| Tsitaat: | Algselt postitas: Arkady1
no tagumine ots on nagu alla pool võrreldes esimesega kui paar nädalat seisab kui 3-4 päeva seisab ei muutu midagi |
Pole küll oma silmaga näinud, konkreetsel autol, seda esisilla ja tagasilla vajumise erinevust aga enda endine D3 ka pidevalt seisis pikemaid aegu,
siis täiesti normaalne nähtus, kuna auto on sel juhul sleep mode`s.
Sleep mode
After 60 seconds in after-run mode without
receiving an input signal, the system goes
into the energy-saving sleep mode. The system
leaves sleep mode briefly after 2, 5 and
10 hours to check the height level again.
Extreme low level
Extreme low level (65 mm or more below normal
level) is shown by the low level indicator
lamp and the warning lamp flashing. Extreme low level can occur after the vehicle has been at a standstill for a very long period.
I hope that I will soon forget the Audi Quattro. Until I do, I shall continue to worship that b.tch goddess Success at the expense of friends, family,
honesty and decency - anything to be in a position to have one. -Four Wheeler Magazine 1982
