Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 2,5 tdi AEL Sidur ei kesta.
 Lehekülgi:  1  2  3
Pealkiri: 2,5 tdi AEL Sidur ei kesta. (Vastuseid: 67 | Vaatamisi: 16729)
a90q20v
Registreerunud 15.04.04
Auto: zil157
postitati 20.10.12 20:13 Tsiteeri
C4 A6 2,5TDI r5 103 ja natuke peale kiluvatte.
Sidurid ja hoorattad ei kesta. Milliseid soodsaid variante on seda kestma saada.
Põhjus miks ei kesta hooratas ja sidur on lihtne- lihtsalt nõrgim lüli.
Hooratta keerab lihtsalt seest sodiks. Üle aasta ei ole kuidagi ühe hoorattaga saanud. Ketas ja korv natuke kauem kestavad. Siduriga libistamine ei ole põhjus.
Ilmselt mõni teine sidur aga mille oma. Ühemassilist hooratast mitte soovitada.
loodetavasti on kellegi kogemus sest siis ei pea jalgratast leiutama.
Tänud ette.
postitati 20.10.12 21:34 Tsiteeri
Algselt postitas: a90q20v
Tänud ette.
Huvipärast küsin, et miks ühemassiline hooratas halb on?
a90q20v
Auto: zil157
postitati 21.10.12 06:30 Tsiteeri
Ei ole halb aga ael i peal teeb hirmsat vibra kui panna aat oma.
audicabrio
Registreerunud 30.08.07
postitati 21.10.12 09:10 Tsiteeri
Kas tõesti need kõik, kes on enda sidurid vahetanud ühemassiliste vastu, ei ole vibra tähele pannud või lihtsalt ei maini seda? Tahaks teada, kuna endal plaan ühemassilise vastu vahetada. Kas teemaalgataja oli kuulnud sellest et vibra tuleb naistelt saunas või tõepõhi ka kuidagi all?
maxic
Registreerunud 27.05.04
Auto: auditu
postitati 21.10.12 10:00 Tsiteeri
Jah, on küll vibratsioon tühikäigul, kuid ei midagi hullu.
jrgen99
Registreerunud 02.02.05
Auto: A6 2.5TDi Avant quattro 1997
postitati 21.10.12 17:39 Tsiteeri
Võin ka öelda et vibratsioon tekkis peale hooratta vahetust. Eriti sis on tunda kui 4 käiguga sõita sis käsi käigukangile panna on tunda.
freelander
Registreerunud 06.09.05
Auto: A6 C7 facelift 3.0bitdi
postitati 21.10.12 17:45 Tsiteeri
Vibratsoon tekib ühemassilisega nii alla 1200 pöörde. Üle selle kaob.
Aga ühemassilisega kaob see värin kiirendustel, möödasõidul jne.
Kui valida kas värin möödasõidul või siis väga madalatel pööretel, siis igaüks saab ise valida.
a90q20v
Auto: zil157
postitati 21.10.12 18:25 Tsiteeri
Eh, kui vibra rõõmu teeks siis ostaks Opel kadett diisli :)
Aga teema juurde tagasi.
Hetkel kaks varianti:
Lihtsalt aeg ajalt sidureid vahetada või keerata võimsus maha...
2bar piisavalt tore, et hetkel nõus sidureid ja hoorattaid vahetama.
freelander
postitati 21.10.12 18:33 Tsiteeri
Nojaa aga kui valida kas väike värin mingitel pööretel või siis suvalisel hetkel lagunev audi, siis pigem vist valiks vibra. Aga noh oleneb kas auto on soitmiseks voi niisama soprade ees kummipõletamiseks. Mina näiteks endale ei saa lubaga seda, et suvaliselt hetkel auto laguneb. Ketast on vast sinna vahele lihtsam leida mingit kangemat. Aga soovitan mingeid välismaa foorumeid lugenda ja kindlasti leiab õige summa eest sinna lahenduse, iseasi kas see sind sellise audi puhul rahuldab.
a90q20v
Auto: zil157
postitati 21.10.12 18:50 Tsiteeri
Suvalisel hetkel ei lagune. Ainult siis kui paremat pedaali tugevamalt muljuda ja alati saab koju sest hoorattaga kui üle keerab siis ei kao kohe vedu vaid vaikselt sõites saab koju.
Kui nüüd norida siis. kas kummipõletamine ei olegi sõitmine või kuidas saab kummi põletada ilma sõitmatta.
Ei ole 1wd masin, seega ei tegele põletamisega. Ja kw ei ole düno trükiga esinemieks vaid tarbimiseks.
Aga siini ei ole lihtne olnud sinna ketast ja korvi leida.
"iseasi kas see sind sellise audi puhul rahuldab"
Millise sellise?
freelander
postitati 21.10.12 19:14 Tsiteeri
No ma motlesin selle all seda, et c4 väärtus ei ole mis teab suur ja korralikud sidurikomplektid maksavad väga toredat raha. Seda motlesin selle all. Aga usun, et kolla audi saksa foorumites, kindlasti leiad midagi, neid üüber tehtud c4 on mitmeid. Ja ei usu mina, et sa ainuke sellise probleemiga oled.
a90q20v
Auto: zil157
postitati 21.10.12 19:55 Tsiteeri
Nii enam võhem korralik, kui korralik üks c4 on hind kuskil 4000-5000 eur.
Palju huvitav sellise seiduri eest võidakse küsta nii umbes täpselt. teab kas on mõtet surfata.
freelander
postitati 21.10.12 20:37 Tsiteeri
Praegu jälle hinnad ulmeliseks aetud aga pigem on korraliku quattro hind alla 4k. Aga usun et korralik sidurikomplekt on veerand kui mitte pool sellest. Hooratas ja kõik siis.
yanekk
postitati 21.10.12 21:00 Tsiteeri
Ma küll ei tea, mis suuruses ketas/korv kasutusel on aga neid natuke kangemaid komplekte on ju kõik kohad täis, ainult ole mees ja osta.
