 Lehekülgi:  1  ..  5  6  7  8  9  10
Pealkiri: Väljalase (Vastuseid: 249 | Vaatamisi: 93190)
Maku
postitati 17.04.09 10:54 Tsiteeri
Wastegate'i toru
If an integrated exhaust (non-divorced wastegate flow) is required, keep the wastegate flow separate from the main turbine discharge flow for ~12-18" before reintroducing it. This will minimize the impact on turbine efficiency-- the introduction of the wastegate flow disrupts the flow field of the main turbine discharge flow.
Split DP support theory
Seal on veel muudki huvitavat kirjas. Kokkuvõtlikult soovitab Jay Kavanaugh Garretti kontorist WG toru downpipe'i ühendada mitte enne 12-18 tolli (30-45cm). Seda siis sellisel juhul, kui WG väljalaset eraldi vedada ei kannata.
As for 2.5" vs. 3.0", the "best" turboback exhaust depends on the amount of flow, or horsepower. At 250 hp, 2.5" is fine. Going to 3" at this power level won't get you much, if anything, other than a louder exhaust note. 300 hp and you're definitely suboptimal with 2.5". For 400-450 hp, even 3" is on the small side.”
__________________________________________________________________________________________
A divorced dump is designed to separate the two different exhaust gas flows - which is all aimed to improve response. The outlet from the turbine is spinning because of the turbine, which isnt good for flow. The best case would be to 'promote' the spin to change to laminar flow which is apparently done by a sharp step up in pipe diameter (say from 2.5 to 3 inch).
Dump pipe - divorced wastegate pipe make any difference?
Saan aru, et üks probleem seisneb selles, et turbost tuleb turbulentsis heitgaasid, kuid WG-st mitte. Seega, kui need ühinevad, siis toimub heitgaaside voolu aeglustumine.
Maku
postitati 17.04.09 14:36 Tsiteeri
Fordi tjuuning
http://www.bestmufflers.com/Information/fordxr6turbodump2.jpg
http://www.bestmufflers.com/Information/fordxr6turbodump3.jpg
.. the difference in power between a single 4" dump and the 3" pipe with the separate wastegate pipe.
Eraldi WG 303kw, 4" 327kw.
LINK
Maku
postitati 01.05.09 09:27 Tsiteeri
Algselt postitas: Maku
S2 foorumis räägitakse järgmist:
The RS2 manifold is good enough for 450hp crank
Lisa sellele jutule.
I believe that the RS2 manifold isnt a restriction with a GT3071 .63 AR because simply the GT3071 cant make more than the manifold can support.
Appart from this and for tech reasons i believe that the only restriction beyond 450 hp on the RS2 manifold is this K26 flange and nothing more.
So, since the GT3071 with K26 or T3 flange has as 0.63AR this tiny neck in the housing then you would make no more than 10hp with the wagner mani.
This applies only for the GT3071. Everything bigger would for sure benefit from the bigger runners and flange on a Wagner T3 mani.
Wagner Exhaust Manifold v RS2 Manifold
Maku
postitati 01.06.09 20:47 Tsiteeri
On kellelgi kogemusi koonuse kasutamisega downpipe-i alguses? Pildil väidetavalt 450hp masin.
Targem mees kirjutas nii:
“As for the geometry of the exhaust at the turbine discharge, the most optimal configuration would be a gradual increase in diameter from the turbine’s exducer to the desired exhaust diameter– via a straight conical diffuser of 7-12° included angle (to minimize flow separation and skin friction losses) mounted right at the turbine discharge. Many turbochargers found in diesels have this diffuser section cast right into the turbine housing. A hyperbolic increase in diameter (like a trumpet snorkus) is theoretically ideal but I’ve never seen one in use (and doubt it would be measurably superior to a straight diffuser).
There’s more to it, though– if a larger bellmouth is excessively large right at the turbine discharge (a large step diameter increase), there will be an unrecoverable dump loss that will contribute to backpressure. This is why a gradual increase in diameter, like the conical diffuser mentioned earlier, is desirable at the turbine discharge.
