Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Küsimus valuvelgede kohta
Pealkiri: Küsimus valuvelgede kohta (Vastuseid: 2 | Vaatamisi: 964)
ehanurm
Registreerunud 22.10.10
Auto: Volvo
postitati 06.05.13 01:11 Tsiteeri
Tekkis üks küsimus velgede peal olevate markeeringute kohta. Valuvelgede seespool on pressitud vastav markeering(all pildil), küsimus et mida see täpsemalt tähendab?
http://www.upload.ee/image/3289731/IMAG0181.jpg
Ja üks küsimus veel, et velje peale on pressitud ET 18. Kas on võimalik, et see on tollides? Sest ET 18 iseenesest oleks väga väike, kui tollides on, siis oleks 45,7 cm umbes. Ja kuidas mõõta velje keskosa?
kelluke
Registreerunud 01.08.07
Auto: C5 1.9 , 5000 C2
postitati 06.05.13 02:52 Tsiteeri
JWL on kvaliteedi standard,ehk tegu on korraliku tootega.ET-18 peaks olema ikka mm.See on velje keskkoha ja kinnitustsapinna vaheline kaugus.
Keskosa mõõta ei ole ju väga keeruline,kui rehvi peal ei ole,mõõdad laiuse ära ja jagad pooleks.
postitati 06.05.13 20:26 Tsiteeri
Loe SEE teema läbi. Ehk siis otsingut kasutades oleksid info kiiremini leidnud. :)
[PHP: 22.4% - SQL: 77.6%]
