Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - C5 kiilub külmalt roolilatt kinni
Pealkiri: C5 kiilub külmalt roolilatt kinni (Vastuseid: 1 | Vaatamisi: 786)
Taavi
Registreerunud 21.11.04
Auto: UrS4
postitati 03.01.13 08:16 Tsiteeri
Selline mure siis, et külmalt poleks nagu roolivõimu üldse taga. Mõlemale poole keerates käib üks nõks läbi ja peale seda on hetkega asi korras. Tundub, nagu mingi klapp jääks kinni. Probleem esineb enamasti hommikul peale pikka seismist. Ise kahtlustan latti aga ehk kellelgi on veel mõni hea soovitus. Pump on vaikne ning ebanormaalseid hääli ei tee.
12.301@181km/h
kaido.
Auto: S4 2.2 avant
postitati 03.01.13 08:22 Tsiteeri
Esimese asjana võiksid vaadata ega pumba klapp kinni ei kiilu,sest latil endal ei ole enam klappe,ainuke klapp ongi pumbas mis võib jamada.
Naine ütles kord:kas sul ple üldse mingeid traditsioone peale AC dragi ma mõtlen.
[PHP: 22.9% - SQL: 77.1%]
