Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Quattrorõõmud 2015/2016 (vaidlused veoskeemide üle kustutatakse hoiatamata!)
 Lehekülgi:  1  2  3  4  5  6  ..  8
Pealkiri: Quattrorõõmud 2015/2016 (vaidlused veoskeemide üle kustutatakse hoiatamata!) (Vastuseid: 189 | Vaatamisi: 29479)
raimo21
Registreerunud 21.08.09
Auto: A6
postitati 05.01.16 21:45 Tsiteeri
Waze juhatas mind täpselt jää peale.
postitati 05.01.16 21:52 Tsiteeri
Algselt postitas: raimo21
Ok. Küsisin, sest mapsid, regiod ja maa-ameti portaal annab koha kätte küll, kuid ega see karjäär just sopalomp pole, et esimesest august sisse ja oled kohal ;).
Näis, ehk põikab ka läbi!
Keskmine sügavus 1,6 m, suurim sügavus 2 m, annab lootust, et suurt uppumist karta pole :).
real-illusion
Registreerunud 27.09.11
Auto: A6 3.0 TDI 165 kw Q
postitati 06.01.16 01:53 Tsiteeri
Et kui pikk mees, jääb nina vee peale? :D
Life is tough.
cilaper
Registreerunud 16.06.07
Auto: C5q
postitati 06.01.16 02:25 Tsiteeri
http://www.upload.ee/thumb/5457129/11111.jpg
Kliki, et suurelt näha ;)
rass
Registreerunud 25.09.02
postitati 06.01.16 07:23 Tsiteeri
https://lh3.googleusercontent.com/-Y4erPDA-XbQ/VozAq4-FXLI/AAAAAAAAOOU/i8JLX-0cKuA/s800-Ic42/quattro.jpg
Arno
Registreerunud 09.12.10
Auto: 103Kw
postitati 06.01.16 18:05 Tsiteeri
Jäädvustasin ka natuke quattrotamist :P https://www.youtube.com/watch?v=wVgXdTqcM60
postitati 06.01.16 19:46 Tsiteeri
Käisin kohal, rada on OK, kuid pimedas on suht nadi ikkagi + kui keegi veel ees sõidab, siis tomu üleval jne.
Kohale sõites tuli vastu üks Sierra ja üks BMW, jääl harjutas Ziguli.
Muidu oli OK.
galaxy09
Registreerunud 25.03.15
postitati 07.01.16 05:21 Tsiteeri
Natke offtopic, aga kas keegi teab miskit rääkida selle auto ajaloost?
http://www.auto24.ee/used/2143530
Jäi silma ning endalgi vesistab nelikveo järgi :D monovedu ei ole ikka "see" talvel :)
Kui keegi teab midagi,siis võiks PS saata või siia kirjutada, kui moderaatoritele see sobib, ehk saan ka neljaveolise rõõme nautima hakata ;)
Muidu head tuiskamist ja kindlat teed :)
Siim89
Registreerunud 07.06.10
Auto: C5 1.8T; C4 2.2TQ;
postitati 07.01.16 07:48 Tsiteeri
Tundub täitsa viisakas isend + Recaro sisu. 2.8 üsna lollikindel ja kui natuke kõrgem kütusekulu vs R4 ei heiduta, siis hind on sellise varustusega quattro kohta täitsa hea.
Gaasipedaalikate on ära, stange parempoolne võre samuti, püsikat samuti kahjuks pole. Rohkem midagi silma eriti ei hakka.
S4 OMC 238 km/h, ET 13,04
postitati 07.01.16 09:12 Tsiteeri
Kui asja põhiline eesmärk on jäärada ja lund tarbida, siis ma võtaks pigem B kere.
Sellel masinal on kunagi armatuur vahetatud, ilmselt ka esiistmed. Väga ei usu, et kõrvalistuja airbag sellel masinal juba tehasest oli.
