Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 100 C4 abs anduri eemaldamine
Pealkiri: 100 C4 abs anduri eemaldamine (Vastuseid: 8 | Vaatamisi: 1420)
postitati 09.10.11 19:41 Tsiteeri
Sooviks siis teada saada, et kuidas selle kätte saaks. Mingit polti nagu näha pole, kust lahti keerata vms. Ei julge ka kohe jõuga hakata kangutama, seega ootaks targematelt vastust selle kohta. Täpsemalt siis vaja esimesi andureid lahti võtta.
postitati 09.10.11 19:51 Tsiteeri
Rooste hoiab teda kinni sel. Ja tervelt sa vaevalt kätte saad. Miks andur vaja ültse eemaldada?
QUATTRO
Auto: 5,2 Cherokee 4x4
postitati 09.10.11 20:07 Tsiteeri
Tõenäoliselt võid kohe hakata uut andurit otsima juba ja ka seda vedruhülssi, mis andurit paigal hoiab.
Torts keraamilist määret ei teeks ka paha, saad hiljem selle anduri kätte vajadusel.
postitati 10.10.11 14:18 Tsiteeri
Andurit vaja selleks eemaldada, et uurida kas äkki on ots roostes ning siis ka paremini näha, kui kaugele see andur sisse ka läheks. Nimelt asi selles, et algul kustub abs-i tuli ära, aga sõites hakkab natukese aja pärast uuesti põlema ja nii palju kui ma olen leidnud otsingu abil ja targematelt ka nõu küsides, siis peaks viga olema selles, et andur on liialt kaugel.
Aiku
Registreerunud 03.04.04
Auto: AUDI A6 C5 1,8T 2000a.
postitati 10.10.11 14:23 Tsiteeri
Selleks ,et uurida pole vaja andurit välja kiskuda kui ta ei tule. Lihtsam on ju veovõlli ots välja võtta ja seest poolt uurida anduri roostet ja palju välja pesast ulatub.
postitati 10.10.11 14:40 Tsiteeri
Viga vöib ka selles olla, et andur on liialt lähedal ja igasugu mudru on tipu ära lihvinud.
Kulutab keskele augu ja veits vett/niiskust ajab asja lolliks/hukka.
Aiku pakkumine on parem, kui vana andurit löhkumata kätte ei saa ja uut asemele panna ei ole.
postitati 10.10.11 14:45 Tsiteeri
Asi võib ka 5min laheneda, tõmbad anduri välja (katki ei lähe), puhastad ära ja paned tagasi. Nii palju, kui mina olen neid välja kiskunud, pole ükski kinni olnud eriliselt.
Auto: 5x4x4
postitati 10.10.11 14:50 Tsiteeri
Selle kakkumisega ongi see lugu, et täpselt 50:50 võimalus. Kui tuleb siis tuleb, kui ei siis ei. Riskiga peab arvestama alati kui ei viitsi poolteljeotsa välja tõmmata ja veidi rohkem vaeva näha. Ise pole seestpoolt aidates siiani mitte ühtegi suutnud ära lõhkuda, aga kõri on uut alati vaja läinud, sest üldjuhul originaalanduritel pole sellet peale hunniku roostet midagi järel :(. Teiseks on pooltelje otsa hammastiku puhastus niikuinii "must have" tegevus, mida on ABS anduri august tehes suhteliselt tüütu majandada ja seda väljas olles on ikka kordades lihtsam teha korralike töövahenditega. Ütleme siis nii, et see pole niikuinii kortermaja ees parklas toimetamise teema (noh võib ju, aga ...). Kui masin on mingi asisema mootoriga ja kaabliga laseb ABSi'le ligi, siis on asi kordades lihtsam diagnoosida, milline andur segast paneb vaiksel kiirusel igast andurist eraldi vagscope'ga graafikut joonistades.
Minu 2.3 AAR motoga isendi puhul pole ka ABSi readoutist võimalik kahjuks rääkida :(. Sorry, aga 100% ei oska midagi väita, et mõne 2.6 või muu motoga konkreetne isend readouti võimaldab :(. Ise tegelenud reeglina uuemate isendite ABSi muredega.
postitati 16.10.11 18:00 Tsiteeri
Sai siis järgi uuritud ning mõlemal anduril on tipud maas ning augud sees. Hammasvööd sai ka puhtaks tehtud ning nüüd uute(kasutatud) andurite otsingul.
[PHP: 0.2% - SQL: 99.8%]
