Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - A4 käigukastis või Mootoris kerge lõtk
Pealkiri: A4 käigukastis või Mootoris kerge lõtk (Vastuseid: 11 | Vaatamisi: 1619)
hull22
Registreerunud 10.08.11
Auto: A6 C7
postitati 06.04.13 18:21 Tsiteeri
Autoks A4, 2002 aasta, 2.0 bensiin, 96kw.
Alustaks siis sellest et tegemist multitronic kastiga. Imelikuna tundub see, et koha pealt ära minnes teeb auto enne kerge nagu jõnksu ja siis hakkab normaalselt sõitma. Külma mootiriga teeb seda rohkem, aga teeb ka sooja mootoriga, täpselt selline tunne nagu ei leiaks algul õiget käiku või oleks kuskil mingi lõtk. 3 korda kahe aasta jooksul on juhtund ka sellist asja, et tagurdamise pealt käib nagu kolks ja siis hakkab tagurpidi liikuma, aga see sellisel juhul kui drive pealt jään seisma, panen tagurpidi käigu sisse ja vajutan kohe gaasi. Kui kohe gaasi ei vajuta ja lasen autol ise veereda siis on normaalne. Sellises olukorras piisab vaid kergest gaasi vajutamisest. Ei oska nagu arvata millest seda probleemi otsima hakata. Vb on kellelgi sama probleem olnud!
postitati 06.04.13 19:01 Tsiteeri
Tundub, et tegu rohkem nagu omaniku poolse rabistamisega.
Käik sisse ja koheselt pedaali, sedasi saab vast iga automaatkasti puhul jönksatusi/paukumist tunda ja kuulda.
taavi9
Registreerunud 09.01.06
Auto: A6 C6 avant 3,0TDI S-line 09a.
postitati 06.04.13 19:30 Tsiteeri
Kas kastiõli on normis?
hull22
Auto: A6 C7
postitati 07.04.13 14:37 Tsiteeri
Päris nii see asi ka ei ole. Vast tõesti saab. Olen sõitnud ka teiste autodega millega sellist asja ei ole olnud. proovitud on isegi pikemalt algul veereda lasta kuid see ei aita!
hull22
Auto: A6 C7
postitati 07.04.13 14:41 Tsiteeri
Algselt postitas: taavi9
Usun et ei ole sellest kuna pärat õli vahetust ei ole midagi muutunud! Hetkel just ongi plaanis lasta kastil õli ära vahetada.
postitati 07.04.13 14:47 Tsiteeri
Neid multitronicuid tuleb peale õli vahetust uuesti sõitma õpetada arvutiga. Pakun, et see on sulle uudis. Kulunud kastid jõnksutavad samuti ja siis aitab ainult suht kallis remont.
hull22
Auto: A6 C7
postitati 07.04.13 14:57 Tsiteeri
Miskit olen kuulnud küll kusagilt. Mismoodi see sõitma õpetamine käib seda ei tea. kuulnud olen mingist softi uuendamisest vms. Kui kalliks see remont minna võib kui kulnud? 214 000 oli sõitnud kui saksast tuli. Käigukasti õli sai kohe vahetatud. hetkel on ees 255 000 ja vahetama lähen siis juba 3 kord. ehk siis selle 40 000 vahel on korra õli vahetatud. usun et õli peaks olema õigeaegselt vahetatud. Pigem isegi varem kui peaks! Aga no kindlam on varem vahetada kui pärast uut kasti osta.
postitati 08.04.13 08:18 Tsiteeri
Maakeeli öeldes on see õpetamine edasi-tagasi sõitmine pidurdamine jne oma kümmekond korda, kuni adapt. OK öeldakse arvuti poolt. Olen mõnel autol seda teinud ja tulemus on olnud tuntav. Kui kett või miski muu kulunud, siis aitab siiski ainult remont. Kui asja väga hulluks ei lase, siis u. 1000eur. on kuuldavasti remont läinud inimestel. Loomulikult sõltub see number väga paljudest asjadest.
Edu.
EvilS
Registreerunud 19.06.12
postitati 08.04.13 09:15 Tsiteeri
Mul pole praegu küll raamatut käepärast, aga minu teada oli 2006. aasta A4 käsiraamatus kirjas, et peale käigu (nii D kui R) sisse panekut tuleb hetk oodata, enne kui gaasi anda. Olen ohuolukorras isegi oma autol liiga kiiresti D->R vahetuse teinud ja siis kohe kergelt gaasi andnud, et auto nina ristmikul kurvi lõiganud rekka eest päästa... ning siis hakkas ebameeldivalt tugeva jõnksuga liikuma (pääsesin!). Kui rahulikult tegutseda, siis probleemi pole.
Olen veidi vaadanud tehnilisi jooniseid ka Multitronic kasti kohta - seal on kaks eraldi sidurikomplekti edasi- ja tagasi liikumise jaoks. Selleks, et D pealt R peale vahetada, peab kast Drive siduri pealt rõhu maha võtma, stabiliseeruma ning siis hakkab alles Reverse käigu sidurile rõhku andma. Kui liiga kiiresti D->R liigutus teha käigukangiga, siis antakse R sidurile rõhk enne peale, kui D siduri pealt jõud ära kaob. Käigukang on ühendatud hüdraulika klappidega otseselt, mitte elektrooniliselt läbi juhtaju. Pakun seda, et liiga kiirel tegutsemisel on mingi aeg mõlemad sidurid osaliselt rakendatud ja seega liiga varane gaasi andmine (üle)koormab kasti sisemiselt ja seega kast ei suuda normaalselt kohalt võttu teha siduri libistamisega.
Seega tuleks ikka kastile anda 1-2 sekundit aega, enne kui gaasi anda.
Parandage mind, kui eksin.
[edit] Lisan veel seda, et mul oli autol ostu järgselt ka üliväike jõnks kohalt võttes, ise sain sellest aru alles peale 10k läbimist. Multitronicu õli oli regulaarselt vahetatud 60k tagant, viimasest vahetusest oli 30k. Lasin Flamekos õlivahetuse teha (~90€) ja sellega läks kohaltvõtt täiesti sujuvaks, kui ise mitte rabistada nagu juhend käsib. Tänaseks 20k läbitud peale õlivahetust ja olukord on endiselt täitsa korras.
hull22
Auto: A6 C7
postitati 08.04.13 14:45 Tsiteeri
no loodetavasti remontima ei pea. lähen vahetan õli ära ja lasen neil selle sõitma õpetamisega tegeleda. Vb oskab keegi soovitada tartus mõnda head kohta kus kastis õli vahetada. omal on plaanis transremi minna.
ets30
Registreerunud 18.08.08
postitati 10.04.13 12:18 Tsiteeri
Kas õlivahetusega lahenes probleem või on lõtk jätkuvalt alles?
hull22
Auto: A6 C7
postitati 10.04.13 14:40 Tsiteeri
Pole veel jõudnud õli vahetada. Ei viibi hetkel Eestis! Annan teada kui õli vahetatud.
[PHP: 21.2% - SQL: 78.8%]
