Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 2.4 mootor
Pealkiri: 2.4 mootor (Vastuseid: 11 | Vaatamisi: 1833)
vax
Registreerunud 28.03.10
postitati 02.01.13 18:05 Tsiteeri
2.4 mootor
Oman 2.4 V6 (121kw) A4 nii aastake, lihtsalt tekkis huvi, et tegu on suht uimase mootoriga, et kas see on normaalne?
Hea näide, 4. käiguga sõidan Kadaka viaduktist üles ja auto ei kiirenda, litsu kuitahes palju gaasi.
Samas, kui lasta mootor nii 3-4krpm, siis justkui ärkab ellu.
Teiseks (hobi)autoks on Mosse 2141 1.7i niva mootoriga ja astub tunduvalt erksamalt edasi...ja väiksema küttekuluga.
postitati 02.01.13 18:31 Tsiteeri
Audi V6 polegi mingi ergas mootor.
4nda käiguga (eeldame,et 50km/h) vastumäge ei ootakski erilist kiirendust.
yanekk
postitati 02.01.13 18:34 Tsiteeri
Algselt postitas: mkb
Ära nüüd kõiki V6-si ka ühte patta pane.
Kuid see 2.4 on küll selline, ei liha ega kala.
andrec
Registreerunud 07.10.06
Auto: A4 B6 R30 VR6 turbo
postitati 02.01.13 18:35 Tsiteeri
Ega sellest mootorist ei olegi midagi head loota tegelikult. Üle tasuks vaadata muidugi ketipingutid, nukkade vahelised ketid(mis on kehvad kindlasti sellel autol juba) ja rihmamärgid. Millal küünlad, õhu- ja kütusefilter vahetatud?
postitati 02.01.13 18:39 Tsiteeri
Algselt postitas: yanekk
Tahtsingi just öelda, et igaüks defineerib uimasust erinevalt ;).
2.4 puhul on selline käitumine täiesti OK.
Audi ja Niva ... nagu siga ja kägu ning 2x vöimsuse vahe + küttekulu on pigem reaalsuses 1:1 .
Portaalide andmeil on Niva keskmine 9.0, Audil aga 9.4 liitrit sajale kilomeetrile.
vax
postitati 02.01.13 18:41 Tsiteeri
kette ja pinguteid pole kontrollinud, olen teadlik küll sellest teemast, aga pole aega olnud.
Filtrid on vahetatud.
andrec
postitati 02.01.13 18:47 Tsiteeri
Need arvutiga kontrollitavad.
vax
postitati 02.01.13 18:50 Tsiteeri
Jah, mul esiveolisele see peale aretatud, kaalub 1074kg masin.
Audi arvuti näitab keskmiseks sinna 10.5 kanti...
http://static3.nagi.ee/i/p/776/12/194030092da192_l.jpg
postitati 02.01.13 18:52 Tsiteeri
Algselt postitas: vax
1074 vs 1275 + kg (sedaan).
postitati 02.01.13 20:57 Tsiteeri
C6 Corvettega sõites panin ka kuskil 70 pealt 6-nda sisse ja ka tundus, nagu oleks 1,2 motoga masina roolis. Eks kõik sõltub ikka kasti ülekannetest jne, olles natuke sõitnud naise isa a4 2,4 autoimaadiga, siis ma küll selle kiirenduse üle ei kurdaks, manuaaliga võiks veelgi parem olla.
audihunt
Registreerunud 12.08.07
Auto: Audi quattro
postitati 02.01.13 21:28 Tsiteeri
Ma arvan ka et Sinul , teemaalgatajal on miskit mootoriga. Ntks läbisõit juba 400 000 vms. Siis on see normaalne et teravus on ära kadunud. Muidugi ega see 2.4 mootor eriline "püss" ei ole , aga samas 120 kw ja peaks ju natuke edasi evima. Mul on 240 tuhat kellal ja näiteks Tabasalu mäest 4 käiguga kiirusel 50-55km/h ampsab küll veel pöördesse minna. Ärge nüüd saage valesti aru , omasin eelmine talv 4.2 A8-t ja 2.2 S6-te, et tean küll et nende tasemeni see minek kaugeltgi ei küündi.
Amadeus
Registreerunud 08.10.02
postitati 02.01.13 21:33 Tsiteeri
Jah see on normaalne vabalthingava V6 puhul. Kui tahad sealt neljadaga üles kiirendada, pead turbomootori poole vaatama.
[PHP: 31.9% - SQL: 68.1%]
