Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Mootori tihendid A4 B5 1.8 92kw
Pealkiri: Mootori tihendid A4 B5 1.8 92kw (Vastuseid: 13 | Vaatamisi: 2272)
gt1993
Registreerunud 03.04.13
Auto: A4 1.8 1999
postitati 22.06.13 14:48 Tsiteeri
Tervist!
Sooviks uurida, kas kellelgi on kokkupuuteid klapikambrikaane tihendi vahetusega ning mootoriketipinguti tihendi vahetusega (metalltihend vist). Küsimus tulebki viimase kohta- nimelt on selle vahetus keeruline?
Samuti kui ketipinguti ei tööta, siis kett peaks olema lõtv?
Kolmas küsimus oles summuti sukkade kohta. Kas see "traadi mähis" käib kuidagi lahti võib peab tolle peale tõmbama, igatahes pole varem sellega mitte mingisugust kokkupuudet olnud.
postitati 22.06.13 14:57 Tsiteeri
Klapikambrikaane tihendi vahetus pole keerulist midagi, kaas maha, vanatihend minema, pinnad puhtaks, uus tihend asemele ja vist oli 20Nm jöuga kinni, osadel ka spetsiaalsed kaelusega poldid, mis ei lase üle pingutada.
Ketikaane tihendi kohta ei tea, pole kokkupuuteid olnud, kuid arvan, et samuti ei midagi keerulist.
Kui ketipinguti ei toimi, siis kett lötv töesti ja kolin taga.
Sukaga aga nii, et kui on läbi, siis löigatakse vana vahelt ära ja pannakse uus asemele.
gt1993
Auto: A4 1.8 1999
postitati 22.06.13 15:12 Tsiteeri
Mul to sukk on nagu väljaveninud, mingit ülesannet ta nagu ei täida. Arvatavasti sellepärast auto lörisebki. Aga kuidas uus pannakse? Pean mingi osa lahti võtma ja peale ajama või saab ilma lahtivõtmata.
Õhupuhasti all on mingi plekist äär summutipükste juures, vahel gaasi andes teeb to nagu häält. Nüüd täpselt ei saagi aru kas to plekk teeb seda või tuleb hääl keti probleemide tõttu. Minek tundub ka autol natukene kehvavõitu, kas keti olukord mõjutab kuidagi minekut või on see süüte tõttu? Nagu ma aru saan kett mõjutabki süüdet ehk siis kehv minek on seotud lõdva ketiga. Mõned korrad on esinenud ka halba käivitust. Nimelt pöörded käivitusmomendil jäävad 400-500 peale aga natuke puterdab ja hakkab normaalselt käima. Varuosad.ee vaatasin seal oli mingi ketipinguti 150 € aga googeldanud olen teemasi ja seal räägitakse mitukorda suurematest summadest. Siit tekibki omakorda uus küsimus. Kas keegi on vahetanud endal ketti ja pingutit ning kuidas oli hinnaga ja kuidas auto käitus enne vahetust.
T_
Registreerunud 23.10.07
Auto: VW Passat B8 4-mo
postitati 22.06.13 15:35 Tsiteeri
Sukk eiole ainult see võrk seal peal vaid koos selle elastse toruga seal sees. Võrku ei vahetata eraldi vaid nagu Kuits mainis lõigatakse vana vahelt ära ja uus asemele.Katkine sukk võib olla lörina põhjus.
gt1993
Auto: A4 1.8 1999
postitati 22.06.13 15:54 Tsiteeri
Okei to on siis keevitusteema jah?
postitati 22.06.13 18:02 Tsiteeri
Algselt postitas: gt1993
Just, keevitatakse uus asemele.
Kui kett on lötv pinguti pärast, siis piisab selle vahetusest, kuid kindlasti on olnud ka olukordi, kus pinguti surnud ja kett veninud, mis omakorda kulutab ajastuse hammasrattaid, seega pädevasse kohta ülevaatusele ja vajadusel remont.
gt1993
Auto: A4 1.8 1999
postitati 17.07.13 10:24 Tsiteeri
Summuti sukk sai ära vahetatud. Keevitus ja uus sukk läksid maksma 29 €. Samuti sai uuritud ketipinguti kohta. Pingutit ühe korra juba vahetatud. Ilmselt on klõbina viga hüdrotõukurites. Praegu otseselt ei võtagi midagi ette 4000 km pärast õlivahetus ning siis mootori pesu teha ja uus õli sisse - võibolla annab kõrin järele siis. Kui kellelgi on hüdrotõukuritega probleeme olnud siis kuulaks huviga, kuidas probleemist jagu saite.
yanekk
postitati 17.07.13 15:09 Tsiteeri
Mis imeasi see mootoripesu peaks olema, et mootori korda teeb, ennemini keerab selle veel rohkem peeti.
Best ET 12.08 :)
gt1993
Auto: A4 1.8 1999
postitati 17.07.13 19:42 Tsiteeri
No tuttav ütles, et õlikanalid võivad umbe ka joosta aga tõenäosus teooriaga ei viitsi tegelema hakata. Tema kogemuse põhjal ei ole midagi halba teinud aga eks see minu otsustada ole aastalõpul või kevadel. Mõningaid teemasid surfasin siin, siis ka oli juttu kusagil, et mootoripesu ja mingi kallim asi ajavad asja korda.
yanekk
postitati 18.07.13 04:39 Tsiteeri
"Jõudu tööle" mootoripesuga remontimisel.
Best ET 12.08 :)
gt1993
Auto: A4 1.8 1999
postitati 19.07.13 09:23 Tsiteeri
Surfasin veits netis, pigem ei siiski. Vahetan tihedamini õli jne. Lugesin miskit, et õlivõtturit tuleks puhastada. Aga muidu mis firma õlifiltreid te kasutate? Kas neid odavamaid või kallimaid?
postitati 19.07.13 12:41 Tsiteeri
Odavaid filterid kasutada on üpris totter otsus.
gt1993
Auto: A4 1.8 1999
postitati 20.07.13 07:53 Tsiteeri
No viimane õlivahetus läks 6€ -ne filter aga ilmselgelt see on odavam?
yanekk
postitati 20.07.13 08:18 Tsiteeri
Asi pole hinnas, vaid tootjas.
Mõni külapood võib ka sepiku eest kringli hinda küsida.
Best ET 12.08 :)
[PHP: 26.0% - SQL: 74.0%]
