Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi 80 B4 Sidur
Pealkiri: Audi 80 B4 Sidur (Vastuseid: 3 | Vaatamisi: 1129)
arsine
Registreerunud 22.08.12
Auto: B4 2.0E
postitati 10.05.13 07:54 Tsiteeri
Audi 80 B4 Sidur
Selline probleem siis, et mu 2.0E 85kw masinal on sidur üsna raske ning võtab hästi ülevalt (ca 5cm pedaal alla ja lahtutab...). Ise olen juba ära harjunud aga enamik, kes masinaga sõitnud väidavad, et see on omadega õhtal samas kui mitmel tuttaval sama raske sidur kui mul. Jama on veel selles, et sidur ei lahuta ka vist korralikult, käigud 1-2 lähevad enamasti üsna raskelt sisse, kohati aga ilusti.
kaspara
Registreerunud 25.07.09
postitati 10.05.13 20:45 Tsiteeri
Endal oli sama teema, et võttis nagu ülevalt ja pedaal oli raske, sõitsin ka mingiaja sellega, aga lõpuks hakkas läbi libisema ja siis tuli vahetus ette võtta.
Infoks veel niipalju et sedaani ja universaali kettad erineva suurusega
arsine
Auto: B4 2.0E
postitati 13.05.13 17:58 Tsiteeri
Töö- või peasilindri jama ei pruugi olla? Või näiteks vana vedelik seal sees?
QUATTRO
Auto: 5,2 Cherokee 4x4
postitati 13.05.13 21:02 Tsiteeri
Selliste sümptomite puhul vajab sidur päris kindlasti uuendamist. Jätkates vahetad lisaks sidurikomplektile välja ka pedaali või peasilindri, mis lihtsalt purunevad ülekoormuse tõttu.
Targem annab järele.
[PHP: 28.3% - SQL: 71.7%]
