Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - a6 2,5tdi 132kw 2001/10 käigukast uimerdab
Pealkiri: a6 2,5tdi 132kw 2001/10 käigukast uimerdab (Vastuseid: 3 | Vaatamisi: 1271)
helitehnik
postitusõiguseta huviline
Registreerunud 31.01.05
Auto: Volvo s80, Audi s8
postitati 19.07.12 22:23 Tsiteeri
Mure siis selles et mitte alati aga vahel gaasi andes jäävad pöörded ikka sama kohe peale, ehk siis ei kiirenda, isegi kui kickdown teha. kickdowniga siis lükkab käigu küll alla ja pöörded on kõrgemal, kuid edasi tahhokas ei liigu, seisab ühe koha peal. hoides gaasi sujuvalt samal kohal edasi mingi 5seci, siis järsku hakkab liikuma. Igakord seda pulli pole, milles võib asi olla? on ehk kelllegil aimu? Tänud vastamast
elts1987
Registreerunud 08.04.10
Auto: A6 3.0tdi Quattro ja B4 2.0 Quattro
postitati 20.07.12 08:26 Tsiteeri
Re
Miks Sa arvad , et viga kastis üldse? Mulle tundub rohkem et viga mootori ja selle juhtimise poolel! Vb. On kellegi tuttaval vag-com , ehk saab sealt mingi vastuse.
DT85
Registreerunud 26.06.11
postitati 26.07.12 03:24 Tsiteeri
Kuna sul pole kirjas, mis kastiga tegu on, siis kõik sümptonid viitavad multitronic kastile. Siis peakski olema nii, pöörded on samad, muutub vaid käigukasti ülekandearv.
elts1987
postitati 27.07.12 18:06 Tsiteeri
Algselt postitas: DT85
132kw pole multitronicut vaid tiptronic
[PHP: 15.3% - SQL: 84.7%]
