Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Karterituulutus klapi tootekood
Pealkiri: Karterituulutus klapi tootekood (Vastuseid: 10 | Vaatamisi: 3643)
Tambet.
Registreerunud 03.11.11
postitati 10.01.13 11:16 Tsiteeri
Tere,
Nimelt oleks vaja teada tootekoodi karterituulutus klapile, eriti tore oleks kui keegi oskaks anda ka mingisuguse skeemi, et kus see paikneb. Vagcat.com'is kasutajat pole ning millegipärast registreerida ei lase.
Audi A4 B5 1997 1.8 ADR 92kW FWD
Ette tänades,
E: Vagcat'i sain sisse, aga sellest pole tolku.
Tambet.
postitati 10.01.13 15:50 Tsiteeri
Naljakas on nüüd see, et forss ütles, et " Konkreetselt klapi nimetusega ei leia, mootori ploki küljel asub rõhutasandi, selle hind 29,34eur. kohal olemas." , et siis kas on sama asi? Käisin Flameko's karterituulutuse nö korrastuses ja lubati kõik ära teha aga siis kui kõik tehtud oli ja järgi läksin siis öeldi, et sellist asja veel vaja vahetada nagu karterituulutusklapp, et nende kirjade järgi 80€ kanti varuosa aga unustasin varuosa koodi küsida. Nõme oli see, et viisin lihtsalt kontrolli ja kontrolli käigus avastasid vead, mille'd nad lubasid kõik korda teha mis tõttu olin ka nõus selle 100€ kopikatega välja käima, et kui neil seal juba lahti lammutatud on siis las vahetavad ära, kuna varuosad pidid kohapeal olemas olema ja siis kui oli valmis siis tuli välja, et vahetasid ühe vooliku, mingi toru ja všo. Ja nüüd tuleb välja et sellise nimetusega asja polegi nagu või? :D
postitati 10.01.13 20:11 Tsiteeri
Nt AEB-l on 035103245A ja maksumusega 4.20 - Topran.
Tambet.
postitati 10.01.13 20:19 Tsiteeri
Oota see on siis see klapp või?
Aga ma ei saa aru, et mis sel autohooldusel 80€ maksab ning forssil 30€ ?
Igatahes, saatsin Flamekosse meili, loodan, et nad valgustavad seda asja tootekoodiga.
postitati 10.01.13 20:31 Tsiteeri
Algselt postitas: Chips
http://www.autohausaz.com/secure/PartImages/035103245A.jpg ja 30-80€ :o, rikkalt elame sellisel juhul.
Tegu siiski AEB klapiga, mis ei pruugi sinu isendile sobida, kui sellist seal üldse ongi.
Siim89
Registreerunud 07.06.10
Auto: C5 1.8T; C4 2.2TQ;
postitati 11.01.13 01:50 Tsiteeri
Kui ma õigesti nüüd ütlen, siis prj käest sain mina oma AEB-le sellise vidina "pimeda" ja usun, et ka su mootoril võib selle ära kaotada!?
Peaks nii või naa nõrk koht olema.
T_
Registreerunud 23.10.07
Auto: VW Passat B8 4-mo
postitati 11.01.13 06:46 Tsiteeri
Kas ADR'i karterituulutus ei ole lihtsalt selline?
Alumine ots on ploki küljes ja ülemine voolik läheb gaasisiibrisse.
http://i619.photobucket.com/albums/tt275/gtiworm/AudiBreather.jpg
Tambet.
postitati 11.01.13 13:03 Tsiteeri
Okei, ma olen segaduses. Tegin järelpäringu Flamekosse, et küsida, mis varuosakoodi järgi see karterituulutusklapp on ning sellepeale saatsid nad mulle kulukalkulatsiooni, kus nüüd on hoopis mingisugune 80€ maksev õhutoru ja jällegi, ei mingit varuosakoodi.
postitati 11.01.13 13:16 Tsiteeri
Pölvega toru kood on 058 103 213 ja Toprani toode hinnaga 18€.
Tambet.
postitati 11.01.13 13:25 Tsiteeri
Saatsin neile uue kirja, paludes neilt veel kord varuosakoode ning sain tahetud vastuse - 058133356D, 058133783J.
Voolik on jah puruks, seda ma tean aga see toru, mis nende arvates on karterituulutusklapp/õhutoru on täiesti toimiv, õhku pidav ning isiklikult üle kontrollitud ja terve! Tõesti huvitav.
http://www.upload.ee/image/2975917/varuosad.png
Teema võib lõppenuks kuulutada!
postitati 11.01.13 13:38 Tsiteeri
Ühelgi vabalthingabal kohe kindlasti sellist asja ei ole.
[PHP: 25.5% - SQL: 74.5%]
