Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi A6 C4 2.0 74kw Kütusekulu
Pealkiri: Audi A6 C4 2.0 74kw Kütusekulu (Vastuseid: 27 | Vaatamisi: 3181)
miilits6
Registreerunud 03.09.12
postitati 12.01.13 16:36 Tsiteeri
Tervist,
Probleem kütusekulus. Aru ei saa miks aga pill võtab 15l/100 julgelt kui mitte rohkem ja seda ka maanteel rahulikult sõites. Saan aru, et praegu talv jne aga olgem ausad see on natuke liig. Tegin diagnosti ja sealt arvuti ütles, et toores jääb peale aga mis selle põhjustab, et see peale jääb. Äkki ikkagi keegi oskab aidata. Loodan, et ei hakata ajama, et see normaalne ja sõida rahulikumalt ja talv on ja lase mootor soojaks või vaheta termostaat ära või pumbake rehvid täis vms. Sellised asjad on kõik üle käidud.
Ette tänades.
miilits6
postitati 28.01.13 19:30 Tsiteeri
Keegi ei oska aidata?? Möötsin nüüd nimme küttekulu. Maanteel sõites sooja mootoriga sain 15,3l/100km. Ei usu, et see päris normaalne un. Äkki ikka mõni nupu vend oskab aidata.
postitati 28.01.13 19:47 Tsiteeri
No kui diagnostitud "toores" peale jääb, siis pole ju mingi ime, et kulu selline on.
Tuleb leida pöhjus, mis antud "toores" toimima jääb.
yanekk
postitati 28.01.13 19:49 Tsiteeri
Algselt postitas: miilits6
Kui enda asukohast pole sõnagi, siis ei vaevu eriti keegi midagi soovitama.
Ja ka auto kohta andmeid napib.
hunt_1
Registreerunud 13.03.08
Auto: c4 2,0 103kw
postitati 28.01.13 20:18 Tsiteeri
Kas tüüpviga monopritse padi on kontrollitud?
QUATTRO
Auto: 5,2 Cherokee 4x4
postitati 28.01.13 20:22 Tsiteeri
Kirjuta parem see veakood mingi normaalse ühikuna siia. Sooja õhku saab kogu pritseüritus?
Pole veel suutnud sellist koodi näha, "toores jääb peale".
miilits6
postitati 30.01.13 16:05 Tsiteeri
Algselt postitas: QUATTRO
Nüüd siis nägid. Aru ma ei või sellistest vendadest kes nokivad siin foorumis. Kui sa ei oska aidata siis ole mees ja ära mõnita. Kõik saavad ilusti aru mida see "toores jääb peale" tähenbab, vb jah on mingeid erinevaid termineid vms seal, et selle järgi saab õelda vea aga minule õeldigi nii ja ma kirj teile selle edasi. Sooja õhu kohta ei oska midagi õelda, üritan lähiajal vaadata.
miilits6
postitati 30.01.13 16:06 Tsiteeri
Algselt postitas: hunt_1
Sellest tüüpveast ma ei tea midagi, äkki räägid lähemalt sellest.
ash
Registreerunud 28.10.02
Auto: typ85 CQ '87
postitati 30.01.13 16:15 Tsiteeri
Sinu probleemi kallal ei mõnitanud mitte keegi, küsiti veakoodi (numbreid) mitte "toores jääb peale" seda ei näita diagnost sõnaotses mõttes. Mõistad? Kui ütled KOODI siis oskavad inimesed Sind ilmselt rohkem aidata..
yanekk
postitati 30.01.13 16:29 Tsiteeri
Algselt postitas: ash
See vist pea poolte uute kasutajate probleem, elementaarsest viisakusest pole lõhnagi.
miilits6
postitati 30.01.13 16:36 Tsiteeri
Algselt postitas: yanekk
Vabandan. Jah ma sähvasin, aga ma leian, et quattro oleks saand kh ennast viisakamalt väljendada.
pampkuri
Registreerunud 08.03.04
postitati 30.01.13 17:19 Tsiteeri
Kui oled nii õrnahingeline et see mis Q sulle kirjutas haiget tegi siis pöördu sinna sealt kindlasti saab abi : http://naistekas.delfi.ee/ Vabalt võib seda postitust mõnitusena võtta
miilits6
postitati 30.01.13 18:37 Tsiteeri
Mai saa teist aru, enamus siin foorumis on väga normaalsed inimesed. Kui Sina ei ole ss sa ei pea seda teada andma, jäta oma kriitika endale. Alati on olemas teisi varjante aga kui see ongi teie point foorumi külastamiseks ss kes olen mina, et teid keelata. Tuld.
raineys
Registreerunud 03.05.11
Auto: Saab 9-5 2.3t
postitati 30.01.13 18:53 Tsiteeri
Noh jah. Ma püüan olla neutraalne. See "toores jääb peale" ei ütle mulle mitte kui midagi. Küllap leidub teisigi, kes sellest aru ei saa. Ma eeldan, et see on midagi sellist, et külma mootoriga on pöörded kõrgemal?
Kõigepealt võiks ikkagi oma käitumist vaadata ja siis teiste käitumist kommenteerida.
miilits6
postitati 31.01.13 10:44 Tsiteeri
Imelikuks teebki asja see, et külmalt pill eeli eeli käib(ca 500 rpm) ja soojalt on umbes 800 pööret. Möötsin heitgaase ja HC oli umbes 70.
