 Lehekülgi:  1  ..  7  8  9  10  11  ..  85
Pealkiri: VAG-COM / VCDS (Vastuseid: 2123 | Vaatamisi: 3074161)
postitati 05.12.10 08:53 Tsiteeri
Algselt postitas: kickija
Tekkis küsimus, oleks vaja Audi A4-l OIL märguanne ära kustutada, engine alt võtsin adaption ning proovisin 8-le ja 2-le kanalile väärtust 72 anda, kuid ütles, et ei sobi. Oskab keegi öelda, kuidas see käib?
Kui on vana programm, kus pole SRI Reset nuppu, proovi seda.
Pre-1998 models ... or if Channel 02 is not available:
[Select]
[17 - Instruments]
[Adaptation - 10]
Enter the correct channel from the list below in "Channel Number"
[Read]
The "Stored Value" is the current value for that channel.
Enter the "New" value of from the list below.
[Test]
[Save]
Channel 05 should be the distance until the next Oil Service.
It is in thousands of kilometers. Let's say you want the Oil
Service light to come on in 5000 miles. That would be 8000 km.
Put the value 8 into channel 05. The "standard value" used by the US
dealers would be 12 (7500 miles).
Channel 06 should be the distance until the next In-1 Service.
Same units as above. Standard value would be 24 (15,000 miles).
Channel 07 should be the time until the next In-1. In-1 lights
up based on time or distance, whichever comes first. This is in
10's of days. Standard value would be 36 for 360 days.
Channel 08 would be time until the next In-2. In-2 is based
strictly on time. Standard value is 72 for 720 days (about
two years).
Tegelt sai vist 96a. A4 -l kellade nuppe näppides ka ära resettida.
Otsi, siin foorumis sellest mitu teemat.
Kjaups
Registreerunud 15.06.06
Auto: A6 01a 2,4, KIA 1.6
postitati 06.12.10 11:25 Tsiteeri
Glow plug cylinder 2 - Q 11
Open circuit
Status: Static
Glow plug cylinder 3 - Q 12
Open circuit
Status: Static
Selline tore veateade.
Asjast olen aru saanud, et Glow plug on eelsüüteküünal. Parandage kui eksin.
Aga mida see Static seal endast kujutab?
postitati 06.12.10 11:52 Tsiteeri
Algselt postitas: Kjaups
Open circuit
Status: Static
Open circuit
Status: Static
Lühidalt öeldes on need kaks küünalt läbi.
Open circuit - avatud vooluring e. takistus puudub.
Static e. staatiline - seisev, liikumatu, jne.
Kjaups
postitati 06.12.10 12:15 Tsiteeri
Hmm. Imelik. Külmaga käivitades peab ainult ca sekundi kauem käiama, vahele turtsub kaks kolm korda ja siis hakkab tööle nagu tavaline tühjal käigul töötav mootor :D .
Et kui kaks tükki läbi on, siis peaks ju päris palju jamamist olema kahe surnud eelsüüteküünlaga külmal ajal?
postitati 06.12.10 12:59 Tsiteeri
Ei pea isegi 0 töötava küünlaga läheb korras nmootor kuni -20 neni suht vabalt käima. Vaheta küünlad ruttu ära enne kui mittetöötav küünal kaande kinni tahmab.
anduke88
Registreerunud 17.04.07
postitati 15.12.10 20:33 Tsiteeri
Nii, vahepeal saabus uus hiina kaabel. Seekord olin targem, võtsin multimeetri ja pistsin mõlemad otsad kaitsmekarpi musta pesa klemmide külge. Ja ongi, + ja - on teisipidi võrreldes adaptri musta otsaga.
Ehk kui 2x2 adapter panna õiget pidi, on + - omavahel koos ja - + ehk tulukesega kaabel õhtal. Nüüd panin adaptri soontega võrreldes valet pidi külge ja asi hakkas tööle.
Niiet kes möllavad 80-tega, siis ennem igaks juhuks pistke tester külge ja vaadake, kummal pool Teil + ja - on. Võimalik, et kõikidel on asi nö tagurpidi, aga võimalik, et asi nii ainult minu masinal, võimalik, et hiina kaabel valet pidi vms...
