Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - B3 tahmab lööb küünlad täis
Pealkiri: B3 tahmab lööb küünlad täis (Vastuseid: 2 | Vaatamisi: 1026)
audi5000
Registreerunud 04.07.04
Auto: ammustel aegadel oli
postitati 19.06.13 20:36 Tsiteeri
sai soetatud peaaegu seisnud,halvasti hooldatud, audi 80 1988a.B3 1,8 karpa.sai vahetatud kütte filter,õli, tühikäigupöörete regulaator.auto töötab ilusti ,aga ei salli linna sõitu ja foore., hakkab imelikku haisu sumbutajast ajama ,puterdama sureb välja jätab vahele tahmab küünlad,lööb küünlad täis tagant tahma välja.j.n.e.mida tuleks teha,kuidas ravida aidake
elu on ikka seiklus
postitati 19.06.13 21:27 Tsiteeri
küünlad, küünlajuhtmed, rootor jagajakaas esmalt.
audi5000
postitati 20.09.13 19:12 Tsiteeri
karburaatori alumine kummist muhv tihend oli katki nüüd auto nagu uus
elu on ikka seiklus
[PHP: 11.5% - SQL: 88.5%]
