Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890 Eesti Audi Klubi foorum - Audi A6 C5 keskkonsooli valgustus probleem.
Pealkiri: Audi A6 C5 keskkonsooli valgustus probleem.
(Vastuseid: 2 | Vaatamisi: 1092)
Ollu.
Registreerunud 17.05.12
postitati 17.05.12 17:28
Tere, probleem siis selline et keskkonsoolis ei põle ükski nupu valgustus, nupud ise toimivad ja kliima näidikud ja ventilaatori astme näidik ka
töötab, probleem just nupu valgustuses. Ehk keegi oskab aidata kust viga otsima hakata.
KsenoonE
Postitusõiguseta huviline
Registreerunud 05.01.10
postitati 17.05.12 18:24
Kellade valgustus toimib? Vb lihtsalt rullist maha keeratud valgustus.
Ollu.
postitati 17.05.12 20:24
On ju kirjas et keskkooli valgustus probleem mitte kellaploki, ja reostaadist pole ka maha keeratud.
[PHP: 37.6% - SQL: 62.4%]