QUATTRO
postitati 31.01.13 12:13 Tsiteeri
Nojah, proovi siis Sinusugust aidata.
Kuna sellised asjad ei juhtu reeglina ise, töötan sel alal ja pean igapäev sõna otseses mõttes inimestel näppe sahtlivahele peksma, et saada teada mida nad enne on teinud kui oma auto remonti toovad või mis tingimustel probleemid algasid.
80% inimestest ei saa, ega hakkagi aru saama kui oluline on TÄPNE info. Kes kardab ennast lolliks teha, et ise näppis, kes peab mind ülbeks, et ma julgesin üldse miskit küsida jne.
Kui Sa omad juba heitgaasi analüsaatorit, siis on järelikuklt tegu juba keksmisest kõvema remondikojaga.
Niikaua kuniks ei tule ühtki täpsustavat vastust, soovin edu.
pampkuri
postitati 31.01.13 15:03 Tsiteeri
... aga järjepidev, sulle öeldi väga korrekselt ütle veakood.
miilits6
postitati 01.02.13 22:00 Tsiteeri
Algselt postitas: pampkuri
Mai tea vea koodi, mul pole endal deagnosti. Lasin deagnosti teha ja ei ole veakoodi õelnud kuna pole saand uuesti teha deagnosti. Oletame, et ma pole deagnosti teind ja hakkame viga otsima. Kust me alustaks. Stroboga süüte paika panekust?? Proovisin, süüde peaks olema ca 10 kraadi (autodata järgi) aga 10 kraadiga hooratta kriipsu järgi see pill lihtsalt ei käigi. Teiseks olen käind läbi vaakum voolikud, nendes pole viga leidnud. Mehaaniliselt on mootor korras. Ei tiksu, ei suitse, ei söö õli ja silindri surved olid kh 10 bari ligi. Mõõtsin tembi andurite takistust, takistus väheneb(olemas teine andur kh ja sellel vähenes samamoodi). Kütuse torud üle käidud, leket pole leidnud.
miilits6
postitati 01.02.13 22:21 Tsiteeri
Räägiks tühikäigu mootorist. Kas tühikäigu mootor mitte ei tohiks lasta pillil alla norm. pöörete tuksuda ja kas mitte tühikäigu mootor ei peaks külmalt pööret juures hoidma?
postitati 02.02.13 09:03 Tsiteeri
Tühikäigu mootor/klapp hoiab töesti ettenähtud piire, kuid köigil pole siiski nii, et külma mootori korral on pöörded körgemad, kui sooja mootori korral, see tuleb ka vist auto margist.
Minu näide nt. Opel ja Audi, Audi töesti hoiab külma mootoriga veidi aega pöördeid körgemal, kuid Opel sedasi ei teinud, auto oli mootori poolelt 99% töökorras, peale selle arvan, et kui praegu lähen vötan Audi tühikäigu klapilt pistiku tagant ära, siis läheb auto ka käima ja jääb käima, see on ainult arvamus, mida praktiseerida ei kavatse.
Selle asemel, et oma pead vaevata erinevate prognoosidega, mis ei anna tulemust, tee enesele teene ja vii auto pädevatele meestele hooldada.
QUATTRO
postitati 02.02.13 10:17 Tsiteeri
Proovi nüüd see asi ära restartida aku - klemmi eemaldamisega ca 10 minutit.
Siis aja tester lambda signaali otsale. Käivita mootor ja ära gaasi anna kui vähegi võimalik. Lase käia ja jälgi samal ajal lambda signaali, kas miskit toimub. Kui toimub, siis lase mootor kindlasti 80 kraadini (ära vahepeal gaasi torgi) ja säti süüde stroboga 5 kraadi enne ÜSS. Kui asi on justkui ok, siis sureta mootor välja lase seista ca 15 minutit ja lase uuesti käima(gaasi ei puutu) ja lased käia ca 15 minutit. Võiks ok olla.
Need temperatuuriandurid saavad lekkida ka korpusest, seega klemmidevaheline takistusemõõtmine ei anna alati tulemust. Proovi mõõta anduri kumbagi klemmi ka kere/mootori suhtes. Kui tekib mingisugunegi takistus, kuulub andur vahetamisele.
Need monopritsed suudavad ennast vahel lihtsalt lolliks käia. Lambdaanduri korrektne toimimine on selle pritssetüübi puhul A&O.
Väljalaske kollektor ei tohi lekkida , summuti peab olema korras, süüde peab olema paigas ja pritse potet ei tohi näppida. Rohkem ei saa seal keerulisi asju olla .
Kauri
miilits6
postitati 12.02.13 16:27 Tsiteeri
Tänud, sellist vastust olen kaua oodand. Teen ära ja siis mainin kas töötas. :)
miilits6
postitati 12.02.13 18:08 Tsiteeri
kas see 5 kraadi enne ülemist surnud seisu liiga hiline ple??
ülks
Registreerunud 04.12.04
postitati 12.02.13 18:09 Tsiteeri
Endale on jäänud ka kõrvu, et 5-6 kraadi enne ÜSS-i on okei.
www.teemetünni.ee
QUATTRO
postitati 12.02.13 19:29 Tsiteeri
Tavariistadega mõõtes ei tee keegi vahet kas seal on 5 või 7 kraadi. Parima leiab muidugi personaalselt proovides, kuid sellest vahemikust suudab aju juba ise edasi toimetada kuhu tarvis. Pane 6 ja oled kuldsel keskteel.
[PHP: 22.5% - SQL: 77.5%]
