 Lehekülgi:  1  ..  21  22  23  24  25  ..  54
Pealkiri: Audi A4 "S4" 1,9TDi quattro - 1998 - freeser (Vastuseid: 1330 | Vaatamisi: 330645)
postitati 17.10.12 14:41 Tsiteeri
Garretti kodukalt ka natuke infot:
Q. What is compressor surge?
A. The surge region, located on the left-hand side of the compressor map (known as the surge line), is an area of flow instability typically caused by compressor inducer stall. The turbo should be sized so that the engine does not operate in the surge range. When turbochargers operate in surge for long periods of time, bearing failures may occur. When referencing a compressor map, the surge line is the line bordering the islands on their far left side. Compressor surge is when the air pressure after the compressor is actually higher than what the compressor itself can physically maintain. This condition causes the airflow in the compressor wheel to back up, build pressure, and sometimes stall. In cases of extreme surge, the thrust bearings of the turbo can be destroyed, and will sometimes even lead to mechanical failure of the compressor wheel itself.
postitati 17.10.12 16:05 Tsiteeri
Sul rõhukell ikka näitab õigesti. T5 2,5 TDi PD mootorid teevad sama häält kui turbo geomeerria kinni hakkab jääma. Hoob ei liigu piisavalt kiiresti ja tekib ülerõhk järsul kiirendusel või lihtsalkt kohapeal tuuritades.
kuno666
Registreerunud 15.07.06
Auto: 2xV8 & 1x 2,2 20v.
postitati 17.10.12 16:14 Tsiteeri
Minu seat teeb peale tühja toru allapanekut ka käiguvahetusel sellist powwww häält aga Taneli autol tuleb natuke seda geomeetria varrast timmida sest algul ta tegi veel julmamat häält. Proovib nv seal kallal veel askeldada ehk saab asja natuke paremaks.
Tehnic
Registreerunud 19.12.08
Auto: Audi a4 1.9tdi, A6 C5 Avant Quattro BAU
postitati 17.10.12 16:50 Tsiteeri
Kindel, et sul ikka BV43 turbo on? Eelmainitu peaks siiski sobima üks ühele külge, kui välismaiseid foorumeid lugeda. Teine küsimus on selles, et sooviks näha neid parameetreid mis näitavad 103kw mootori pihustiotste andmeid? Ise väga ei usu, et need suuremad on kuna 81kw tuleb 4silindri peale ja 103kw 5silindri peale ning puudub nagu loogiline vajadus sinna suuremad pihustid panna. Parandage mind kui kellegil täpsemat infot.
Imres
Registreerunud 11.03.07
postitati 17.10.12 16:56 Tsiteeri
Turbo on Gt2052v.
Best ET 13,414@A4
Kenwood
Registreerunud 03.03.07
Auto: Audi V8 ; MB
postitati 17.10.12 17:00 Tsiteeri
AEL pihustiotsa suurus 0.216, peast enam ei mäletad palju see oli AFN omadel, äkki 0.184 ( ei anna pead ) Aga vahe on tunda. Ise kasutasin 1Z mootoril neid ja sõitsin neldega ligi aasta, nii et hirmus kummik järgi.:D
Samas, head kokka tunneb sellest, et pann on tahmane.
Tehnic
postitati 17.10.12 17:05 Tsiteeri
Peaks olema siiski originaalis 0.205 AFN mootoril.
teitur
Registreerunud 07.07.10
Auto: Allroad C5, VAZ 2105
postitati 17.10.12 17:08 Tsiteeri
AFN on .205 avaga. Kas ta sul tossama ei hakanud peale pihutsiotse vahetust?
E:Tehnic jõudis ette:)
kuno666
postitati 17.10.12 17:12 Tsiteeri
Mille pealt see BV43 turbo pärit peaks olema ?
Kenwood
Auto: Audi V8 ; MB
postitati 17.10.12 17:21 Tsiteeri
Algselt postitas: Tehnic
Selge, eksisin järelikult. Nii väikse vahe peale vaevalt väga suitsema hakkab, natuke jõulisa peaks ikka tulema.
BV43 turbo peaks saama 125kw 2.0l tdi pealt.
Leopold661
Registreerunud 17.11.04
postitati 17.10.12 17:56 Tsiteeri
Algselt postitas: freeser
19x8,5 235/35
https://lh6.googleusercontent.com/-CcGl26Ky-es/UFCSl7Mu79I/AAAAAAAABv8/cW4X-dgOFhg/s800/DSC_0239.jpg
Oleme ausad,need eelmised veljed mis sul olid ei kõlba küll kuhugi.Uued on tegijad.
jrgen99
Registreerunud 02.02.05
Auto: A6 2.5TDi Avant quattro 1997
postitati 17.10.12 21:47 Tsiteeri
Algselt postitas: JoonasJJ
Hästi ei saa aru, miks sa sellist asja üldse ehitanud oled, aga huvitav projekt on küll. (Y)
Tanel on lissalt kopeerinud selle projekti ühelt mu sõbralt.
