Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - KORRAS: 2.4 V6 ketipinguti tihendi vahetus
Pealkiri: KORRAS: 2.4 V6 ketipinguti tihendi vahetus (Vastuseid: 1 | Vaatamisi: 1136)
scale
Registreerunud 07.02.12
Auto: Audi A4 Avant´98
postitati 30.03.13 16:52 Tsiteeri
Paluks abi siis sellise küsimusega, et kes, kas ja kus on on vahetanud ketipinguti tihendit ja palju see ka maksma on läinud? Või siis on mõni hakkaja mees, kes tahaks ette võtta hoopis? Alul arvasin, et leke kambrikaanest, ( mis oli ka tõsi ) seega need vahetatud. Endiselt lekib siis parema (salongi poolt vaadatuna) pinguti juurest. Asukohaks võiks olla Tallinn.
andrec
Registreerunud 07.10.06
Auto: A4 B6 R30 VR6 turbo
postitati 30.03.13 17:40 Tsiteeri
Saatsin U2U!
[PHP: 22.4% - SQL: 77.6%]
