Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - teema lõpetatud
Pealkiri: teema lõpetatud (Vastuseid: 24 | Vaatamisi: 1977)
kaupokommer
Registreerunud 14.11.12
Auto: audi 90 coupe 2,3 automaat audi b4 avant tdi audi 90 stayl
postitati 29.01.13 19:36 Tsiteeri
teema lõpetatud
Tere kas keegi on kokku sobitanud audi coupe tayp 85 ja vw passat b2 synkro, ühe sõnaga coupele passat b2 synkro sillad alla:)
postitati 29.01.13 19:38 Tsiteeri
Tagasild ju teistsuguse ehitusega.
kaupokommer
postitati 29.01.13 19:43 Tsiteeri
Algselt postitas: KeveN
ja kuid huvi kas keegi on kokku puutunud sellega
postitati 29.01.13 19:47 Tsiteeri
Milleks sellist jama teha, b3 quattroid saada küllaga, tolle oma lääb b2Q 1:1 alla
kaupokommer
postitati 29.01.13 19:52 Tsiteeri
Kas b2 silda poleks kergem panna, selle ehitus ju lihtsam, kaks puksi ja tifri padi, ei peaks põhja vahetama, ega amorte muutma.:)
postitati 29.01.13 20:01 Tsiteeri
Siin hakkab rolli mängima kui lai see sild on. Et amorid ülemiste puntide vahelt mõõdetud pikkus on ehk b2 passsatil laiem. Kui sa selle mõõdu sebid, siis homseks saaks ma sulle oma b2 Q oma öelda.
postitati 29.01.13 20:17 Tsiteeri
Passati tagatelg ainult 2 mm laiem, autodatas oli olemas ikka.
postitati 29.01.13 20:33 Tsiteeri
B2 Passati sillad: Pilt
B2 80 quattro: esimene pool, teine pool
kaupokommer
postitati 30.01.13 06:31 Tsiteeri
Audi tagasilla amordid on nagu esimesed, passatil samasugused nagu tavalisel audil., ei peaks põhja ja amordi kohti muutma. Huvi on kas keegi on kokku puutunud selle teemaga, äki kellegil on linke saata.:)
mokits
Registreerunud 22.12.06
postitati 30.01.13 06:37 Tsiteeri
Sisuliselt Tahad teha monovedurist täisveduse? Kui jah, siis pead ikka põhja ka ju ära vahetama. Minumeelest oli kasutaja inx, kel selline projekt millalgi käsil oli ja siin klubis raudselt kuskil see olemas.
postitati 30.01.13 12:06 Tsiteeri
No asi seisnebki selles et ta soovib passati tagasilda külge monteerida, et siis ei peaks põhja ehk vahetama.
kaupokommer
postitati 30.01.13 14:09 Tsiteeri
Mida vähem tööd seda lihtsam seda teha on asja mõtte.:)
tarmo
Registreerunud 05.01.03
postitati 30.01.13 14:36 Tsiteeri
Algselt postitas: kaupokommer
Müü esivedune maha ja osta nelivedune auto. Enam lihtsam ei saakski ümberehitus olla.
kaupokommer
postitati 30.01.13 16:34 Tsiteeri
Kah võimalus. Ma rohkem uurin kas keegi on teinud säärast masinat, et teada saada kas on võimalik. Guuglist ei leia midagi selle kohta äki siit saab mingeid linke :)
postitati 30.01.13 17:42 Tsiteeri
On sul siuke tagasild võimalik saada odavalt? Kui jah, siis kruti ta amortides külge, kui kannatab ja vaata mis ta endast kujutab.
Kiil
Registreerunud 03.02.03
Auto: Allroad C5
postitati 30.01.13 18:08 Tsiteeri
Kas Mosse tagasilda poleks lihtsam alla panna? :D
postitati 30.01.13 18:14 Tsiteeri
Kardaanitunneli pead nagunii ümber ehitama ju, seda pm praegu ei olegi olemas.
kaupokommer
postitati 30.01.13 18:21 Tsiteeri
Jah tunneli peaks küll vahetama aga to ikka kergem kui terve põhja vahetus.
kaupokommer
postitati 30.01.13 18:24 Tsiteeri
Algselt postitas: Kiil
Ja jah pole veel sellele tulnud, aitäh
postitati 30.01.13 18:46 Tsiteeri
Tervet tagaotsa ei pea vahetama, tagasilla juurest ainult.
mokits
postitati 30.01.13 22:02 Tsiteeri
AC- sse võiks ka like nupp tulla :D
Aga teemasse, sellest esivedusest neliku tegemine ei ole kahjuks väga lihtne. Selleks et ikka asi oleks hea, peaks asja nii tegema nagu see mõeldud on, mitte asja lahendama " mosse tagasillaga". Siin turu foorumis oli q- kuubiku kere 800€-ga müüa, laod sinna kraami peale ja olemas ongi. :P Edukat ehitamist.
postitati 30.01.13 22:42 Tsiteeri
Mokits see 800€ maksev kere on samamoodi ümberlõigatud esiveduse kere :)
kaupokommer
postitati 31.01.13 06:29 Tsiteeri
Plaan pole ehitada, aga soov on teada kas keegi on säärast asja teinud.Plaan osta b3 quattro kevadel kui tööd soomes saab.Huvi ainult, sest kuskil säärast teemat pole näinud,et keegi oleks säärast teinud.aitäh
postitati 31.01.13 07:13 Tsiteeri
Küll sa siis juba 4.2 A8 ostad. Sellel on toimiv tagasild standartvarustuses.
kaupokommer
postitati 31.01.13 07:22 Tsiteeri
Algselt postitas: Black
Küll sa siis juba 4.2 A8 ostad. Sellel on toimiv tagasild standartvarustuses. [/quote
Aitäh pakumast nõu eest, mis kuhugi ei vii.:cool:
[PHP: 28.8% - SQL: 71.2%]