Aga ilmnes üks aga, kui panna "auto scan"-i peale, siis asi jääb ABS-i juures seisma-otsing peatub (Address 03: ABS Brakes
Controller: 4A0 907 379 A). Tuleb selline error ette:
http://www.upload.ee/image/987978/error2.jpg
ja otsing lõpetatakse.
Kas nii peabki olema? Sama error tuleb uuesti ette käsitsi ABS seadete all sobrades ning teisteski menüüdes, kui liikuda advanced osa peale.
Kas selle hiina kaabli peab siis ära regama? Samuti ei saa menüüdest osadele asjadele ligi. Pikk serial nr About alt olemas, aga mis seal regamislehel tuleb panna Certificate Number & Short Serial Number lahtritesse?
Praegu töötab Windows 7-ga 409 versioon suurepäraselt. Lähiajal võtame mõne A4-ja ka ette :cool:
postitati 15.12.10 20:44 Tsiteeri
Kaabel on lihtsalt registreerimatta. Infot leiad internetist või osta originaal kaabel. Ma ei saa aru kuda sul juhtmed tagurpidi on ma olen neid väga palju erinevaid näppinud ja alati on õigesti saanud. Ise paigaldan kahtluse korral K liini järgi kuna se on esimene ja hästi näha. Nimelt roheline juhe läheb valge pistiku K tähe alla. Ja vooluoma panen lihtsalt samapidi mis K,L liini pistiku. Kui näeb võid ka vaadata voolu oma kus punane on + ja pruun -.
emmure
Registreerunud 02.06.09
Auto: Audi a6 2.8 v6 quattro
postitati 17.12.10 19:19 Tsiteeri
Keegi saaks kuidagi ära seletada ,kuidas ma näeks kaabliga kas mul temp. andur korras või ei. Oleks vaja kontrollida kas ajus sama õlitemp. näit mis salongis ja sama ka jahutusvedelikuga. Kas alati on viga termostaadis ,kui salongis jahutusvedeliku kraadi ei näita. Ning kas keegi saaks anda mõne skeemi kuidas seda paagisiseset andurit vahetada ,mis pidavat ära kuluma. Jättis teine täna jälle teele ,kuigi selle kütte tasemepeal pole seda veel juhtunud. Käib asi juba närvidele ,vahetaks teise ära. Kui saaks vaid teada mis selle hind võiks olla ja mis nime all seda otsida.
Autoks a6 c5 a98
Ette tänades Emmure.
Project-Massacre
postitati 18.12.10 05:39 Tsiteeri
Algselt postitas: emmure
Autoks a6 c5 a98
Kütusepaagi tasemeandureid on kolm ja kuskilt on meelde jäänud, et vahetatakse kõik korraga ja hind mingi 3K oli äkki. Kõigepealt oleks vaja neid vagcom-iga uurida. Mul viskas ka korra silmini tankides ühe anduritest lolliks, peale veakoodi kustutamist toimis jälle ilusti ja toimib siiani.
Temperatuure saab vaadata engine- measurig blocks- group (001 jne.)
Krister.audi
Registreerunud 20.09.10
Auto: Audi A4 B7, UrS4
postitati 18.12.10 10:21 Tsiteeri
vag-com 409-1
sai ostetud selline isend välimuselt sinise pistikuga ja hõbedase kaabliga. Peal tekst OBD-II ja üks sinine LED. Kaasas väike valge-sinine CD ei saa kuidagi tööle seda kaablit ette tuleb selline kiri NO RESPONSE FROM CONTROLLER mis võib viga olla ?
emmure
postitati 18.12.10 12:30 Tsiteeri
Autoks a6 c5 a98
Mul näiteks vag kaabel paagi anduri viga ei näita? Kas võib olla asi milleski muus?
Project-Massacre
Browser
Registreerunud 13.11.10
postitati 18.12.10 13:51 Tsiteeri
Algselt postitas: Krister.audi
Kas porti panid ikka õige programmis? Vaata device manageri alt kaabli port ning siis määra see programmist. Kui port on suurem kui port4 (näiteks port 12), siis määra port kas 1-ks või muuks vabaks, mis programmis olemas on.
