Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890 Eesti Audi Klubi foorum - Mure bybassi vahetamisega A4jal
Registreerunud 31.10.05
Auto: audi s6 4,2 audi 80 2,0 audi a4 1,8T
postitati 16.03.13 12:30
Probleem siis selline, et sai ostetud audi TT bybass 99+a audi a4 1,8t . Vahetamise käigus selgus et olemasoleval bybassil polegi ühte toru. Soovikski
teada et mis sinna peaks käima?
Registreerunud 25.09.02
postitati 16.03.13 12:39
Otsi bypassi pisut alt poolt, see mis sul nö vana bypass on, on tegelikult karterituulutuse klapp.
www.eksperthooldus.ee
ragnara
Registreerunud 23.03.12
Auto: A4 b9 2.0TDI Quattro
postitati 16.03.13 12:46
Vanale bypassile saad ligi põhjaalt. Võta taskulamp kaasa ja roni alla, peaksid leidma. Kunde pool paremal ees on ta. 99aastal ja aeb mootorikoodiga
siis. Muidu olen näinud ka kus ta ongi otse õhulõdviku küljes, seda viisi on ta vist vanematel 1.8t masinatel.
[PHP: 18.1% - SQL: 81.9%]
