 Lehekülgi:  1  ..  66  67  68  69  70  ..  85
Pealkiri: VAG-COM / VCDS (Vastuseid: 2123 | Vaatamisi: 3074183)
jast112
Registreerunud 20.04.15
postitati 27.06.15 09:08 Tsiteeri
Hei.
Mul siis tulid sellised veateated. Äkki keegi oskab aidata. Muidu kuskil tulukesi ei põle. Panin lihtsalt kaabli taha ja voila sellised üllatused. Tänud. Esp ka ei toimi. Vähemalt ei lähe on. Skännimise ajal viskas, et leiti mingid vead. Esp goes off vms. Auto muidu sõidab ilusti hetkel.
Audi a6 avant c6 2.7 tdi quattro
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000184530
Shop #: WSC 00012 888 06946
VCID: 23450907E2202306A91-8076
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 610402092
Coding: 344630393135313035442056413036313034303230393220
Shop #: WSC 00011 888 06946
5 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 255
Reset counter: 255
Mileage: 140488 km
Time Indication: 0
Date: 2010.12.02
Time: 09:54:18
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Reset counter: 255
Mileage: 210117 km
Time Indication: 0
Date: 2013.01.30
Time: 23:44:02
00992 - Consumption Cut-Off Active
Freeze Frame:
Fault Status: 00110000
Fault Priority: 7
Fault Frequency: 14
Reset counter: 255
Mileage: 235268 km
Time Indication: 0
Date: 2013.08.31
Time: 18:12:20
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 1
Fault Frequency: 2
Reset counter: 192
Mileage: 229611 km
Time Indication: 0
Date: 2013.06.28
Time: 07:21:21
02255 - Voltage Measuring Lead from Vbat
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 4
Fault Frequency: 47
Reset counter: 132
Time Indication: 0
Date: 2013.02.20
Time: 19:19:56
Ramm
Registreerunud 15.03.07
postitati 27.06.15 09:45 Tsiteeri
aku hakkas tűhjenema ja süsteem lülitas teatud funktsioonid välja. ühesõnaga kustuta ära ja lae akut ja asi korras.
tl470487
aeg maha
Registreerunud 06.07.11
postitati 27.06.15 10:02 Tsiteeri
Ega ikka ei lähe korda, kui hädaline osad vead sealt postitusest ära muutis ehk ära kustutas. :D
Loomulikult ESP ei tööta, kui roolinurga kohta andmeid pole.
jast112
postitati 27.06.15 10:54 Tsiteeri
Tõsi. Ma puhastasin koodid ka vcds ja siis skännisin uuesti ja tulid ainult need koodid. Küsingi ainult selle koodi kohta hetkel.
tl470487
aeg maha
postitati 27.06.15 10:57 Tsiteeri
Miks see ESP tekst siis?
Algselt postitas: jast112
jast112
postitati 27.06.15 11:05 Tsiteeri
Algselt postitas: tl470487
No ma ei tea ju. Ega ma tähele ei pannud kas ta nüüd viskas. Lihtsalt unustasin kustutada selle siit postitusest. Tahan selle regulaatori asja korda saada. Sellel on fault priority 1, mis on siis suht tähtis, et saaks korda nagu uurisin interneti avarustest. Soovingi teada, et kas kellegil on sama viga viskanud ja kuida korda on saanud. Kas vahetan aku? Vahetan selle regulaatori?
tl470487
aeg maha
postitati 27.06.15 11:10 Tsiteeri
Oleneb, mis viga see täpsemalt oli. See ei lähe ise korda ja käed peab mustaks tegema selle konkreetse sõiduki juures nagunii sõltumata sellest, mis kasvõi tuhandetel on varem sama veakoodi taga seisnud.
Kui ise remondiga ei hakka tegelema siis niisama ajaviiteks asja uurimiseks on: http://wiki.ross-tech.com/wiki/index.php/Main_Page
postitati 27.06.15 11:26 Tsiteeri
Kuupäevasid ikka vaatasid, millal vead on tekkinud? Ei ütleks, et just eile ;)
jast112
postitati 27.06.15 12:01 Tsiteeri
No jah alles ostsin kaabli. Auto ka sai ostetud eelmine aasta lõpp.
ivorturb12
Registreerunud 21.10.08
postitati 04.07.15 20:39 Tsiteeri
Millist silindrit näitab vag-com 3silindri all reaalselt?
V6 audil vaatan näiteks pihusti näitusid, 3silindri pihusti näit kehva.
Kokku v6-el näitab vag-com 5 pihusti väärtusi, ehk siis juhtpihusti oma ei tohiks näidata.
Kuid kolmanda silindri oma parasjagu ongi ju juhtpihusti. Kuid mida vag-com selle all mõtleb vms?
kaits68
Registreerunud 29.06.09
Auto: A6 2,8Quattro`97; A6 1,9TD`02
postitati 20.07.15 08:55 Tsiteeri
Kõike läbi lappata siin raske, et on äkki juba läbi käinud see siit. Sai siis airbag maha võetud, ilma ,et oleks akku klemme eemaldanud ja nüüd siis põleb tuluke armatuuris. Lihtsalt kustutades ära ei kao, kui kaabliga kallal käia. Sooviks täpsemaid juhiseid :)
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AR
Component: A6-Klimavollautomat 0208
Coding: 00103
Shop #: WSC 00040
VCID: 6AD1DC711664C89
1 Fault Found:
01592 - Air Quality Sensor (G238)
37-00 - Faulty
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4B0 959 655 M
Component: Airbag 8.4E 3003
Coding: 0000306
Shop #: WSC 02314 785 00200
VCID: 3A712C317644B89
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
001 - Upper Limit Exceeded - Intermittent - MIL ON
muidugi ka esimene viga olnud pikemalt üleval,, millega tegu?
