Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890 Eesti Audi Klubi foorum - Konditsioneeri radikas ning kõrge rõhk
Registreerunud 18.01.12
Auto: Audi A3 1997 1.6 74kw
postitati 17.05.13 13:11
Sai siin kliimahädadega pöördutud Autokliimasse Tähetornis. Algul öeldi, et vaja täita. Ok, täitsime ära. Peale seda lõi aga salongi vibra sisse.
Viisin auto tagasi sinna. Just helistasin, öeldi, et kliimaradikas umbes. Ei lase survet läbi ning sellest hakkab kogu kupatus vibreerima. Kas asi on
tõene, st on selline asi võimalik? Kas radikat annab kuidagi puhastada või vahetuslõbu?
Autoks Audi A3, 97 aasta, bensukas 1.6
Mihkel
postitati 17.05.13 15:58
Kahtlane küll. Kas jahutusventikad töötasid ja radikad on ilusti vabad mustusest. Või mõeldaksegi seda et radikas nii tugevalt sodi täis et ei jahuta.
Seda peaks puhastada saama siis.
Mihkel.
postitati 17.05.13 16:25
Mõlemad vendid muidu töötavad, üks vähekene kaheksas aga ei midagi hullu. Keema iseenest ei ole läinud. Vibra tekib kui tuled sõidust ja peatud(ehk
800 pöörde peal). Siis hakkab üks surin peale. Käisin autol järgi nüüd, küsisin, et mis värk on - rääkis sama juttu (seest umbes ning veidi kummis)
ning küsimuse peale, kas on ohutu kasutada, ütles, et maanteel on okei. Aga linnas mitte.
Tööajaks öeldi kaks päeva ning rahakest küsitakse 200. Ei teagi, kas siis visatakse likku kuhugi 2ks päevaks?
Mihkel
postitati 17.05.13 16:37
Algselt postitas: Mihkel.
[PHP: 28.2% - SQL: 71.8%]
