Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi A4 Avant´96 kesklukk
Pealkiri: Audi A4 Avant´96 kesklukk (Vastuseid: 29 | Vaatamisi: 3444)
postitati 18.11.10 07:33 Tsiteeri
Siit tekkis mul ka kohe küsimus, et mis sa arvad, kas oli asi seda jamamist ja muretsemist väärt? Või oleks kohe võinud spetsialisti juurde minna? Mul ka muidugi selliseid kogemusi, autol ei töötanud tagumised kõlarid, võtsin lahti, ohoo, mõlemal poolel pistikust üks juhe lahti, jootsin tagasi, aga ei midagi, ostsin veel ühe kõlari, et proovida ja ikka ei midagi, kiskusin salongi lahti, ajasin juhtmeid, taga, alles siis mõõtsin juhtmete takistused, olid korras, mõõtsin kõlarite takistused, olid korras, läksin lõpuks spetsialisti juurde, kes keeras nupust tagumised kõlarid peale:) Ma olin seda Audi Gamma makki a4 peal omanud üle 6a, nüüd sis sama asi ka a6 peal ja ei teadnud, et ühel nupul on mitu funktsiooni:) Ise olin lihtsalt rumal ja sellega põhjustasin endale meelehärmi.
Pipi
Registreerunud 21.05.10
Auto: Audi A4 Avant ´96
postitati 18.11.10 10:48 Tsiteeri
Algselt postitas: audi_a4_v6
Minul selle kõigega jamasid ei kaasnenud. Ehk jah natuke peavalu. ;)
Nõu küsisin siit, sest tahtsin eelnevalt olla ise kursis, mis kõige tõenäolisemalt viga on. Ennetades seda, et autoremonditöökojas vaadatakse, et naine, nagunii midagi ei jaga, ajame häma, uurime nats asja ja siis esitame "arve". Vaevalt siis arve 300.- oleks olnud. :)
Ise ei plaaninudki "parandama" hakata. Üks loll suudab rohkem vussi keerata kui pärast sada tarka parandada. :D
exess
Registreerunud 28.05.06
postitati 18.11.10 12:13 Tsiteeri
Pipi,ära pane mõnda tähele,ilmselt "pahad päevad" ;)
Foorum ongi selleks,et küsida ja uurida:)
Pisike punane putukas
Pipi
postitati 18.11.10 12:34 Tsiteeri
Algselt postitas: exess
:D :D :D ei ole hullu
Mulle meeldivad mehed, kes naisi "lollideks" ei pea. Väga positiivne oli näha kuidas mu küsimusele vastati ja arutleti. Hea tunne ja loomulikult suur abi.
Olen nüüd jälle ise ka ühe asja jagu targem. Mulle meedib, et omades autot olen kursis ka tehnilise poolega. Parandama ma ise ei hakka, aga teada tahaks küll. ;)
Ma ei tunne isegi kaasa nendele naistele, kes oma "seljakotiga" parkimiskohast välja tagurdada ei suuda, ilma, et nad kedagi tiivaga riivaks. ;) (eile õnnestus päästa oma auto sellise naise eest)
Sulle, exess, erilised tänud teadmiste eest, sul oli õigus!
Edu teile targad mehed :cool:
postitati 18.11.10 14:45 Tsiteeri
Lihtsalt siit foorumist käis ka sada muud varianti läbi ja tihti on see nii, et inimene kardab seda kõige hullemat, kuid tegelikult muretseb asjatult! Effekt on umbes sama nagu ravimipakilt kõrvalmõjusid lugedes:)
[PHP: 41.9% - SQL: 58.1%]