tl470487
aeg maha
postitati 20.07.15 09:08 Tsiteeri
Järelikult on seal jätkuvalt mingi viga, mis on vaja kõigepealt korda teha ja alles siis allub süsteem selle vearegistrist kustutamisele.
kaits68
postitati 20.07.15 09:11 Tsiteeri
Et siis peaks ära kustuma ainult lihtsalt vigade kustutamisega?
tl470487
aeg maha
postitati 20.07.15 09:19 Tsiteeri
Ilmselt küll, kui intermittent aga kui ei saa kustutada siis ikkagi vigane ahel. Ülemine viga seisneb õhu kvaliteedi anduris, mis ilmselt oma otsa saanud.
Mihkel.
Registreerunud 18.01.12
Auto: Audi A3 1997 1.6 74kw
postitati 27.07.15 21:34 Tsiteeri
Kas keegi saab abi pakkuda järgmine kolmapäev Tallinnas TBA'ga? (http://wiki.ross-tech.com/wiki/index.php/Throttle_Body_Alignment_(TBA)). Sai mootor ära puhastatud ning nüüd tühikäigu pöörded kukuvad väga aeglaselt alla. Jäävad nii 1700 peal korra kinni ja siis kukub vaikselt. Lekkeid ei tohiks olla - brake cleaneriga testitud tühikäigul.
Mihkel
kaits68
postitati 28.07.15 14:22 Tsiteeri
Sain siis airbagi tulest lahti- aga tulemuseks siis nüüd järgnev probleem.Tekkis sellega, kuna sai lahti võetud see kopsik, kus rooliasendi andur ja muud asjad sees, et kontrollida airbagi linti. Kahjuks jõudis sõber anduri paigast ära kruttida ja kui panin aku klemmid tagasi ja süüte sisse , siis l'ksid põlema pidurisüsteemi veateate, abs ja eps tulukesed ja veateade järgnev. Kas on võimalik koduste vahenditega seda eemaldada või tuleb terve roolisasendi anduri karp välja vahetada?
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 1728
Coding: 00000
Shop #: WSC 00000
VCID: 254BEF4DBFFA271
2 Faults Found:
00778 - Steering Angle Sensor (G85)
66-10 - Not Matched - Intermittent
01044 - Control Module Incorrectly Coded
35-00 - -
tl470487
aeg maha
postitati 28.07.15 14:26 Tsiteeri
Arvutiga rooliasend vaja kalibteerida. Ei midagi keerulist.
kaits68
postitati 28.07.15 14:50 Tsiteeri
kas saab sinna lihtsalt ligi või vaja ka mingit parooli selle seadistuse tegemiseks?
tl470487
aeg maha
postitati 28.07.15 14:54 Tsiteeri
Lihtsalt.
Midagi sellist abiks, kui VCDS-ga möllad: http://wiki.ross-tech.com/wiki/index.php/Audi_A6_(4B)_Brake_Electronics_(Bosch_5.3_ABS/EDS/ASR/ESP)
Paljude muude seadmetega ei ole mingit login-i vaja.
kaits68
postitati 28.07.15 15:30 Tsiteeri
sai proovitud, kuid kui üritada siseneda steering angle nupuga, siis natukese aja pärast saab teate- No response from controller
tl470487
aeg maha
postitati 28.07.15 15:33 Tsiteeri
Siis tee kodeering ja seadistused kõigepealt.
kaits68
postitati 28.07.15 17:11 Tsiteeri
sain keskmise suure hüüumärgi eest ära, kuid abs põleb ikkagi veel. Esp kustub ära , kui piduripedaali vajutada, kuid tuli tagasi järgmise süüte sisse panekul:)
postitati 30.07.15 12:54 Tsiteeri
Algselt postitas: kaits68
1. Seda tehakse ABS alt.
2. Ära tee asju, mida reaalselt teha ei oska. Oma vigadest õppimine läheb kalliks.
xemm
Registreerunud 01.05.07
postitati 06.08.15 18:03 Tsiteeri
Väike probleem seoses VCDS 14.10.2'ga. Auto on 2007 aasta Allroad 3.0 TDI
Nimelt tahaks et kojamees tagurdades vihmasensor sees asendis ei töötaks.
Lähen Central Electronics -> Adaption -> Channel 16
Algul ütleb security access reguired, nii lähen tagasi ja võtan security access lahti ja toksin koodi mis mulle programm ette ütleb sisse, ütleb et kõik okei ja pääs olemas.
Lähen tagasi Central Electronics -> Adaption -> Channel 16
Vaja panna 1 asemele 0.
Panen 0, vajutan test ja save ja siis mõtleb natuke ja ei tee midagi
Võtan kanal 16 lahti ja jälle security access reguired.
Seda ringi mingi 3 korda proovitud ja ikkagi ei saa väärtust nulliks.
Kaabel ja soft tl470487 käest.
siim1314
Registreerunud 12.04.11
Auto: A6 2006 171kw
postitati 06.08.15 21:40 Tsiteeri
Algselt postitas: xemm
Siin paar lehekülge tagasi peaks ka sellest teemat olema. Ma ei ole enda omal siiamaani sellest lahti saanud- ikka aegajalt katsetan kui arvutiga autos käin, aga no ei võta seda 0i omaks. Mõne teise arvuti külge saama ehk
[PHP: 9.0% - SQL: 91.0%]
