Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - B2-e ja B3-e generaator
Pealkiri: B2-e ja B3-e generaator (Vastuseid: 2 | Vaatamisi: 1492)
TaSa
Registreerunud 20.01.12
Auto: Audi 100 C4,Audi A4 b5
postitati 04.05.13 17:53 Tsiteeri
Mure järgmine.
Audi 80 B2-l on geneka küljes pistik kus on kaks jämedat juhet ja üks peenike(ergutus),B3-e generaatoril käib üks jäme juhe ja ergutus.Asi selles,et enda B2-l on generaator läbi,aga b3 oma kodus olemas,nimelt kas ma pean siis need kaks jämedat kokku panema,või jääb üks lahti,sest hoovis on üks 90 millel on üks juhe lihtsalt lahti.
Tegelane5
Registreerunud 26.09.05
postitati 08.05.13 11:20 Tsiteeri
Peaks kokku panema.
TaSa
postitati 09.05.13 18:36 Tsiteeri
Panin kokku jah,toimetab ilusti.
[PHP: 47.0% - SQL: 53.0%]