Minu turbo outlet on 60mm ja kasutan stock flantsi, mis on keevitatud 3" põlve külge. Kahjuks ei mõõtnud stock flantsi sisemist diameetrit, et oskaks öelda, kas üleminek on suur või mitte. Väidetavalt on RS2 turbo outlet 55mm ja S2 K24 46mm. Oskab keegi flantsi sisemist mõõtu öelda? Kahjuks ma ei tea, kas see on essidel ja sinisel paadil erineva mõõduga.
Veuks
Registreerunud 24.01.06
Auto: audi 80 20vt ja jeep
postitati 02.06.09 04:27 Tsiteeri
3b flants oli 58mm läbimõõduga.
Maku
postitati 02.06.09 05:37 Tsiteeri
Algselt postitas: Veuks
Tänud! Ilmselt pean lähiajal oma masina sumpsi maha kakkuma, siis saan üle mõõta. Kui tollel on ka 58mm, siis tuleb lihtsalt natuke lihvida.
Veuks
postitati 02.06.09 10:40 Tsiteeri
Muidu kui tahtmine asi ennem valmis teha siis nelipaki eest saaks selle 3b flantsi millel otsas 45kraadi 3tolline põlv.Ainult lambda pesad välja lõigatud
Teemo
Registreerunud 15.10.05
Auto: Audi Quattro
postitati 02.06.09 21:15 Tsiteeri
No ma mõõtsin ka täna neid downpipe flantse.
Mul on olemas AAN ja RS2 downpipe. Mõlemal see turbo külge kinnituv flants 57-58mm avaga( ei ole päris ümmargune). Turbo külge kinnituv flants on ca 10 cm, pikk ja edasi läheb juba painutatud toru. Tiba keeruline täpselt seda toru mõõta, kuna on painutatud siit-sealt, kuid keskmiselt on AAN mootoriga variandi puhul toru välisläbimõõt 65mm ümber. RS2 puhul aga 70mm juures, nii et 5mm-ne välisläbimõõdu erinevus on olemas.
Maku
postitati 02.06.09 21:40 Tsiteeri
Mulle meenus, et ehitasin kunagi selle sumpsi ju ABY-le. Anyway tänud Teemole andmete eest.:) Iseküsimus on, kui suur võib see üleminek olla, et koonust ei vaja?
Rst
Registreerunud 06.10.04
Auto: hall metallik diisel Q
postitati 09.06.09 08:58 Tsiteeri
Kuna on jäänud mulje, et essi sõbrad ei julge teha 3" väljalaset, sest kardavad, et jääb liiga lärmakas, siis pakun enda auto väljalaske näidist teile vaatamiseks. Minu arvates on antud süsteem ainult natukene mürarikkam, kui originaal väljalaske süsteem. Mis põhiline, seda väljalaske süsteemi kannatab isegi üksi tõsta ilma, et nikastaks selja ära nagu seda võib teha originaal väljalaske süsteemi puhul. :D
Pütiteks kasutasin Laki Autost saadavaid 3" avadega resonaatoreid.
Resoka läbilõige
Resokas pealt vaadates
Resokas otsast vaadates
Downpipe
Tagumine osa
Terve summuti jooks
salukas8
Registreerunud 23.10.06
Auto: Audi S4 Tq 2,2 169+kW `92
postitati 09.06.09 11:18 Tsiteeri
Mina lahendasin enda 3" summuti ühe resoga. Ja sellega sai asi ikka väga lärmakas. Kõige rohkem hakkas häirima tagaosas tekkiv "kumin" 2000-3000rpm vahel.
