Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - A8 rihmavahetus
Pealkiri: A8 rihmavahetus (Vastuseid: 12 | Vaatamisi: 1802)
avidmera
Registreerunud 23.03.13
Auto: Audi A8, 3,7L, 191KW
postitati 29.05.13 17:28 Tsiteeri
A8 rihmavahetus
Kellegil kogemusi A8 3,7L rihmavahetusega?
KAs rihma vahetades oleks mõistlik ka veepump vahetada?
Oskab keegi soovitada soodsat kohta neid töid teha ja mis see maksma võiks minna?
TÄUD
yanekk
postitati 29.05.13 17:30 Tsiteeri
Mis asi on A8 omanikule odav/soodne?
Best ET 12.08 :)
andrec
Registreerunud 07.10.06
Auto: A4 B6 R30 VR6 turbo
postitati 29.05.13 17:32 Tsiteeri
Veepump on hammasrihma liinis ja tuleks kindlasti vahetada!
avidmera
postitati 29.05.13 20:54 Tsiteeri
nii mõnigi ai võib olla
Algselt postitas: yanekk
Soodne........soodne on asi,mis on teistest pakkumistest odavam
jannomb
Registreerunud 21.10.10
Auto: Audi A8 3.7 d2, Audi A6 avant 4.2 V8
postitati 14.07.13 16:43 Tsiteeri
Ei hakanud uut teemat tegema, värskelt soetatud korraga kaks V8 mootoriga Audit ja mõlemal mõistlik rihm ära vahetada. Kuna pole varem Audidega kunagi kokku puutunud, siis uuriks millisest kohast oleks mõistlik rihmavahetuseks detaile ostma minna?
Tean, et juppe saab igast varuosapoest aga kohati võib sama tootja hinnavahe olla erinevates kohtades ca 20%, seega kus Audidele mõistlikumad hinnad oleks?
Hammasrihmast käib jutt!
yanekk
postitati 14.07.13 17:34 Tsiteeri
See hammasrihm ise on sellest kõige odavam asi, kui ainult seda kalliks pead.
Best ET 12.08 :)
andrec
postitati 14.07.13 18:30 Tsiteeri
Mõistlik on sinna pöörduda kes sul selle rihma ära ka vahetab ja teab mis seal töökäigus veel vaja on(tihendeid, polte jms asju), ning omab vastavaid rakiseid.
jannomb
postitati 14.07.13 19:34 Tsiteeri
Ma ei rääkinud, et kalliks pean ja pole mõtet teemat nii keeruliseks ajada. Tean ise, mis juppe vaja on ja mida mitte, lihtsalt ei näe mõtet osta kohe esimesest poest kõiki asju. Samuti ei näe põhjust kõikidest poodidest minna küsima eraldi, kui siin foorumis niigi teavad inimesed kus kohast mida tasub osta. Kõik teavad, et vaja läheb paras kogus igast vidinaid ja hinnad on parajad nendel osadel. Lihtsalt huvitab kus kohast tasuks esimesena uurida Audile juppe!
Nagu ennem mainisin, siis hinnad võivad erinevate poodide vahel kõikuda kõvasti ja nii rikas ma küll pole, et lähen ja ostan kinnisilmi esimesest poest kõik.
andrec
postitati 14.07.13 19:48 Tsiteeri
Enamus töökodades maksad sa tunnihinda selle arvelt juba rohkem kui sa oma varuosaga lähed.
Varuosi müüvad ju: Forss, Autoekspert, Teeme, Fixus jne
jannomb
postitati 14.07.13 20:33 Tsiteeri
Mul oli üks küsimus....ei ole mõtet hakkata rääkima täiesti kõrvalistel teemadel. Ma ei küsinud hammasrihma vahetamise kohta midagi. Mind ei huvita, et keegi kuskil rohkem küsib...äkki võiks mõelda, et mõni inimene vahetab ise rihma ära. Ma ei küsinud kes eestis müüb varuosi! Ma tean ise, mis firmad meil siinkandis on. Nagu juba mitmendat korda kirjutan, siis selle asemele, et ma kõik need poed ükshaaval läbi käin ja kulutan mõtetu aja selleks, lootsin pigem siit kiirema vastuse saada, millist firmat soovitatakse hinna poolest.
postitati 14.07.13 21:10 Tsiteeri
Mida jonni ;). Mida sul öigupoolest vaja, kas rihma müüvat varuosa firmat vöi rihma tootjat?
Andrec andis juba piisavalt infot, mida enam jaurata.
Isegi Bosch peaks hammasrihma komplekti pakkuma, muidu Gates vm tuntud tootja.
Kui aga ei suudeta detailide soetuses otsust langetada, siis ei kujuta ette vahetustgi, mida sooritatakse.
Nagu öeldud, siis töö teostaja vöiks pm ise vajalikud detailid organiseerida, köiges on vöimalik kompromiss leida.
Poode ei pea läbi kappama, kasuta kaupluse kontakte (tel, e-mail jne) ja saad ilma tömblemiseta selged sotid
quattromees
Registreerunud 07.01.03
postitati 14.07.13 21:16 Tsiteeri
Tee päring siia.
Varuosapäringute sooritamiseks ei pea sisse logima.
Päring edastatakse umbes 100 varuosamüüjale, nende hulgas maaletoojad, uute varuosade müüjad ja autolammutuskojad.
Sisseloginud kasutajatel on võimalik enda ja sõiduki andmed salvestada ning neid automaatselt päringule lisada.
link
Kokku rohkem, kui 1100 hobust
arsi
Registreerunud 09.02.06
postitati 15.07.13 06:06 Tsiteeri
Vastus läheb küll küsimusest mööda aga .....
Kui ise pole kunagi seda tööd teinud siis pole mõtet torkida . Oma hangitd osadega ei anna sulle ükski töökoda karantiid.
Rihmavahetus maksab koos tööga ca 900-1000 eurot. See sisaldab siis ka lamerihma ja rullikuid.
Kindlasti pole mõtet säästa sealjuures nuka ja vända simmerite pealt .
[PHP: 25.4% - SQL: 74.6%]
