Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - B4 kerega 2.8 quattro EI LÄHE PÖÖRDESSE:
Pealkiri: B4 kerega 2.8 quattro EI LÄHE PÖÖRDESSE: (Vastuseid: 8 | Vaatamisi: 1856)
gansta
Auto: Audi 100 2.3.
postitati 31.10.12 14:51 Tsiteeri
Audi 80 92 aasta 2.8 quattro 128kw
ei jookse üle 5500 pöörde,
oleks nagu piirajas ja kiirendades on kuni 3500 pöördeni täiesti normaalne kiirendus,
sealt edasi hakkab hullult koguma.
youtoube on video kus 2.8 jooksevad 8 tuhandeni probleemideta.
http://www.youtube.com/watch?v=hLnhvkjfnHo&feature=related
Tehtud niipalju :
1. Lasin üle vaadata nukad rihma: oli poole hambaga valesti, ei muutunud miskit erilist.
2. Bensiini pump korras testitud ja pressis 5 misiganes ühikut.
Autol on kuiv koonusfilter.
Oskab keegi aidata mida edasi vaadata või teha ?
Kes ees, see mees.
postitati 31.10.12 15:18 Tsiteeri
Pole hullu, vaata, tal ka midagi katki, üle 6000 ei taha minna eriti :D
http://www.youtube.com/watch?NR=1&v=xxYj2T6OKq0&feature=endscreen
Vist oled vale auto valinud :D
lorenzo
Registreerunud 05.11.06
Auto: B7 avant quattro, 2x 82' Ford Capri
postitati 31.10.12 18:17 Tsiteeri
8000 rpm juures see mootor originaal kooste korral juba desintegreerib end ise kui ta sinnani mingite võtetega lasta.
Originaalis tuleb piiraja 6700 juures vastu.
Mõõda kompressioonid üle. Kontrolli küünlaid, küünlajuhtmeid, gaasitrossi lõtk.
Anduritest: õhulugeja, mootori kiiruse andur(G28), mootori pöörete andur(juhipoolse mootori käpa all).
http://12v.org/engine/index.php?section=cl&view=rear
commodore
Registreerunud 26.03.05
Auto: Coupe Quattro, C6 quattro, Passat B8 4motion 280hp
postitati 31.10.12 18:54 Tsiteeri
Ära muretse, ei lähe sinul, ega ka minul või teistel stock v6 2.8 nii pöördesse nagu antud videos. 8000 pöörde pealt ütleb sulle keps juba tere! Kahjuks see mootor ongi selline....uimane. Ma täpseid pöördeid ei oska sulle öelda(auto on seisnud juba pikalt) aga vahetult enne piirajat ei taju sa enam mingit edasiminekut. St mootor karjub ja mõistlik on järgmine käik rauda lüüa.
postitati 31.10.12 19:05 Tsiteeri
Ma ütleks, et esimeses videos oleval audil pole seier lihtsalt omal kohal.
ABC on enamvähem 5000-5500 rpm tühi, ega AAH vöi ACK paljut erine.
Mina saanud tsirka 6000+ ja seda veoga, kohapeal pole proovinud.
Tjuubis löiguti vaadates, pöhimötteliselt 6300-6500 on köik, siis juba vahetatakse käik.
gansta
Auto: Audi 100 2.3.
postitati 02.11.12 06:51 Tsiteeri
no mul 4 tuhat on lagi sealt edasi pole mõtet piinata ei jõua lihtsalt.
Küünlad on uued ja kütusefilter on uus kõikvõimalikud mahlad autos vahetatud.
Panen siis speedsteri juurde aja kirja , kuna endal pole võimalik neid andureid testida. Äkki leiab tema vea ülesse, või oskab keegi miskit muud varianti pakkuda?
Terv,
Mikk L.
Kes ees, see mees.
postitati 02.11.12 07:34 Tsiteeri
Mul oli kunagi suht sama kala a4 2,6 v6-ga, siis, rihm oli peal valesti, ka mitmed uurisid ja jamasid, viimaks viisin esindusse, seal uuriti ja puuriti ka tükk aega, siis helistasin ja käskisin neil rihma kontrollida, oligi selles viga, aitäh Aasta Auto oma saamatuse eest!
Neno83
Registreerunud 19.10.05
Auto: S2 coupe 93 (ABY), coupe GT 84 (JS), 80 quattro 83 (KK), 80 quattro 84 (JS), A6 avant 2,5TDI quattro 96 (AEL)
postitati 03.11.12 19:52 Tsiteeri
Ma kahtlustaks, et sisselaskes olevad klapid ei toimeta.
V6-l nimelt selline sisselase millel on pikad runnerid madalate pöörete jaoks ja alates ca 4100 rpm avatakse lühikesed runnerid.
Vaata kapoti all natuke ringi, äkki on lihtsalt voolik vaakumservo küljest lahti.
http://12v.org/engine/index.php?section=hw&sm=im
ATV põhjakaitsmed ja lisaseadmed....www.ironbaltic.ee
gansta
Auto: Audi 100 2.3.
postitati 25.12.12 11:52 Tsiteeri
Suured tänud,
Viga oligi selles sisselaske vaakumklapis,
Nimelt oli selle vooliku ots vanadusest rabe ja oli ots lahti tulnud.
Sai seda jälitatud ja õhulugeja all oli see koht kus tuli vooliku otsast mõni cm maga lõigata ja uuesti ühendada.
Kes ees, see mees.
[PHP: 18.2% - SQL: 81.8%]