ESS:)
laurz
Registreerunud 30.12.05
Auto: b4TQ :D E39
postitati 14.06.09 04:09 Tsiteeri
Ja see 2000-3000 rpm-i on täpselt maanteel kulgemis kiirus:D No nii palju,kui mina aru olen saanud on 3 tolli sumpa aretamine väikeste jõudude puhul suht mõtetu.Seda müdisevat häält saab palju lihtsamalt.Enda S-il sai keskmine pütt vigastada.Sai see lihtsalt vahelt ära lõigatud ja asemele kaks universaalset resot.:P
Maku
postitati 14.06.09 06:40 Tsiteeri
Algselt postitas: laurz
Linnast täpselt sama moodi ju.:D
forsin
Registreerunud 01.07.04
postitati 24.06.09 20:52 Tsiteeri
Algselt postitas: salukas8
Väljalaske klappidest kuni sumpa otsani on mul jälle oma arvamus .(milleni on jõudnud vaid üksikud kubatuur x 3 = hp autod)
(klappidest kuni käigukasti kõrvale teostus auditeam cuubik-ul)
minuarvates on sumpas suurimaks probleemiks eemaldada kuulipilduja tärin (mitte detsibell lärm)
Iga väljalaske klapi avanedes järgnev lask sumpast. (minu lahendusega seda pole)
Näiteks plahvatus sirge toru ühes kinnises otsas tekitab lasu võnke (olenematta toru jämedusest) ja seda võnget saab hävitada ainult ühe meetodiga, nagu püstoli sumbutid (kõrvale võnke paunaga) ok natuke vähendab turbo.
Välja kolle ehk püksid vabalt hingavaga on asi lihtne näiteks viis > ühte ja individuaal torud kolvimahuga peale mida tuleb koonusega hõrendus/jämedam toru/ torud = individuaal resod ehk ühineminek jämedaks. Kasutatakse ka lahendust kaks kolvi mahtu ja siis väga suur hõrendus vabadusse või ühinemine.
Turbokal on asjad keerulisemad ja kasuks tuleb vaid tõuke-d reastamine et ei tekiks enne turbot tühik alasid, mis ei tõuka turbot.
(mõtlen tühik ala all individuaal välja toru seda aega kui v.klapp on kinni ja heitgaas seisab) Lahendus peiub õieti reastatud väljalaske koldes ,siis tekib pidev ühtlane tõuge turbole.
Seda pole vaja kui aetakse taga turbokal vaid põhja pöödre ala max näitajaid.
Sellisel juhul on henri tehtud välja kolle üks õigemaid (individuaal torud ~üks kolvi maht ja teine kolvi maht on ühinemis paun enne turbot ) see tapab enamus võnked ja tekitab turbot tõukava ühtlasema palooni efekti.
Ja peale turbot peab vabanema heitkaasi survest mida on kõrgel hoitud kuni turboni seega turbost väljudes võiks olla koonus jämedamaks vähemalt x2 mahus ja isegi rohkem. Kui turbot tõugatakse näiteks kolme bar-iga ja peale turbot oleks normaalne kui heitgaasi surve langeks ~0,7bar-ini (audi teamile tegin 54-> 80mm sisemõõt)
Tegelikult peaks kohe peale turbot olema lisaks ka võnke leevendi paun +lamda koos wg(tegelikkuses vaid parimad on osanud selle kohapeale teha jämedama koha = esimene reso)ja kuna kogu see krempel elab kuumusega oma paisumis elu siis enne auto kõhu alla jõudmist peab lisama ka lõõtsa.
ja kui asi õieti lahendada asub lamda kohas kus loeb ära kõik heit gaasid mis tulevad turbost ja wg ja seda kohe peale turbot (näiteks auditeamil) tulemus air/füll lõpuni korrektne.
http://fotoalbum.ee/photos/forsin/17274389
Lisandub veel keevitaja probleem sest ~80% maailma tuuning piltidel on kasutatud TIG roostevaba keevitust mida on teostanud ühekäega sulataja (endine ühekäega co keevitaja)
Olen serdiga tig keevitaja ja tean mida räägin , väljalaske torusid peab keevitama pidevalt teise käega traati lisades . või korralikult gaasi keevitusega läbi sulatades sellega peaks paljud küla parmud hakkama saama. ja on tulemus parem (enamus ilu tuuning firmadega võrreldes)
Maku
postitati 25.06.09 12:17 Tsiteeri
Soovitan pilgu heita SIMONS'i valikutesse. Võin näiteks tuua, et RS2 väljalaset pakutakse 6719 krooni eest. Sealt lahutame klubikaardi %-id veel maha ja saame päris mõistliku pakkumise (edasimüüa http://www.atoy.ee). Kes on omal käel väljalaset ehitanud, teab, mis raha pütid, torud ja põlved maksavad..
