Pealkiri: K: rehvitabeli kohta (Vastuseid: 2 | Vaatamisi: 1811)
tarmo
Registreerunud 05.01.03
postitati 23.10.04 19:56 Tsiteeri
et siis küsimus:
kes seletaks lahti rehvitabelis peituvad järgmised lühendid: 85Q RF ja 85Q XL ?
äss
ac aasta auto 2011 võitja
Registreerunud 23.03.04
Auto: 2x 1,8t ja masuudipress
postitati 23.10.04 20:34 Tsiteeri
Juttu nokian i kodukalt .. kui keegi ära tõlgiks, siis peaks asja saama :P
XL is the Extra Load load range. The tyre is developed for a maximum load of four units higher. For speeds over 210 km/h the actual load of V, W and Y rated tyres is reduced accordingly.
RF means Reinforced Speed Rating, which means that the tyre is in the highest passenger car load range designed for carrying higher loads than ordinary car tyres.
RF tyres need to have higher inflation pressures than ordinary passenger car tyres. A common inflation pressure with a maximum load is 290 kPa. When hauling a trailer or a caravan at speeds below 100 km/h, the maximum load bearing capacity can be exceeded by 10% by increasing the inflation pressure by 20 kPa.
Tige Kala
Registreerunud 18.01.04
Auto: B7 S-Line
postitati 23.10.04 21:29 Tsiteeri
Jutu iva on selles, et need kummid on mõeldud autodele, millega ntx kantakse mingeid raskeid esmeid, koormaid. Kannatavad rohkem koormust.
[PHP: 22.4% - SQL: 77.6%]
