Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Mis valuveljega on tegu?
Pealkiri: Mis valuveljega on tegu? (Vastuseid: 4 | Vaatamisi: 3085)
Marek1
Registreerunud 20.04.04
Auto: A6 Avant 2012 & VW Passat 2011
postitati 24.05.13 10:23 Tsiteeri
Huvitaks kas keegi teab, mis veljega on tegu:
http://www.auto24.ee/kasutatud/auto_pildid.php?id=1345684&view=30&cache_missing=1
Hakkas meeldima ja oleks soov endale soetada selline.
Ette tänades :D
postitati 24.05.13 10:46 Tsiteeri
Kui on originaalvelg, siis võid üritada siit kataloogist otsida:
http://www.wspitaly.com/download/Catalogue_WSP_2012_rev2_web.pdf
OEM 4F0601025D / PR-C5G
Marek1
postitati 24.05.13 11:15 Tsiteeri
Algselt postitas: prj
Vaatsin läbi aga üldiselt ei taha millegipärast replica tootjad seda velge pakkuda.
Marek1
postitati 24.05.13 20:38 Tsiteeri
Vot on hea koht ikka see foorum:D.
Tänud mehele nimega Meelo, kes saatis mulle ühe lingi ja kui kõik hästi läheb siis varsti autol uued jalavarjud all :cool:
[PHP: 48.5% - SQL: 51.5%]
