Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Esimesed ja tagumised udutuled ei tööta.
Pealkiri: Esimesed ja tagumised udutuled ei tööta. (Vastuseid: 3 | Vaatamisi: 974)
neem
Registreerunud 04.07.12
postitati 17.11.12 10:41 Tsiteeri
Mure järgmine udutuled ei tööta. Kaitsmed korras aga vool udutuledeni ei jõua. Autoks siis a4 1,8 92 kw 1999 a.
zniffer
Registreerunud 04.04.05
Auto: 200 tQ 134Kw ja wv passat 87a 1.8 syncro/quattro:P ;)
postitati 18.11.12 12:43 Tsiteeri
Aga,,, kas sa koos park või poolduledega oled proovinud :D
neem
postitati 18.11.12 16:15 Tsiteeri
Seda muidugi , üheski asendis ei tööta. Päevatuled iseenesest lülituvad automaatselt .Udutule lülitites ka tulukesed põlema ei lähe . Kellelgi veel ideid?
neem
postitati 05.01.13 18:03 Tsiteeri
Prrobleem lahenes . Udutule kaitsme klemmidel oli udupeene oksiidi kiht peal .
[PHP: 45.6% - SQL: 54.4%]
