Pealkiri: Q7 3.0 TDI 171kw pikk käivitus. (Vastuseid: 6 | Vaatamisi: 2314)
T_
Registreerunud 23.10.07
Auto: VW Passat B8 4-mo
postitati 24.10.12 19:06 Tsiteeri
Probleem siis selline,et käivitub pikalt.Aku ja eelsüüteküünlad on äsja vahetatud.
Veakoodid sellised:
Address 01: Engine
Control Module Part Number: 4L0 910 401 K HW: 4L0 907 401
Component and/or Version: 3.0L V6TDI G000AG 0030
Software Coding: 0011779
Work Shop Code: WSC 00548 264 93960
VCID: 2A5F069B85E4083
5 Faults Found
005658 - Glowplug for Cylinder 1 (Q10)
P161A - 001 - Open Circuit
Freeze Frame
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Mileage: 141439 km
Time Indication: 0
Date: 2012.09.08
Time: 12:14:17
Freeze Frame
RPM: 1260 /min
Torque: 97.5 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 14.21 V
Duty Cycle: 25.6 %
Temperature: 10.8°C
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 001 - Open Circuit
Freeze Frame
Fault Priority: 0
Fault Frequency: 1
Mileage: 141439 km
Time Indication: 0
Date: 2012.09.08
Time: 12:14:17
Freeze Frame
RPM: 1260 /min
Torque: 97.5 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 14.21 V
Duty Cycle: 25.6 %
Temperature: 10.8°C
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 001 - Open Circuit
Freeze Frame
Fault Priority: 0
Fault Frequency: 1
Mileage: 141439 km
Time Indication: 0
Date: 2012.09.08
Time: 12:14:17
Freeze Frame
RPM: 1260 /min
Torque: 97.5 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 14.21 V
Duty Cycle: 25.6 %
Temperature: 10.8°C
005662 - Glowplug for Cylinder 5 (Q15)
P161E - 001 - Open Circuit
Freeze Frame
Fault Priority: 0
Fault Frequency: 1
Mileage: 141439 km
Time Indication: 0
Date: 2012.09.08
Time: 12:14:17
Freeze Frame
RPM: 1260 /min
Torque: 97.5 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 14.21 V
Duty Cycle: 0.0 %
Raw, Form. N/A: 000 000 000
Raw, Form. N/A: 000 000 030
005663 - Glowplug for Cylinder 6 (Q15)
P161F - 001 - Open Circuit
Freeze Frame
Fault Priority: 0
Fault Frequency: 1
Mileage: 141439 km
Time Indication: 0
Date: 2012.09.08
Time: 12:14:17
Freeze Frame
RPM: 1260 /min
Torque: 97.5 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 14.21 V
Duty Cycle: 25.6 %
Temperature: 10.8°C
Readiness: 0 0 0 0 0
yanekk
postitati 24.10.12 19:28 Tsiteeri
Kas juhe ka nende taha tagasi sai, näitab ju otseselt et pole ühenduses.
Siin tegelikult päris pikalt kirjutatud.
Google
Best ET 12.08 :)
jankul
Registreerunud 20.03.06
Auto: AUDI A6 3,0TDI 171KW quattro
postitati 25.10.12 10:01 Tsiteeri
Selline tobe küsimus, et kui pikk on pikk käivitus?
postitati 25.10.12 17:02 Tsiteeri
Algselt postitas: jankul
Üle 10m lükkamist. :)
BTW, su avatar ja profiilis olev auto ei lähe kokku.
postitati 26.10.12 04:26 Tsiteeri
Korras 3,0TDi peaks käivituma u. sekundi jooksul. 1,9TDi PD käivitub näit. momentaalselt n.ö. poolest pöördest.
OOOO, VW, Seat, Skoda DIAGNOSTIKA, OSTUABI (võimalik üle Eesti), kodeerimine, (de)aktiveerimine, aut. kastide õli, seadistused, DPF-i, õhkvedrustuse mured, läbisõit jne. (Litsentsiga orig. Ross-Tech PRO V2 seade + alati uusim tarkvara ja 19a. kogemust). 2g, HN+, MHI2, MHI2Q uuendused, NAVI 2026-27, VIM, SpeedCam, Carplay, Android Auto aktiv. jne. Läbitud kilomeetreid ei muuda. U2U või 55547002.
Amadeus
Registreerunud 08.10.02
postitati 26.10.12 05:44 Tsiteeri
Kui kuuest küünlast üks töötab, siis võib see käivitus pikem olla küll.
T_
postitati 02.11.12 12:03 Tsiteeri
Viga oli siiksi "uutes" küünaldes.
[PHP: 24.1% - SQL: 75.9%]
