Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Käigukastide ülekanded
Pealkiri: Käigukastide ülekanded (Vastuseid: 1 | Vaatamisi: 1109)
Rain573
Registreerunud 17.09.05
postitati 25.02.13 11:59 Tsiteeri
Tehke lollile selgeks kuidas arusaada kasti ülekannatest :D :D
Olen leidnud et 01A kaste on 35/9, 37/9 ja 41/9 ülekannetega ja 01E kaste on 37/9. Kõigekiirem ülekanne neist on siis 35/9 v? 01E kastidel on kuuenda käigu ülekanded 27/37, 26/38 või 23/41. Milline neist siis kõigekiirem on? Või mis tähtedega kast lubab kõigesuuremat kiirust 7000rpm i juures?
postitati 25.02.13 15:55 Tsiteeri
Eespool veetava, tagapool vedava hammaka hammaste arv. Võrdse arvu korral käivad sama kiirelt. Mida vähem on veetaval ja rohkem vedaval, seda kiiremini veetav pöörleb, kuna kõik tema hambad peavad vedava omade vahelt läbi käima ja siis vastavalt mõnest veel. Antud juhul on kõige kiirem peaülekanne tõesti 37/9 ja kõige kiirem 6. käik 23/41.
Kiireim peaks olema DQT tähisega V6 diislikast.
[PHP: 24.0% - SQL: 76.0%]
