Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Lõtk/kolin esisillas
Pealkiri: Lõtk/kolin esisillas (Vastuseid: 35 | Vaatamisi: 9664)
AudiA4Avant
Registreerunud 15.01.13
Auto: Audi RS3, Cabrio B4
postitati 04.06.13 21:03 Tsiteeri
Algselt postitas: Hr.MarkoM
Algselt postitas: AudiA4Avant
Ei hakkand uut teemat tegema.
Sai alla pandud taastatud esisild umbes 2-3nädalat tagasi. Kuid miskit koliseb ees ikkagi. Sõites natuke ebatasasema teepeal kostub eest "lõkklõkk" ehk siis miskit ees lõgiseks, nagu oleks miskit täiesti lahti. Olen poldid kõik ülekeerand ning sellest tolku pole olnud. Kontrollisin ka pidurid üle, et klotsid ei koliseks. Kust edasi viga otsida? Uued silla osad olen heebliga üle kontrollind.
Audi A4 B5 2001a.
Kas vedrud terved? Kui murdunud siis see tükk võib ka koliseda seal all pesas.
Kolisesid suht lahti olevad välimised rooliotsad.
100
Aeg maha
Registreerunud 12.04.10
Auto: 100
postitati 15.07.15 19:32 Tsiteeri
Mu autol (2,3 mootoriga C4 100, manuaal, esivedu) on mingi eriti rõve kägina/kriuksumise moodi heli kusagil ees, aga mitte kuidagi ei ole saanud tuvastada mis täpselt seda teeb. See probleem on olnud juba vähemalt pool aastat ja olen käinud kahes kohas näitamas, kuid ei ole selgust saanud. Täiesti ulme, iseenesest silla ehitus ju väga keeruline pole. See on mingi eriti "kaval" viga ka, mõnikord praktiliselt ei esinegi ja mõnikord on eriti kõvasti kuulda. Vist oleneb ka ilmadest, kas on soe, külm, kuiv, märg... kuid ma ei ole konkreetselt niimoodi tähelepanekuid teinud milllal täpselt esineb rohkem ja millal vähem.
Heli on kuulda põhiliselt kohalt minnes ning madalate käikudega hoogu maha võttes, kuid on olnud ka vabakäiguga mingi ebatasase koha peal.
Ei tahaks küll nö. kindluse mõttes kõiki sillas olevad pukse ja patju vahetada, saaks kuidagi selle täpse põhjuse teada. Mis seal olla saab: stabika sisemised ja välimised puksid, õõtshoovapuksid, silla ja kere vahelised puksid, peaks olema küll vähe tõenäoline kuid päriselt võibolla ei saa välistada ka mootori- ja käigukastipatju. Originaal ei neist asjadest ükski, kõiki on millalgi vahetatud. Siiski sõber ükskord kuulas kui eriti hullu heli tegi ja talle tundus parema ratta poolt tulema heli, kuid täpselt ei saanud aru. Jälle kuhugiu kontrolli minna tundub üsna mõttetu, raha tahetakse ikka silla kontrollimise eest, kuid midagi ei leita.:(
postitati 16.07.15 07:42 Tsiteeri
Amordid, vedrud?
Dr.Rammstein
Registreerunud 09.04.10
postitati 16.07.15 07:48 Tsiteeri
Algselt postitas: Kivitare
Amordid, vedrud?
Täpselt nii peakski olema.
Suru autot käega esitiibade pealt alla ja õõtsuta üles-alla. Kuula, mis häält teeb ja kuidas käitub.
Mob: 58144911
100
Aeg maha
Auto: 100
postitati 16.07.15 15:03 Tsiteeri
Amordid said sügisel uued (õlikad) kuna üks 8 a. vana amort (gaasiamort) ühel hetkel kiilus kinni ja oli nagu puupakk all. Vedrud amortide vahetamise ajal olid korras, eks igaks juhuks püüan veel üle vaadata, kuid üldiselt kui näiteks mingil väikesel metsateel suurtest sujuvatest aukudest läbi sõidan ja amordid ning vedrud töötavad päris pika käiguga, siis ei ole seda heli täheldanud. Linnas ühes sellises kohas on tulnud seda heli vahel, kus kiirusel u. 10-15 km/h toimub keeramine ja ühe ratta all on sügav kanalistasioonikaevu kõrval olev lohk, vahepeal seal tuli ikka väga jõhker heli kuuldavale, tundus et eriti just siis kui 2. käiguga gaas maas sealt läbi sõitsin. Enam aga ei ole selles lohus seda heli välja tulnud ja on põhiliselt kohalt minnes ning vaikselt 1-2 käiguga sõites kiirendamise-käiguga pidurdamise alguses.
Muuseas, asukohaks Pärnu. Äkki keegi, kellel võimalused olemas selleks (tõstuk, kanal), tahab üle vaadata.;)
iiri3e
Registreerunud 28.01.15
postitati 22.07.15 14:20 Tsiteeri
Minul tegi heli sarniir
100
Aeg maha
Auto: 100
postitati 28.04.18 14:33 Tsiteeri
Vana teema, aga mainiks ära, et probleem kadus peale õõtshoobade ja stabika pukside vahetust, ilmselt võis seotud olla šarniiriga.
sir-mac
Registreerunud 26.06.03
Auto: S6 4,2 Avant
postitati 28.04.18 16:29 Tsiteeri
Algselt postitas: 100
Vana teema, aga mainiks ära, et probleem kadus peale õõtshoobade ja stabika pukside vahetust, ilmselt võis seotud olla šarniiriga. [/quote
]Kui ära vahetada kõik esisilla jupid, siis võibki eeldada, et viga oligi just šarniiris. Klass!
100
Aeg maha
Auto: 100
postitati 28.04.18 16:39 Tsiteeri
1 šarniir oli konkreetselt läbi, seepärast õõthoobade ja pukside vahetamiseks läks ja sellest ka kahtlus.;) Puksid ei olnud konkreetselt läbi, aga õõtshoobade vahetamise käigus oli loogiline ka need vahetada.
sir-mac
Auto: S6 4,2 Avant
postitati 28.04.18 17:28 Tsiteeri
Tore, kui said selgusele. mis oli mure põhjuseks. Aga ega sa kodus ju ei vaheta välja kõiki lampe, kui üks nendest on läbi põlenud?
:D
100
Aeg maha
Auto: 100
postitati 28.04.18 18:59 Tsiteeri
Miks peakski kui eraldi vahetamise puhul rohkem maksma ei pea ja oluliselt enda mugavus ei kannata.
Kui aga pean ühe remondiga seonduva ebamugavuse asemel valima 2, siis seda küll ei taha. Tavatööajaga tööl olles pole just kõige lihtsam autot remonti viia ja sealt ära tuua, eriti veel kui töö võib viia vahepeal ka kusagile teise Eesti otsa ja võib hiljem (kui juba remondikoht suletud) tagasi jõuda. Elu on näidanud, et kui 1 juba läbi on, siis pole ka ühtegi head põhjust miks teine samal ajal paigaldatud šarniir peaks oluliselt kauem vastu pidama. Roolivardaotstega sama lugu. Koolituskulud kunagi ammu juba tasutud kus peale ühe detaili vahetamist sillastendis käidud ja mõne kuu pärast uuesti.:) Ja kui juba õõtshoovad vahetada, oleks mu arust lausa naljakas kui jätaks mõne õõtshoova- või stabikapuksi vahetamata (C4-l).
[PHP: 12.4% - SQL: 87.6%]
