Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Tespera OÜ
Pealkiri: Tespera OÜ (Vastuseid: 27 | Vaatamisi: 8335)
M-Tech
Registreerunud 19.01.04
Auto: Audi Q5 3.0TDI Off-Road Package
postitati 07.11.05 21:52 Tsiteeri
CarStop on lihtsalt suur kett millel on eri firmadega lepingud.
Kõik kohad ilmselt saastad ei ole.
Ka mina omast kogemusest soovitan Tesperat vältida, suht lambad on seal koos.
Sõbra B4-jal lükati 15k maksnud tutikate valukate kodarate vahelt kang läbi, et silda painutada.
Kus selliseid inimesi välja võetakse. Sõber pani loomulikult kisama selle peale.
Nn. digitaalne sillaregull on ka suht huumor neil seal, niidid jooksevad ümber auto, mis on sajast kohast jätkatud.
Minu kogemused nendega paari aasta tagused, kuna rohkem pole sinna roninud ja kõigil teistel olen ka soovitanud seda kohta vältida.
rain28
Registreerunud 16.09.05
Auto: Audi 100 2.0CC 1985
postitati 08.11.05 07:40 Tsiteeri
käisin kah seal ära...va tesperas ja ei olnud meeldiv kogemus.
vahetati stabika pukse ja tehti sillastendi..
kuna mul polnud kuskile kiiret siis passisin seal samas.
esimene laks oli, et nad ei saanud rooliotsi lahti... andsid leeki nendele seal üks kõva pool tundi...
pärast kui hakati tagasi panema ei saadudki tagasi
pandi uued mis ei istund hästi siis.. pange tähele!- kuvaldaga
aidati need otsad sinna tagasi!!
jube urgas on see koht!
ferdinand
Registreerunud 17.01.03
Auto: 400,401,969
postitati 08.11.05 08:07 Tsiteeri
Algselt postitas: rain28
Vaadates su masina aastaarvu siis rooliotsad käivadki niimoodi ära. Olen ise samaealisel lausa roolilatini lammutamisega jõudnud, et rooliotsa vahetada. Kuvaldaga tagasi panemine on muidugi teine teema, ausaltöeldes ma ei kujuta hästi ette mismoodi saab kuvaldaga rooliotsa paigaldada.
Üldiselt jätab teema sellise mulje, et "materdame nüüd kõik". Tegelikult tean omadest kogemustest, et on hullemaidki kohti, kuid kõik sõltub ikkagi konkreetsest töömehest. Kui ikka ei oska ja ei viitsi siis pole midagi teha... Olen ka nii mõneski remondikohas käinud ja jõudnud selleni, et enamuste remonditööde jaoks leian ikka ise vaba laupäeva, pole lihtsalt tallinna piirkonnas ühtegi asjalikku ja mõistliku hinnaga kohta vanema auto hooldamiseks ja remondiks.
[PHP: 36.0% - SQL: 64.0%]
