Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Mure Audi A8 d2 immoga.
Pealkiri: Mure Audi A8 d2 immoga. (Vastuseid: 6 | Vaatamisi: 1102)
Uss
Registreerunud 03.09.03
postitati 25.12.11 10:16 Tsiteeri
Probleem siis selles,et 2-l korral kolmest ei lase originaal immo autot käima panna,jääb armatuuri vilkuma immo tuli.Olen proovinud ka teise tagavara võtmega ,aga probleem sama.Veateateks annab key signal too low.Kas on kellelgi kogemusi sarnase probleemi lahendamisel või siis üldse väljalülitamisel?Olemas sekundaarsed valvesüsteemid. Hakkab juba ära tüütama see võtmega kruttimine koguaeg.Kaabel on endal olemas. Autoks A8 1996 4,2. Ilusat jõuluaega kõigile.
Quattro.
samru
Registreerunud 01.02.04
postitati 25.12.11 10:25 Tsiteeri
Seda saab väga edukalt remontida.
Uss
postitati 25.12.11 10:28 Tsiteeri
Ja kuidas see välja näeb see remontimine?Oleks väga tänulik abi eest.
Quattro.
samru
postitati 25.12.11 10:50 Tsiteeri
Tuleb immoga seotud pistikud juhtme külge kinni joota ja ongi üldjuhul korras. Tehtud neid kümneid ja enamus on korda saadud.
Uss
postitati 25.12.11 11:11 Tsiteeri
Kui saaks veel näpunäiteid kust lammutama peab hakkama siis oleks tore,jootekolb olemas ja elementaarsete jootmistega saaks hakkama.
Quattro.
Uss
postitati 25.12.11 14:24 Tsiteeri
Kas ma peaks vaatama süüteluku ümber olevat immorõnga ja spidoploki taga olevat immoploki ühendusi ,või panen ma väga mööda?
Quattro.
QUATTRO
Auto: 5,2 Cherokee 4x4
postitati 25.12.11 19:53 Tsiteeri
Algselt postitas: Uss
Just nimelt neid.
[PHP: 57.3% - SQL: 42.7%]