freeser
Registreerunud 24.06.11
Auto: Audi S6 2,2 20v, S3 8V
postitati 17.10.12 22:36 Tsiteeri
Algselt postitas: jrgen99
Siiski olen ma juba sammu võrra temast ees :) Ideid on palju tema poolt jah. Aga see ainult mootori kohta, välimus on kõik enda tehtud ja enda ideed :)
freeser
postitati 24.10.12 13:54 Tsiteeri
Talve veljed. Või noh eel talvekad :D Ühel veljel on jube piduri tolm peal, ei tea kuidas selle küll puhtaks saaks. Ahjaa Revalist sai ostetud uued velje poldi katted ka. 7,99€ maksis 20tk :)
https://lh4.googleusercontent.com/-W68oTlnbbCo/UIfoK2Mt2OI/AAAAAAAAB5U/VMBI-cUHhNs/s640/DSC_0303.jpg
https://lh5.googleusercontent.com/-CE9N5kkZXkg/UIfoc5aGktI/AAAAAAAAB5c/AcKcAvxCFso/s640/DSC_0299.jpg
https://lh4.googleusercontent.com/-beVWzrFMhcg/UIfor3N5W-I/AAAAAAAAB5k/p_KfkFE7R9U/s640/DSC_0300.jpg
https://lh5.googleusercontent.com/-ujminG8dG4w/UIfo9JFlgOI/AAAAAAAAB5w/eVbkY7seQnE/s640/DSC_0301.jpg
https://lh4.googleusercontent.com/-reunzl7E24o/UIfpNoVmAKI/AAAAAAAAB54/cThd-pa0IKs/s640/DSC_0302.jpg
https://lh4.googleusercontent.com/-SoyDimmHDAM/UIfpcUqzZ1I/AAAAAAAAB6A/Bb1GPkp96cs/s640/DSC_0304.jpg
https://lh4.googleusercontent.com/-iQEXaCXwwM8/UIfn8xvVv4I/AAAAAAAAB5M/kQNZtWsb8y0/s640/DSC_0297.jpg
charley
Registreerunud 21.09.09
Auto: Audi A6 C5 Avant
postitati 24.10.12 14:26 Tsiteeri
Eest näeb küll väga kuri välja (Y). Sul paistab olema selline tänamatu kodutee, et enne kui maanteele jõuad on autol küljed juba tolmused/pasased.
Margus_H
Registreerunud 10.07.11
Auto: X5
postitati 24.10.12 14:51 Tsiteeri
Karbilaiendid annavad tublisti juurde, külgvaates paistab kuidagi massiivsem see kere. Millega velgi küürisid ja kuidas toimis?
raino84
Registreerunud 29.12.05
Auto: Audi A6 Allroad 2,7Tdi, 140kw, 09
postitati 24.10.12 15:00 Tsiteeri
On ka hea vahend see Autosol´i Wheel Cleaner? Kui jah, siis kus konkreetset toodet saada?
freeser
postitati 24.10.12 16:27 Tsiteeri
Algselt postitas: charley
Eest jah kuri :) Tee on jah 800m kruusa :S
Algselt postitas: M.H
Annavad jep ;) Autosoli wheel cleaner, tegi puhtaks küll, aga mitte niipalju kui mul vaja.
Algselt postitas: raino84
No mul on räme piduritolm seal ühel veljel ja seda ta maha ei võtnud. Leotasin pigileotusega, sai natuke puhtamaks küll, aga jah see vahend isegi toimib väiksema pasa peal. :)
kuks456
Registreerunud 31.08.12
Auto: Audi A4 Tdi
postitati 25.10.12 08:06 Tsiteeri
Esiots on mõnusalt masiivne ja sünge(Y)
KsenoonE
Postitusõiguseta huviline
Registreerunud 05.01.10
postitati 25.10.12 11:38 Tsiteeri
Velje jaoks kasutada sellist http://pood.automaailm.ee/est/autokaubad/autokeemia/rehvidele/?productID=3647
Ülihästi töötab, kõik veljed puhtaks saanud sellega.
freeser
postitati 25.10.12 12:03 Tsiteeri
Algselt postitas: kuks456
ON! :cool:
Algselt postitas: KsenoonE
No kui muud üle ei jää toon selle ära jah :)
Heix
Registreerunud 30.09.07
Auto: VW Phaeton 2011
postitati 25.10.12 12:39 Tsiteeri
freeser seda sama toodet kasutaski, pakend vaid teine...
Vorsprung durch Technik
freeser
postitati 25.10.12 13:58 Tsiteeri
Algselt postitas: Heix
Üks on happega, teine ilma.
Heix
postitati 25.10.12 20:04 Tsiteeri
Siis küll...
Ise olen pool aastat Inglismaal autode hooldusega tegelenud ja võin omast kogemusest öelda, et hape eemaldab hästi piduri tolmust tekkinud kollase jume kuid pigiplekkide vastu aitab vaid pigieemaldus. On olnud ka juhuseid kus piduri tolm on olnud väga intensiivne ning kaua veljel olnud ja velge korralikult puhtaks pole saanudki.
mokits
Registreerunud 22.12.06
postitati 25.10.12 20:11 Tsiteeri
Ma sain oma auto puhtaks pigi eemaldus- ja mootoripesu vahendiga. Ei anna pead kummaga mida tegin, aga mõlemat läks pudel ja pill igalt poolt puhas!!! Ja turustaja oli erimell :) Tõesti olid tõhusad vahendid, kui pudelid leian, siis saan pildid teha ja siia riputada :P
[PHP: 5.9% - SQL: 94.1%]
