotoalbum.ee/fotoalbum/417/335/0104417848cc6eb.jpg
karly
postitati 13.09.13 18:32 Tsiteeri
Lisan mõningaid pilte juurde.
http://static2.fotoalbum.ee/fotoalbum/417/461/010448065558e4b.jpg
http://static2.fotoalbum.ee/fotoalbum/417/461/0104480659dcb36.jpg
http://static2.fotoalbum.ee/fotoalbum/417/461/01044806616e5cd.jpg
http://static2.fotoalbum.ee/fotoalbum/417/461/0104480665fd7f7.jpg
http://static2.fotoalbum.ee/fotoalbum/417/461/0104480667eac90.jpg
http://static2.fotoalbum.ee/fotoalbum/417/461/01044806715dde8.jpg
http://static2.fotoalbum.ee/fotoalbum/417/461/01044806750e4e7.jpg
Proovisin ka teisi viisusid alla.
http://static2.fotoalbum.ee/fotoalbum/417/461/0104480679608b0.jpg
postitati 13.09.13 18:37 Tsiteeri
No selle aja a8 (ja tegelikult ka järgmine) on ikka aegumatu välimusega masin, on olnud alati üks mu lemmikuid (loomulikult tuunimata) ja ka selle teema masin on väga viisakas. Edu!
karly
postitati 13.09.13 18:42 Tsiteeri
Algselt postitas: audi_a4_v6
Minu arust on ka originaal konditsioonis isend kõige ilusam. Seda masinat ma ei hakka küll tuunima. Ainult natukene toonklaasi ja velgede näol ja sellega vast see asi ka piirdub. Tänud !
postitati 13.09.13 18:55 Tsiteeri
Sellisele viiskakale vanakooli lipulaevale see velg küll ei sobi.
Hästi kukkunud pildid ka mainiks.
[PHP: 31.8% - SQL: 68.2%]