Maku
postitati 15.07.09 06:06 Tsiteeri
Giant Muffler Comparison - The Mufflers!
Huvitavad tulemused.
http://us1.webpublications.com.au/static/images/articles/i3/0381_4lo.jpg
Genie Tornado. Straight-through absorption stainless steel muffler. Round hole internal tubing with stainless steel wool plus other absorption material. Welded seams and polished. Centre / offset ends. Dimensions: 36x11x24cm Mass: 4.7kg
TULEMUS - The best straight through muffler tested here is the Genie Tornado. It has a flowbench-verified flow figure as good as that of an empty pipe, and noise reductions as high as 18dB(A). Its stainless steel construction is very durable, although its higher price reflects both its performance and construction. It also has a pleasing sound.
FLOW - centre in 362 cfm, offset in 359 cfm. Seca full-load noise 108 dB(A), static noise 90-91,5 dB(A)
http://us1.webpublications.com.au/static/images/articles/i3/0381_5lo.jpg
Exhaust Technology (M) 14614. Straight-through stainless steel absorption muffler. Round holes for full length. Larger bore internal tubing. Welded seams and polished. Dimensions: 36x15 Mass: 4.5kg
FLOW - 382 cfm. Seca full-load noise 109 dB(A)
http://us1.webpublications.com.au/static/images/articles/i3/0381_6lo.jpg
Exhaust Technology "tube". Straight-through absorption mild steel muffler with round holes. Expansion chamber in centre of tube. Welded seams. Dimensions: 44x9cm Mass: 2.5kg.
FLOW - 347 cfm. Seca full-load noise 112 dB(A)
http://us1.webpublications.com.au/static/images/articles/i3/0381_7lo.jpg
Walker 20627 Resonator. Straight-through mild steel absorption muffler. Directional inward punched louvres with absorption material. Welded seams. Dimensions: 28x9cm Mass: 1.8kg
FLOW - vents forward 281 cfm, vents rear 308 cfm. Seca full-load noise 116 dB(A)
http://us1.webpublications.com.au/static/images/articles/i3/0381_8lo.jpg
Walker PF41 Resonator. Straight-through mild steel reflection style resonator with outward punching for half the tube length. Rolled seams. No absorption material. Dimensions: 25x10cm Mass: 1.4kg.
FLOW - vents forward 401 cfm, vents rear 395 cfm. Seca full-load noise ca 120 dB(A)
http://us1.webpublications.com.au/static/images/articles/i3/0381_9lo.jpg
Genie Turbo. Tri-flow reflection / absorption stainless steel muffler. Round hole internal tubing with stainless steel absorption material. Welded seams and polished. Dimensions: 36x11x25 Mass: 4.5kg.
TULEMUS - The best tri-flow (reverse flow or “turbo”) muffler tested here is the Genie Turbo. It mixes amongst the best flowbench results with superior noise reduction over the other high-flowing mufflers. Another stainless steel design, it will have excellent longevity.
FLOW - centre in 252 cfm, offset in 252 cfm. Seca full-load noise ca 107 dB(A), static noise 87-89 dB(A)
Genie Tornado ja Genie Turbo müra vahe tuleb max paar detsibelli, kuid voolavuse vahe ca 100 cfm-i! Esimene on siis otseläbi ja teine tagurpidi vooluga.
