Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - audi turboks?
 Lehekülgi:  1  2  3  4
Pealkiri: audi turboks? (Vastuseid: 77 | Vaatamisi: 9834)
postitati 04.11.08 20:29
Algselt postitas: mett
aga kuidas oleks voimalik siis teha 2,6i kw kõige kergemini juurde ma ei motle selliseid varjante et osta teine auto.
väljalase paremaks, mitte vihmaveetoru, aga alustuseks mootoripoolde "lati" asemele torukolle. sisselase paremaks, midagi 2.8 muudetava pikkusega sisselaske laadset. surveastme suurendamine. kindlasti midagi veel.
juurde saad....kogemusi ja reaalset mõtlemist.
hj kasv on ikkagi nii väike, et pigem mata see mõte maha ja osta 2.2t
kiin21
Registreerunud 17.10.05
Auto: Audi
postitati 04.11.08 20:31
NOS? :D
Raika
Registreerunud 03.11.03
postitati 04.11.08 20:32
Muhvigi ei rehkenda välja:o
Kahju küll mainida aga nii palju peaks ikka julgust olema, et kohe ei tormata ESIMEST - PROBLEEMIGA/KÜSIMUSEGA postitust kustutama/muutma:mad::mad::mad:
mett
postitusõiguseta huviline
Registreerunud 20.08.08
postitati 04.11.08 20:33
vaadake tegelikkult on asi selles miks ma üldse hakkasin mõtlema sellise asja peale oli see et ma sain selle 2,6 v6 700 kr eest ja see töötab mul endal seda uuemat audi kere pole aga see läheb sigarile peale.Ja kuna juba läheb tegemiseks siis mõtlesin et voiks äkki teha aga enam vist ei hakka jamama.tänud aga ütleme et ma panen 2,8 k,kasti sellele külge kas see muudab midagi voi mitte.
juks11
postitati 04.11.08 20:36
Esmalt õpime õigekirja selgeks ja ka kasutame seda ning siis võiks ka foorumisse korrektses vormis kirjutada, sellistpaskaonsitaksraskelugedajakamingikstõsiseltvõetavaksasjakspidadapunkt
mett
postitati 04.11.08 20:44
aga mis te sellest arvate kas osta voi mitte teie soovitusel vaatan s-seeriat?http://www.auto24.ee/webcache_kasutatud/812/auto_php-id=25812-www_auto24_ee.html
Raika
postitati 04.11.08 20:47
no päris hea seda ma kohe teengi.
kuidas sa seda teed kui küsida tohib esimese postituse kustutamine ehk teemat algatava postituse kustutamine ei ole veel teema kustutamine :P
olbert
Registreerunud 13.01.06
Auto: Golf IV 1,9TDi 4Motion Variant
postitati 04.11.08 20:50
see ju remonti vajav! miks sa ei osta korralikku?
Kuule mees, ega sa rahvastepalli ei mängi, kus sul mitu elu on!
www.alunaut.ee kõik alumiiniumi tööd (tegemist siis merealumiiniumiga)
mett
asi vaata selles et ma suht esimest korda siis (tegin enda teema)ja ei oska kustutada ?aga mis te sellest arvate muidu jätame selle turbo juttu siis sinna paika kuna kisub juba vägivaldseks.Eks see on siis nii lootusetu asi aga mis te sellest arvate.sellest audist mis ma panin just ülesse.
sadguy
Registreerunud 16.03.06
Auto: Coupe, 9-5 T, Octavia
postitati 04.11.08 20:51
k2igukast peetis.
mett
postitati 04.11.08 20:52
sellepärast et mul endal ka käed otsas.Ja tahaks ise midagi ikka teha.
olbert
postitati 04.11.08 20:54
kui sa juba turbotamisest "nii palju" tead siis kui palju sa veel tiptronic kastist tead?
MartinCS
Registreerunud 28.03.06
Kallis mees, sa küsid huupi aga vastused on foorumis ammu olemas. Kui ma ütlen, et selle auto remont on selle auto teine hind, siis sind see ei rahulda, ma eeldan?
Võta nüüd asja rahulikult ja uuri teooriat. Mida rohkem sa uurid, seda rohkem sa saad aru, et sa ikka suurt ei tea veel. Alles siis mine praktikasse. Sellest autost käi kaarega eemale. Ära küsi miks.
Oma kätega võid tega keretöid, aga mitte S8-t remontida ja ülal pidada.
mett
postitati 04.11.08 20:57
seda ma algul ei vaadanud aga noh ega ma pole ütelnud et ma nendest tean jube palju aga ma lihtsalt küsisin.
mett
postitati 04.11.08 20:58
aga veel kord vabandust et ma küsisin.Ja kuidas teemat kustutada saab
sadguy
postitati 04.11.08 20:59
Sina ei saagi
mett
postitati 04.11.08 21:00
no siis kustutage ära ja ma ei tüüta teid rohkem.
Auto: 6x4x4
postitati 04.11.08 21:01
Mulle meeldib selliseid teemasid aeg ajalt lugeda, hea meelelahutus :P.
mett
postitati 04.11.08 21:02
võtta heaks.Said lolli üle naerda.HAAHa
Tort
Registreerunud 16.09.07
Auto: A4 2.6
postitati 04.11.08 21:29
Mingi s4 vaata omale kui huvi on.
Auto: 6x4x4
postitati 04.11.08 21:37
Ära pane pahaks, aga siin foorumis on selliste soovidega kasutajaid iga kuu paar tükki. Mida ei viitsita on see, et lugeda natukene teemasid, mis on "turbo"'ga seoses. Leiad hunniku samalaadseid teemasid kus soetatakse säästupill ja siis hakatakse kohe kõvasti turbotama ja lisaks ka kasulikku infot kuhjaga, mille läbi lugemisel EI JÄÄ eriti palju enam küsimärke õhku. Aga noh mis sa teed, inimene on ju laisk ja ootab, et kõik kandikul ette tuuakse.
Simps
Registreerunud 29.01.05
Auto: erinevad
postitati 04.11.08 21:43
Taolised teemad ajavad juba närvi.
Konrad
Registreerunud 27.09.06
Auto: SL63
postitati 05.11.08 05:37
Algselt postitas: tarmo
Ma juba vaatasingi, et tükk aega pole enam ühtegi turbotajat näha olnud :)
12 points! :D
postitati 05.11.08 08:01
Muidugi! Noor mees (tahaks hirmsasti profiilis su vanust näha), käed otsas, tegutse! http://www.roadrashed.com/Smilies/jerkoff.gif
estliiga
Registreerunud 16.08.07
Auto: BMW e39 520d touring ja VW GOLF MK2 1.6td
postitati 05.11.08 21:35
Mida te siin turbotate, pane üks korralik SUPERCHARGER peale.
See oleks midagi huvitavat :D
http://www.youtube.com/watch?v=PZ8_uSoVi0w
Audi V8 4.2 atm quattro 1992, Audi 80 b4 2.8 pooleveoline 1993, Audi Coupe 2.3 10 v pooleveoline 1992, Audi A6 C4 2.6 pooleveoline 1997, BMW E36 325i, VW Golf 4 1.4, VW Golf 4 1.9 TDI, Audi A6 C4 2.6, VW Golf 4 1.9 TDI, Audi A6 C4 Avant 2.8 quttro, Audi A4 1.8, BMW e39 520d touring
 Lehekülgi:  1  2  3  4
[PHP: 25.6% - SQL: 74.4%]
