Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi a4 automaatkäigukasti 3-4 käik puudub
Pealkiri: Audi a4 automaatkäigukasti 3-4 käik puudub (Vastuseid: 11 | Vaatamisi: 1840)
s.a
Registreerunud 03.01.13
postitati 03.01.13 17:07 Tsiteeri
Tere
Probleem on siis selline et 1.8 92 kw Audi a4 kadus ära 3 ja 4 käik . Esimesed 2 käiku toimivad ilusti ning tagurpidi käik samuti . Kas tuleb kasti vahetus ette võtta või on kala kuskil mujal? Veel on probleemiks põlev õliandur armatuuris , põleb kollaselt .
Raika42
Registreerunud 16.11.08
postitati 03.01.13 17:30 Tsiteeri
Algselt postitas: s.a
.... Veel on probleemiks põlev õliandur armatuuris , põleb kollaselt .
Kui minu autol põleks kollane õlituli armatuuris, siis arvatavasti kontrolliks õlitaseme üle.
s.a
postitati 03.01.13 17:56 Tsiteeri
Õlitase korras , see viga on olnud ka eelmise omanikul . kui akuklemm maha võtta siis paar kolm käivitust ei löö seda ette . Aga siiski käigukast suurem probleem
R129
Registreerunud 19.02.10
postitati 03.01.13 18:15 Tsiteeri
Kas käigu puudumine tähendab seda, et üle 2 käigu ei panda sisse, või lööb seejärel juba tühja.
s.a
postitati 03.01.13 18:36 Tsiteeri
Kui manuaalselt lülitada siis esimeselt teisele toimib ilusti , kuid kui sisse panna kolmas sis ei lülitu ümber . vaid jääb teine sisse. ning D asendis kaob peale 2 käiku vedu
R129
postitati 04.01.13 09:01 Tsiteeri
Kui kast tühja käib, siis ei ühendata siduripakke omavahel ära. Lõhnab kas väga huvitava el veana või mehaanilise rikkena.
s.a
postitati 04.01.13 15:06 Tsiteeri
00652 gear monitoring implausible signal . sellise veakoodi lõi mulle data kaabliga . on kellelgi kogemusi sellega?
R129
postitati 04.01.13 22:19 Tsiteeri
Kas see mitte ei tähenda, et ülekanne on vale (libiseb)?
s.a
postitati 06.01.13 13:29 Tsiteeri
Ei oska öelda . Kontrollisin ka kasti õli üle , norm on sees . Suutsin ka kasti nn avariiresiimi ajada aga siis oleks nagu esimene käik sees . Teiste käikudega käigud ei libise ja kõik korras
s.a
postitati 07.01.13 11:01 Tsiteeri
Kui kasti aju lahti ühendada kas siis peaks minema 3 käik sisse ja avariiresiimi ?`kas avariiresiimist saab ilma kaabliga kustutamata ka välja?
R129
postitati 07.01.13 13:18 Tsiteeri
Ma tean, et mercedesel on 2 eri arvriire˛iimi. III käik kui on elektrooniline pisem viga ja II käik kui sisuliselt voolud tagant ära võtad. Ei mäleta peast kuidas Audil on.
s.a
postitati 08.01.13 14:25 Tsiteeri
audil on 3 käik avariiresiim , aga seda ta ei lülita sisse . Kas 1 ja 3 käigul on ühiseid solenoide ? mis 3nda sisse lülitamisel aktiveeruvad?
[PHP: 31.4% - SQL: 68.6%]