Ja parim dogleg stiilis pütt:
http://us1.webpublications.com.au/static/images/articles/i3/0381_15lo.jpg
Walker Lukey L0099. Single flow reflection / absorption mild steel muffler with round hole perforated tubes. Centre expansion chamber. Absorption material around end sections. Rolled seams. Dimensions: 35x11x20 Mass: 3.5kg.
FLOW - 285 cfm. Seca full-load noise ca 108 dB(A), static noise 90-93 dB(A)
KOKKUVÕTE
Unless you need to fit a muffler just so that you can pass a noise test, steer clear of baffled mufflers - their flow is typically only about half that of a same length piece of empty pipe. Tri-flow (reverse flow or “turbo” mufflers) also typically flow badly - even a good one only has about 70 per cent of the flow of an empty pipe. However, tri-flow designs can be significantly quieter (but not always!) than straight-through designs. Tri-flows can also have a deeper, mellower sound. A good dogleg muffler gives a very pleasing note, together with adequate flow and noise reduction.
The best bet then is a straight-through muffler. If used in conjunction with a cat converter and good resonator (or simply a second straight-through muffler), you will have a system that definitely has excellent flow and very probably has a good quality, quiet sound. The latter unfortunately can't be guaranteed - too many other factors determine the actual noise output.
Rst
postitati 15.07.09 07:35 Tsiteeri
Laki Auto 3" resoka läbilõige
Tundub, et sellepärast ongi mul auto suht koht vaikne tänu nendele resokatele. Lisaks läks turbo spoolup umbes 500 rpm'i madalamaks, kui originaal keskmise ja viimase pütiga. ;)
Maku
postitati 15.07.09 07:50 Tsiteeri
Algselt postitas: Rst
Seni loetu põhjal on soovitatud kasutada võimalikult suure gabariidilist summuti pada. Originaal pütid on nagu voolitud alla. Seega üks variant oleks need lõhki lõigata ja vajalikus mõõdus otseläbi aukudega toru asemele keevitada. Selle ümber loomulikult ka heli summutavat villa. Rst, sul on ka muidugi suht suured lapikud padad, kuid originaal padad on ju veel suuremad.:) Peaks kodus ühe stock pada lahti lõikama, näeks, mis seal peidus on.:)
Maku
postitati 21.07.09 07:32 Tsiteeri
Algselt postitas: MaQQu
lihtne arvutus näitab, et 2 x 2,5" kogupindala on suurem kui 1 x 3" seega hingamine vabam. Kuivõrd seda vaja on, oleneb konkreetselt masinast, mootorist.
Vastusurvetest ja muudest faktoritest tahaks isegi targemaks saada.
edit:
tegin siis need lihtsad arvutused.
1x2" toru = 4051mm2
1x2,5" toru = 6330mm2
2x2" toru = 8103mm2
1x3" toru = 9116mm2
2x2,5 toru = 12660mm2
Jamo: Exhaust is not about cross sectional area and volume it's about gas flow, the best exhaust is the shortest one of the same diameter all the way through. A straight through 3" exhaust will gas flow better than twin 2.5
GazzaG60: 2x2.5 may flow better but we have a single pipe from the turbo not 2. this then would need to go into 2 pipes causing a turbulent point. 3" straight through wont have that issue. the area of the pipe, is very important as long as it flows well.
what's the exhaust pipe size should be for GT2871R??
On nende asjadega kuidas on aga mina pole veel kuulnud otsast lõpuni otseläbi süsteemi, mis mul pead valutama ei paneks. Ehk on tõesti need lakiautos müüdavad lapikud padad head, mine sa tea. Näiteks Robinsoni kunagise RS2-ga sõites tekkis natuke lenduri tunne, sest kumin ja vilin tuli salongi. Seal on 3" ja lõpus MTM-i pada. Kiireka S4-al oli vist 70mm väljalase ja ka see lärmas nii, mis kole. Eks väljalaske ehitamisel neli peamist eesmärki olegi kaal, egt, spoolup ja rõhu hoidmine.
mulk
Registreerunud 11.11.03
postitati 21.07.09 10:55 Tsiteeri
Pindala valem ringil on:
Pi x R2 (raadius ruudus)
3" toru välism66t on 76.1
76,1 / 2 = 38.05
38.05x38.05=1447,8
3,14x1447,8=4560mm2
Maku, arvutused nagu ei klapi?
