Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Õõtsad määritavaks
Pealkiri: Õõtsad määritavaks (Vastuseid: 29 | Vaatamisi: 4360)
postitati 12.04.13 12:43 Tsiteeri
Algselt postitas: Fugitive
Tööriistamarketist osta niplid, auk puurida sarniiri alla keskele. Muud kunsti seal pole, aint, et määret tuleb lisada tihedamini kui 1x aastas....nii 6-12x tihedamini.
Kui suuri (mis läbimõõduga) nippleid oleks mõistlik kasutada? samuti kui pikk peaks/võiks olla sarniiri sisse keeratav vindi osa? Välismaises foorumis soovitati seibe vahele panna. Mõistlik oleks vist kasutada nurgaga nippleid, et paremini ligi pääseda hiljem määrimiseks? Ja viimaks, mida soovitaksite sinna sisse pumbata, tavaline tavott pole vast see kõige parem asi?
V200
Registreerunud 11.09.04
postitati 12.04.13 14:13 Tsiteeri
Algselt postitas: rass
See õli sisse süstimine, millest eelpool räägitakse tundub ausalt öeldes veidi kummaline. Üks asi on kummaline torgata ise kummi auk sisse nõelaga, teine on mootori õli.
Mootoriõli panemine suhteliselt suure lõtkuga detailide määrdeks kõlab tõesti kummaliselt. See peseb sealt selle vähesegi õige määrde välja ja tilgub minema. Pärast on nii, et roomad auto all iga kuu ja tilgutad õli juurde, aga veermik läheb ikka sama kiiresti või veel kiiremini läbi. :)
Sharniiri kestvuse määrab ennekõike see, kas on kasutatud õiget materjali või mitte. Terasel ja terasel on vahe. Mõni noname asi on nagu seebist tehtud ja ei saagi kesta, määri millega tahad.
postitati 12.04.13 14:39 Tsiteeri
Algselt postitas: V200
Rääkides B5 sharniiridest (mille suhtes enamik siin huvi tunnevad) siis seal on ju plastikust kauss mille sees on see metallist kuul liigend, siis esimese asjana hakkab seal järgi andma just see plastikust kauss, või ma eksin?
instruments
Registreerunud 04.08.12
postitati 12.04.13 15:25 Tsiteeri
Selline varuosa tootja nagu MOOG. Nendel peaks olema juba niplid küljes.
Auto: 6x4x4
postitati 12.04.13 16:24 Tsiteeri
Määrdeniplitega võib jännata nende liigendite puhul, mille kummikate jääb allapoole. Kui liigend jääb kummikattega ülespoole, siis pole mitte mingit mõtet määrdeniplil, piisab sellest, et uuel liigendil kummikatte alune pooltelje otsa määret täis lasta ja uuesti korralikult kate fikseerida. Enda tehtud liikuritel KÕIK liigendid nii tehtud ja ei oska ma midagi paha kosta (pole nagu võrdlust millegagi eriti :D). Määrdenipleid pole kasutanud, piisab sellest kui kummikattealune piisavalt hästi täis lasta ja veenduda, et see sealt ei "irduks" paigaldusel, kate teeb juba oma töö ise ära ning ütleme nii, et imet või igiliikurit ei maksa väga samuti loota!
Kui hästi otsida, siis sellest on siin foorumis ka mujal juttu liigendite taastamisega seonduvates teemades.
PS! Fugi, mul on ühel isendil roolivarraste otsad isegi all sama meetodiga ja seda juba ~10+ aastat ja ~160tkm. Usu, ma pole neid vahepeal nipeldanud või määret lisanud! Nii et see "kord aastas" no ma ei tea... Jumal hoia selle "kord kuus eest".
[PHP: 18.2% - SQL: 81.8%]
