Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Remote control boxi ühendamine
Pealkiri: Remote control boxi ühendamine (Vastuseid: 37 | Vaatamisi: 10672)
samru
Registreerunud 01.02.04
postitati 18.11.13 19:58 Tsiteeri
Algselt postitas: RedRockets
Võtaks korraks vana teema üles, juhtmed samad nagu teema alustajal, nii aga autoküljes juhi jalgejuures pole seda rohelist-sinise triibuga juhet.
Siis küsimus oleks: ''Kui on olemas sellised juhtmevärvid nagu punane/pruuniga ja hall/valge siis saad juhtida kesklukustust "massiga."
Niisis Punane-pruun ja hall-valge on olemas küsimus oleks selline kuidas ma peaksin need juhtmed keskluku süsteemi valge ja valge-musta juhtmega ühendama??
Releede NO kontaktid ühendad "massi" NC jätad ühendamata ja sinu poolt nimetatud juhtmed ühendad valge ühendad näiteks hall/valgega ja valge/musta ühendad punane/pruuniga. Kui kesklukk hakkab vastupidi tööle siis vahetad juhtmed omavahel ära.
RedRockets
Registreerunud 29.11.11
Auto: Audi, BMW
postitati 18.11.13 21:49 Tsiteeri
Algselt postitas: samru
Releede NO kontaktid ühendad "massi" NC jätad ühendamata ja sinu poolt nimetatud juhtmed ühendad vage ühendad näiteks hall/valgega ja valge/mustaga ühendad punane/pruuniga. Kui kesklukk hakkab vastupidi tööle siis vahetad juhtmed omavahel ära.
Tänud!
See jäigi arusaamatuks kas ma ühendan nad kokku või pean üheotsa lahti jätma.
Eks homme proovin ära.
Vähemalt saab kiiremini kui jala!
RedRockets
Auto: Audi, BMW
postitati 22.11.13 12:37 Tsiteeri
Ei olegi võimalik seda kesklukku ära ühendada vist hakkab tunduma :mad:
Hall-valge on olemas, aga punast-pruuniga mitte.
Seal on pruun-hall, punane-sinine ja punane-hall, selles pistikus mis uksesisse läheb.
Testrit ka hetkel käepärast pole et hakata nüüd õiget juhet taga ajama...
JanP
Registreerunud 04.12.09
Auto: 240, 300
postitati 01.12.13 20:24 Tsiteeri
Juhtus mulle kätte üks puldiga keskluku juhtimise süsteem. Kuna mu A6 C4-l on tehase poolt peal kesklukk koos alarmiga, mida saab peale panna juhiukse lukust või pagassi lukust, siis kas seda komplekti kasutades saaks teha asja juhtmevabaks?
Kas see tuleks ühendada juhi kickpanelisse või keskluku pumba juurde? Mis juhtmed selleks vajalikud üldse on? On see üldse teostatav või tuleks pigem mingi aftermarket alarm panna?
Kaasasolev skeem on selline:
http://i00.i.aliimg.com/img/pb/778/507/404/404507778_752.jpg
JanP
Auto: 240, 300
postitati 07.12.13 16:51 Tsiteeri
Ideid kellelgi?
tl470487
aeg maha
Registreerunud 06.07.11
postitati 07.12.13 17:19 Tsiteeri
Mis seal ikka ideetada. Hangid 5 klemmiga standard releed 2tk ja ühendad selle näiteks keskluku mooduli külge. Igatahes teostatav ja kui vajad lisainfot või skeemi ühenduse kohta siis otsi mõni alarmi paigalduse juhend, kus juhised Audi keskluku juhtimiseks.
Algselt postitas: JanP
Ideid kellelgi?
ehanurm
Registreerunud 22.10.10
Auto: Volvo
postitati 10.07.14 06:08 Tsiteeri
Paigaldasin ka samasuguse box-i enda autole (autoks ikka Audi a4 b5). Aga nüüd selline probleem, et töötab puldist nii kuidas suvatseb, vahel paneb lukku ja ei tee lahti, tihti ei pane lukkugi. Kui lukku panna siis tihti lihtsalt box hakkab klõpsuma(nii 4-5 korda), aga vaakumpump ei tee midagi. Enne oli kohati probleem ka võtmega lukustamisel, et vahel lihtsalt ei võtit keerates ei tee midagi (vahel kickpaneli juures relee lihtsalt teeb plõksu ja kõik)
Kas oskab keegi midagi soovitada? Vaakumpump õhtal või kickpanelis relee ?
tl470487
aeg maha
postitati 10.07.14 07:43 Tsiteeri
Võtmeluku lüliti vaata alustuseks üle, et see mingisse asendisse kinni pole jäänud jne. Selline asi selgitab, miks alati pult ei kuuletu. Viga võib olla, kus iganes ja ainult mõõtmine teeb targemaks.
ehanurm
Auto: Volvo
postitati 10.07.14 09:15 Tsiteeri
Algselt postitas: tl470487
Vabandan, aga ei saa aru täpselt aru, kus ja mis see võtmeluku lüliti on ?
postitati 10.07.14 09:21 Tsiteeri
Algselt postitas: ehanurm
Ukse luku sees olev lüliti. Lisaks vardale, mis mehhaaniliselt avab selle ukse lukust, on luku küljes ka pistik (luku sees lülitid) mis annavad keskluku pumbale teada, kui uks lukustatakse/avatakse, et keskluku pump ülejäänud uksed lukustaks/avaks pneumaatiliselt.
ehanurm
Auto: Volvo
postitati 10.07.14 09:26 Tsiteeri
Algselt postitas: R-I-X
Okei, siis on vist ikkagi juhiukse lülitiga mingi kamm, sest võtmega lukku keerates tihtipeale ei lähe ülejäänud auto lukku, aga kõrvalistuja poolt keerates läheb alati auto kinni. Lahti tehes on ka tihtipeale, et teeb ainult juhiukse lahti ja ülejäänud uksed tulevad alles siis lahti kui oled juhiukse avanud.
postitati 10.07.14 10:00 Tsiteeri
Ma ei ole küll teab mis kogenud selles osas, kuid pole varem kuulnud, et need lülitid seal luku küljes ära oleks surnud. Isiklikult vaataks enne uue luku otsimist üle ka ukse ja kere vahelised juhtmed.
T_
Registreerunud 23.10.07
Auto: VW Passat B8 4-mo
postitati 10.07.14 10:13 Tsiteeri
Kogetud sama jama. Lüliti on lukusüdamiku peal. Juhtmed hall/valge ja punane/pruun.
Hall/valge oli ära mädanend.
[PHP: 12.5% - SQL: 87.5%]