Maku
postitati 27.07.09 11:09 Tsiteeri
Vähemasti S5 pada paistab tagant selline, millest võib järeldada, et see on midagi sellist (dogleg).
A dogleg muffler is a close cousin to the straight-through muffler, except the exhaust gas travels through an expansion chamber via a 'dogleg" path (ie two 90 degree changes in flow).
Eelmainitud testi kokkuvõte kohaselt oli dogleg pada voolavus 285cfm-i ja otseläbil 359cmf-i.
Maku
postitati 17.03.10 11:27 Tsiteeri
More importantly, if the exhaust backpressure rises higher than the induction pressure generated by the compressor, some exhaust gases will remain in the cylinder after the exhaust stroke to dilute and reduce the incoming air/fuel charge, and in worst-case scenarios, exhaust gases will actually flow backward into the induction system during the "overlap" period inherent in most camshaft designs where both the intake and exhaust valves are open simultaneously (see Fig.6). In this last case, such backflow is very detrimental since it raises the temperature of the incoming air/fuel charge and promotes damaging detonation.
http://www.bankspower.com/techarticles/show/36-airflow---the-secret-to-making-power
Maku
postitati 27.03.10 08:45 Tsiteeri
On kellelgi pilti WG torust seest poolt?
Stock wastegate is fine, top tip ditch the OEM flexi tube from the wastegate. If you look at it the internal pipe in the flexi is only an 1" thick!
Replaced mine with a 2" flexi pipe custom made
http://www.s2forum.com/forum/showthread.php?t=43756
Eero
Registreerunud 29.10.04
Auto: B2 2dq
postitati 14.04.10 10:39 Tsiteeri
Lühidalt:
1. downpipe;
2. 2x55mm torud kattide kohal (peale downpipe-i);
3. enne eelviimast pütti läheb kokku üheks 2,5" toruks;
4. eelviimase ja viimase püti vahel samuti 2,5" toru.
Seoses sellega, et mul on plaanis väljalaske kollektor nüüd ära vahetada ja selle ürituse raames väljalaset üldse veidi korrastada, tekkisid mõned küsimused. Hetkel ripub see väljalase kuidagi liiga maadligi, põhjast üsna eemal.
RS2 stock downpipe peaks olema 2.75'' ja siis läheb kõhu all kaheks 2,5'' toruks ja siis hiljem uuesti kokku üheks 2,5''
Minu mõte oli lahti saada sellest kaheks minemisest, ehk siis downpipe lõikaks enne hargnemist pooleks, kinnitaks ta käigukasti külge ja paneks sinna otsa 2.75'' suka ja edasi 2,75'' toruga kuni esimese pütini, mis on 2,5'' sisselaskega.
Kas see kaheks hargnemine pole näiteks selle mõttega tehtud, et saaks 1 kati asemel kahte kasutada ja võita sellega vastusurves? Katid ei ole mul nii või naa hetkel plaanis ja selles probleemi ei näe...
Teemo
Auto: Audi Quattro
postitati 15.04.10 05:49 Tsiteeri
Mu endise 90 20vt-l oli ka RS2 downpipe, mis enne hargnemist läks 2,5 tolli peale ja lõpus oli üks c4A6 resonaator. Ise hindasin väga piisavaks u.300hj jõule. Sukk on kasulik jah, sest endal rebenes uue rv toru küljest poole aastase vahega kinnitus, mis toetus kõigukastile, sest sukka polnud. Muidugi masina kasutusotstarve oli suht jõhker.
Ei usu eriti et kahe katiga vastusurvele mängiti. Pigem tagati sellega parem heitgaas, kattide säilimine ja torustiku mitte liigsuur läbimõõt.
[PHP: 12.2% - SQL: 87.8%]