Krister.audi
postitati 18.12.10 14:35 Tsiteeri
mis mõttes õiges programmis ? Vaata device manageri kust seda muuta saab
postitati 18.12.10 15:20 Tsiteeri
Autoks a6 c5 a98
Mis asja alt sa seda üldse vaatasid?
emmure
postitati 18.12.10 16:38 Tsiteeri
Autoks a6 c5 a98
Tavaliselt lasen kõik üle käia tal. Ehk autoscan. Kui sealt leiab siis jätan meelde mis nr -i all viga oli ja otsin eraldi ülesse. Ning proovin selle kustutada.
Või peaksin kuskilt teistmoodi ligi minema?
Project-Massacre
postitati 18.12.10 16:51 Tsiteeri
Vaata Instruments alt, kuigi autoscan peaks selle ka läbi võtma. Osad kaablid pooliku tarkvaraga ei lase Instruments teabele ligi ja autoscan võib selle lihtsalt üle lasta. Seepärast vaatagi eraldi seda.
emmure
postitati 18.12.10 17:02 Tsiteeri
Suured tänud. Homme tsekin asja üle. Vaatab mis saab.
Project-Massacre
ruslanpro
Registreerunud 11.02.10
postitati 20.12.10 09:59 Tsiteeri
Krister.audi
mis autoga on tegu?
Silverpm
Registreerunud 06.04.08
postitati 20.12.10 13:48 Tsiteeri
Kas keegi mulle numbreid tahab seletada mis on measurment blocks-ide all.
Vanematel audi 100-c4-jadel ja näiteks minu V8-l on seal pikk julkam neid numbreid mis muutuvad kuid infot nende kohta väga ei leia.
Lisasing ka alla pildi, vastavalt on minul ainult näiteks group 000 info, kui panen 001 siis ütleb, et not available.
http://i13.photobucket.com/albums/a258/gabrielmachado/vagcom_measuring_blocks.jpg
ahartsi
Registreerunud 16.04.10
postitati 20.12.10 13:53 Tsiteeri
http://www.ross-tech.com/vag-com/m_blocks/http://www.ross-tech.com/vag-com/tour/m-blocks.html
Silverpm
postitati 20.12.10 14:01 Tsiteeri
kahjuks see variant ei toimi kui ma selle peal vajutan siis ta ei tee lihtsalt midagi.
emmure
postitati 20.12.10 14:37 Tsiteeri
Keegi oskab öelda mis nr -i alt ma trosselklapi saaks üle käia? Kunagi ammu lõi veakoodi aga ei mäleta mis nr -i all oli. Kontrolliks selle ka üle. A6 c5 98a.
Project-Massacre
emmure
postitati 20.12.10 18:53 Tsiteeri
Mure veel selline ,et äkki keegi teab miks mul need asjad õigel kohal pole? Tundub ,et kõike näidab mul mesure block .i all valesti. Sellepärast ma ei leiagi vist õigeid asju ülesse.
Paneks ka ühe pildi.
http://static1.fotoalbum.ee/fotoalbum/318/295/0796476431b549.jpg
311- 2 versiooni kasutan muidu.
Project-Massacre
Silverpm
postitati 20.12.10 22:53 Tsiteeri
311 oli ühe autoga sama trikk, proovi 409.1 vajadusel USB variant (kui on usb otsaga kontroller)
Enda murega edasi minnes, ehk oskab keegi defineerida.
mootor soojaks sõidetud (linnast-koju ca 30km ring)
Tegemist basic setting alam rühmaga.
1 - 204
2 - 040
3 - 079
4 - 128
5 - 093
6 - 137
7 - 038
8 - 131
9 - 092
10 - 042
emmure
postitati 21.12.10 10:29 Tsiteeri
Siin peab kindlasti ka mingi muu lahendus olema. Ei tahaks esialgu uut programmi peale lasta.
Project-Massacre
[PHP: 4.9% - SQL: 95.1%]