Eero
Registreerunud 29.10.04
Auto: B2 2dq
postitati 07.01.16 09:29 Tsiteeri
Ma arvan ka, et jäärajaks sobib pigem b3 quattro kõige paremini, veidi kergem kui b4/c4 ja jupid ka veidi odavamad.
quicky
Registreerunud 08.02.14
Auto: S4 B7 Avant 4.2L ATM
postitati 07.01.16 09:54 Tsiteeri
Kas täna (nelajpäev) päeva ajal on keegi minemas Kõrnumäele? Lööks kampa :)
ragnara
Registreerunud 23.03.12
Auto: A4 b9 2.0TDI Quattro
postitati 07.01.16 10:30 Tsiteeri
Võrus kuskil ka libiseda saab?
lauri90
Registreerunud 19.07.09
postitati 07.01.16 11:53 Tsiteeri
Eile sai männikul Tammemäe karjääril käidud. Puuriga mõõtsime kaldast paarikümne meetri kauguselt jää paksuseks 20+cm, seega igati piisav. Õhtusel ajal oli korraga ~5 autot peal. Mingi rada oli ka sisse sõidetud.
Volts123
Registreerunud 01.03.14
Auto: S6 c5
postitati 07.01.16 13:10 Tsiteeri
Krt mehed...kadedaks teeb.
Siin Soomemaal on minu arust igasugune mitteametlik jäärajatamine seadusega keelatud(100%ei tea aga nii olen kuulnud).
Aga kui mõni Soome poole foorumlane teab Uusimaa kandis "sideways" liikumise kohti,siis andke julgesti teada...:D
Siin juu järvi jalaga segada.
Auto: 6x4x4
postitati 07.01.16 13:13 Tsiteeri
Algselt postitas: Volts123
Eks järvel ja liivakarjääril on ka pisike erinevus sees "looduslikus mõttes" ;).
nimi
Registreerunud 15.01.09
Auto: B5 1.8tq STW, B5 S4
postitati 07.01.16 15:04 Tsiteeri
Männikul ka käidud ja kannatab juba sõita küll.
postitati 07.01.16 15:38 Tsiteeri
Kui oled grupi liige, siis saad lugeda natuke: https://www.facebook.com/groups/EstFin/permalink/958095897561338/
Lühikokuvõte siis selline, et ühed härrad plaanivad teha Vanta kanti põllule raja. Mina igatahes igapäeva autoga sinna ei roniks, kuna ei tundu just kuigi sile olevat ja põld on ümbritsetud korralike kraavidega.
Volts123
Auto: S6 c5
postitati 07.01.16 16:38 Tsiteeri
Algselt postitas: R-I-X
...olin seda lugenud juba...see hetkel jah auto lõhkumise koht rohkem.
Aga põllu peale saab hea raja kindlasti kui vastav tehnika olemas on...elame,näeme.
end3l
Registreerunud 27.06.07
postitati 08.01.16 08:56 Tsiteeri
Eile kell 13.43 teatati häirekeskusesse, et Lääne-Saare vallas Kuusnõmme külas oli mootorsaan läbi jää vajunud.
Pole midagi igal pool 20cm jääd:D
Sparkle
Registreerunud 27.12.07
postitati 08.01.16 19:41 Tsiteeri
Kas kellelgil on tõsist plaani homme sõiduoskust lihvima minna harjumaal kuhugi jää peale? Võiks väikse kambaka teha. :D
Xen0n
Registreerunud 01.03.15
Auto: Lexus IS250
postitati 08.01.16 20:32 Tsiteeri
Algselt postitas: Sparkle
Võiks täitsa:)
Tarmo_j
Registreerunud 12.05.13
Auto: Audi A6 C6 3,0tdi 2004a
postitati 08.01.16 23:04 Tsiteeri
tahaks ka jääle :D
Ise plaaniks kuskil peale 12 minna enne seda lapsega ujumas.
Remo
Registreerunud 06.08.10
Auto: Mercedes-Benz , BMW , Audi
postitati 09.01.16 08:03 Tsiteeri
Kas kusagil Saares ka mõni asjalik plats või rada juba tehtud on, kus saaks quattroga sõita? Mingid kaupluste parklad ning see mõttetu Sikassaare kõrrepõld eriti huvi ei paku.
Got ARB and nitrous?
Sparkle
postitati 09.01.16 08:37 Tsiteeri
Kõrnumäel elu käib:D
http://www.upload.ee/image/5465801/CAM00015.jpg
[PHP: 0.3% - SQL: 99.7%]
