Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 100 85kw sureb soojalt
Pealkiri: 100 85kw sureb soojalt (Vastuseid: 1 | Vaatamisi: 632)
zoom07
Registreerunud 05.02.13
postitati 05.02.13 21:43 Tsiteeri
Tere
Mure selline, et Audi 100 C4 85kW bens 1993a. sureb millegi pärast välja kohe kui mootor jõuab 90C juurde. Külmalt muret ei ole ja käivitub ilusti.
Küünaldel säde olemas nii soojalt, kui külmalt, vahetatud jagaja kaas rootor ja kütusepump ka juba kuid muutusi ei paista, ikka sama tsenaarium.
Ei ole kusagil diagnosti ka lähedal, äärmisel juhul peaks siis paela otsas vedama hakkama.
Olen lugenud siit veel et viga võiks olla kommutaatoris või mingis halli anduris, kumba mõtekam oleks järgmisena iseseisvalt vahetama hakata, või oleks veel mingeid ideid?
zoom07
postitati 06.02.13 14:49 Tsiteeri
Kas üks võimalus võiks ka lambdas olla, kuna enne sellist välja suremise protsessi algust ca. 200km tagasi vahetati teeninduses lambda ka miski b osa vastu?
[PHP: 21.6% - SQL: 78.4%]