Best ET 12.08 :)
Petu
Registreerunud 13.03.08
postitati 22.10.12 07:08 Tsiteeri
Ketta ja korvi probleemi ei tohiks küll olla tõesti, aga hooratta probleemist saan kohati aru. Ideaalis pole see ühemassiline tõesti just parim lahendus, sest tõesti on selline vibra nagu freelander juba kirjeldas, aga kas tõesti ei saa ühtegi teise võimsama R5 hooratast ketta ja korviga külge pookida? Näiteks VW Caravelle/Multivan 2.5TDI 128kw 400nm või isegi 2.2T AAN?
Edit: Peale 1,5h otsimist ainuke lahendus, mis ma leidsin on kallis ning ei tea kui pikaajaline (enamus panevad siiski ühemassilise):
http://www.ebay.co.uk/itm/LuK-Audi-A6-4A-C4-2-5-TDi-06-94-02-97-Dual-Mass-Flywheel-/320796292963?pt=UK_CarsParts_Vehicles_CarParts_S M&hash=item4ab0f2f763
http://www.ebay.co.uk/itm/Audi-A6-4A-C4-2-5-TDi-Quattro-Dual-Mass-Flywheel-LUK-10-95-02-97-/330649892117?pt=UK_CarsParts_Vehicles_Ca rParts_SM&hash=item4cfc44f515
kylaline90
Registreerunud 11.09.06
Auto: C4
postitati 25.10.12 11:16 Tsiteeri
Tänud ette.
Küsiks, et kui suurtest jõu- ja väändenumbritest jutt on, et hooratas ja sidur lahkuma hakkavad nii kiirelt. Ainult kivi vahetus?
kuno666
Registreerunud 15.07.06
Auto: 2xV8 & 1x 2,2 20v.
postitati 25.10.12 15:00 Tsiteeri
On kellegil ühemassilisest hoorattast pilti mida kasutanud on? On kellegil meeles kas on süvendiga või ilma? Kes on audi 100 c4 kerelt selle võtnud?
Geeni
Registreerunud 05.03.08
Auto: b6q & 90q 20vt & c5 1.9tdi q
postitati 25.10.12 15:33 Tsiteeri
See ketas mis said oli süvendiga hoorattalt pärit 100 c4 2.5tdi 85 kw aga minu a6 sama mootor on sile ja kahemassiline hooratas.
jrgen99
postitati 25.10.12 17:17 Tsiteeri
Algselt postitas: kuno666
Ütlesin sulle ju et sobib su enda korv ja ketas. Sul ju bensuka hooratas oli ja see korv tõesti ei sobi mis raunexsist ostsid. Aga tellisid süvendiga hooratta korvi mida paigaladati aint 100le. A6 on juba sileda pinnaga hooratas.
forsin
Registreerunud 01.07.04
postitati 26.10.12 07:12 Tsiteeri
Tere
mina valisin sellise komplekti
http://album.ee/node/27415769/50316523
http://album.ee/node/27415773/50316523
ja tänane hinna skaala peaks jääma alla 1000 euri.
Selle komplekti hooratta paksus mõõtkava mm on orig.
Survelaager töötab orig kaugusel mm-tes.
Hoorattad pärinevad vanadelt rida 5 pentsukatelt audid alates kaheksakümnendatest.
ja ükski turbo oletatavasti ei keera sellist NM üle.
Sidurikorvi mõõtkava langeb kokku turbo2,2 S audide AAN mõõtkavaga.
forsin
postitati 26.10.12 07:24 Tsiteeri
Algselt postitas: jrgen99
Minu arvates need süvendiga korvid kõik õhemate siduri korvi vedru paksustega kui S audide omad seega nõrgemad
ja samasugused süvendiga sidureid (natuke tugevamad) on terve eesti täis need olid vanadel R5 10 klapi turbokatel
134kw 147kw
kylaline90
Auto: C4
postitati 26.10.12 11:24 Tsiteeri
Kas AAN hooratas sobib 1:1 AEL hooratta asemele? On neil miskit vahet? Plaanis oleks siis jätta AEL sidur samaks ning vahetada hooratas.
jrgen99
postitati 26.10.12 14:39 Tsiteeri
Sobib üks ühele aga poldid peavad ka uued lühemad olema sest kahemassilisel on pikad poldid, muid erinevusi nagu ei olegi.
forsin
postitati 26.10.12 17:53 Tsiteeri
Algselt postitas: kylaline90
http://album.ee/node/27431350/50316523
tegu ühesuguste kahemassiliste hooratastega
aan omal all lisaks üks kihv asendi anduri tarbek mis ael omal puudu sest ael on andur viiene ja saub plokis.
pildil mõlemad
kylaline90
Auto: C4
postitati 01.11.12 11:51 Tsiteeri
Väga tore, et AAN ja AEL 2-massilised hoorattad on välimuselt siis ühesugused ja sobivad 1:1. Paistab, et kõik, kes on 2-massilise hoorattaga AEL moto ära chippinud, on tuttavad vibraga, mis alates 3. käigust momendi tekkides sisse lööb. Chipiga saab kätte momendi, mis põhimõtteliselt AAN motol on stock-is (350-360Nm) ning teadupärast essimehed vibra nagu ei kurda. Siit siis uuesti küsimus, on keegi asendanud AEL orig. hooratta AAN hoorattaga ning mis tulemuseni on jõutud?
 Lehekülgi:  1  2  3
[PHP: 14.4% - SQL: 85.6%]
