Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Õlirõhu anduri asukoht.
Pealkiri: Õlirõhu anduri asukoht. (Vastuseid: 3 | Vaatamisi: 922)
Greger
Registreerunud 07.06.09
Auto: A8 D2 4.2 Quattro
postitati 12.03.13 07:54 Tsiteeri
Tere. Selline mure, et oleks vahja teada kus asub Audi A8 D2 4.2 l ABZ 220 kw mootoril õlirõhu andur ?
Greger
postitati 12.03.13 16:31 Tsiteeri
Võib teema kustutada.
rix30
Registreerunud 19.04.09
Auto: Audi S3 1,8T 8L
postitati 13.03.13 00:33 Tsiteeri
Algselt postitas: Greger
Miks kustutada, kui leidsid anna teada? Hiljem teistelegi hea teada.
Adolf Hitler!
aixx
Registreerunud 21.03.05
postitati 13.03.13 06:32 Tsiteeri
Seda on lihtsalt nii lihtne leida :) Õlirõhuandur on sellel mootoril õlijahutus-filtreerimisekopsiku peal kohe väljalaske kolde all. A8-l see muidugi ilma kõvasti plastikut eemaldamata välja ei paista.
Siin on üks juhend ka, kuidas õlifiltrikopsiku juures olevat tüüpviga remontida
http://www.audipages.com/Tech_Articles/enginemechanical/oilcoolerremovalreinstall.html
[PHP: 20.5% - SQL: 79.5%]
