Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi 80 ei taha käivituda ilma kaasi andmata.
Pealkiri: Audi 80 ei taha käivituda ilma kaasi andmata. (Vastuseid: 4 | Vaatamisi: 954)
ilary007
Registreerunud 23.11.10
postitati 28.02.13 20:18 Tsiteeri
Tere!Otsisin siin teemades ringi aga ei leidnud keda kellel oleks selline viga,nagu mul.Äkki saan siit abi:D
Lugu siis selline,et täna käis naine sõitmas ja suretas auto parkimisel välja ja enam ta käima ei saanud.Läksin siis ise.Tõesti käima ei lähe ei luba ka aga kui andsin nats kaasi siis läheb kohe ja proovisin nii läheb iga korraga kui kaasi puutuda.Aga kui kaasi ei anna siis lihtsalt ei lähe.Kui käima sain siis järsult kaasi andes poob ka algul hingest kinni.Milles võib asi olla?
Tegu siis b4 ga 2.o 85 kw
Tänud juba ette ära.
ülks
Registreerunud 04.12.04
postitati 28.02.13 20:51 Tsiteeri
Rihmamärgid paigas? Käib ilusti ja ilma kõrvaliste helideta?
www.teemetünni.ee
ilary007
postitati 28.02.13 21:21 Tsiteeri
Jh käib küll ilusti aga süüde võib küll nats hiline olla.kas sellest võib ka siis järsku selline jama tulla ennem läks ju ilusti.
ülks
postitati 01.03.13 05:31 Tsiteeri
Pigem mõtlesin, et tõstis hammasrihma ühe hamba võrra paigast ära.
www.teemetünni.ee
ilary007
postitati 01.03.13 15:45 Tsiteeri
Ei kõrval helisid ei ole jh.
[PHP: 22.1% - SQL: 77.9%]
